Question about Bosch Dishwashers
We have a SGS53C12 - The water is not draining we have cleaned filters. Sometimes this works but a few days later it blocks again. The programme runs to the end of its cycle but water still there. Is there anything else we can try? We bought dishwasher June 2007.
  • 7 Answers
SOURCE: another inlet / drain light cycle interruption problem!
When the water stops too soon, it could be the "over flow" is stuck in the downward position, therefore the dishwasher thinks it's going to over flow. Check that out. Otherwise I'm afraid this sounds like the circuit board is shot.
Miss Midget
Posted on Nov 02, 2007
SOURCE: Indecit dishwasher not circulating water
Checked that the motor was not seized by inserting slotted screwdriver through hole at back of machine to engage in slotted end of motor to spin up water circulating motor. Motor was not seized, so that was not the problem. Then took bottom off machine and on inspection found that the start capacitor which is bolted to side of motor was bulging and discoloured wher the terminals are. Replaced Start capacitor ( Less than £10.00) and machine motor started up. Machine behaved irratically at first, flashing lights etc.but got it to reset by switching on and off a couple of times, ran machine through cycle, now working ok.
Posted on Mar 15, 2008
  • 4 Answers
SOURCE: Dishwasher drains continuously
I dismantled and checked various parts of the dishwasher and everything seemed to be working. I noticed with a phase tester that the pressostat never got any voltage. This led me to check the microswitch on the door which turned out to be broken (never making any connection). This is the microswitch that turns off the dishwasher when someone opens the door.
So an unusual problem - two faults at the same time i.e. clogged and overflowing drain and broken door switch!
I ordered and fitted a new door switch and now the machine is working fine again.
Posted on May 30, 2008
SOURCE: Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Posted on Jun 05, 2008
SOURCE: Cycle seems never-ending
on the ECO 50 cycle dish washer will not stop. have had to switch it off, when try to restart it automatically goes back to the ECO 50 programme. Can you please help. The Serial No. is ADP 2440 WH.
Posted on Dec 06, 2008
Hover DYN 7164 error E16
OK Anthony! Now you have enough money to FIX the machine! LOL. First One error begets another. So forget about the errors! You are focusing on them too much! You told yourself whats wrong with this machine! OK Give Up? It is Not Draining! It is your Drain Pump Lad! Go and buy a new one, replace but remember to unplug it first. Don\'t due all that other stuff. Run the machine afterwards on a short cycle and guess what? No water!
Jan 20, 2014 | Washing Machines
Our heating and hot water keeps turning off
Sounds like a glitche in the thermostat. First, override the program & see if it does the same thing over the next few days.
Dec 11, 2013 | Honeywell Programmable Thermostat Heater
The water will not drain from the dish washer and there does not seem to be anything blocking the drain. I ran it through another cycle and now it is leaking water slowly. Is there anyway to drain this...
I would suggest removing and cleaning the filter sometimes debree and build up of small particals can stop it from draining. Clean the filter in hot soapy water and then replace it in the dishwasher and run the dishwasher through a cycle, this worked for me.
Jan 25, 2011 | GE Nautilus 24" Built-in Dishwasher
Hi, good evening. I have a zanussi iz12 washing machine that stops during rinse node and gives e20 fault (wont drain). I checked the pump - working fine. I've found that if i blow into the waste pipe the...
Hi there
I have an IZ12 jetsystem which sometimes works and other times it starts and then clicks and stops just before the water starts to run in. I usually turn it off and try it again a few hours later and then it starts to work again. Sometimes it is the next day before it will work again. Would anyone know the problem?
Jan 11, 2010 | Zanussi IZ12 Front Load Washer
Dishwasher is 2 years old. Top shelf dishes not getting clean even on on heavy duty and sani rinse cycle. All arms move freely,tried the 2 cups white vinegar in an open container and run cycle. I thought...
Sometimes the holes in the arms get blocked up,sweetcorn,rice etc, this then stops the arm spinning and water being sprayed onto plates etc, unscrew it and run water through the centre hole and see what happens.
Oct 06, 2009 | KitchenAid Dishwashers
SUD and F35 codes come up at beginning of cycle
open front bottom cover their is drain pump open filter from drain pump be care full there is water in your drain pump (may be 1 or 2 gal water)
clean filter put it back. run washer..if you get same error again then change your detergent and use less make sure you use he detergent. let me know it help or not please. thanks.
Jun 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Tumble dryer not working
Spoke to my maintenance engineer at work and he said that most of these appliances work by using float switches. After stripping down and drying out the previous day decided to refill reservoir with water and letting drain back in refilled again 15 mins later till no more water could go back in. Then emptied water reservoir and let the water drain back out into reservoir. Think this must have dislodged the float switch and all seems back to normal.
May 25, 2009 | Electrolux Dryers
Grinds beans, won't dispense water sometimes
I just had this problem. I took apart the brew chamber and cleaned under the screens and everything else I could get to along the path of the water. These areas were completely filled with gum residue and solids. I'm guessing that when they dry out, the water can pass through for a little bit. After a cup or two, they go back to blocking off the water flow.
Mar 09, 2009 | Saeco Vienna Espresso Machine
Ariston Dishwasher LSV 67 AIX wont fill with water pumps out only
somebody is pulling your leg.
messy filter will not cause no fill as long as machine has drained tho it will cause other problems
Jul 15, 2008 | Dishwashers
Dishwashers Logo
53 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
