Dvd recorder i have unchecked the RGB setting on my recorder and lost the picture the sound works but lost picture can you re-set to factory settings
Found the manual thanks
Posted on Feb 21, 2008
DVR620KU From the HDMI connector, how to get non-pinched vertical HDMI images on the TV monitor and on the DVD. Recorded DVD's have been Finalized
Using a DVD-RW disk, try ALL different recording settings even if they don't seem probable and record a sample. If output is correct with all BUT the HDMI-cable, go through ALL picture format settings on the TV when a HDMI-cable is used. Different discs and HDMI cables don't have anything to do with this. I'm still chewing on this...
Dec 15, 2014 | Toshiba DVR620 DVD Recorder/VCR
The picture is blue when I play a dvd. I recently connected it to a new Vizio TV. The other tv it was connected to gave us a good picture.
Check your connections for faults, also some connections on TV's are for RGB inputs, so you might have to try another connector or if you can switch the DVD's output to RGB etc.
Apr 04, 2010 | GoVideo DVR4000 DVD Player/VCR
DVD hooked up to sony bravia tv: have dvd power on, but can not get any set up menus (or anything) from dvd to show on tv screen.Unable to set up remote as menu does not appear on tv screen.
Hook up the player with RGB (Red-Green-Blue or component) cables and try the picture. If everything works OK, then go to the menu and turn on the HDMI output and set the resolution (if needed).
Not every HDMI unit works with every HDMI TV. You may also have a bad HDMI cable. On a DVD recorder, you may have your HDMI cable connected to HDMI IN. You must use HDMI out.
Mar 28, 2010 | Sony RDR-GX7 DVD Recorder
Screen just turned green. Sound but no picture.
Contact your LG repair centre. There will be a problem with the main board settings for the RGB gain levels, this is the area which sets up the colour balance. A factory re-set may cure the problem but more likely the EPROM settings on the main board would need to be rectified.
Nov 29, 2009 | LG Televison & Video
Someone made my video dvd combo black and white
It sounds like the video out put has been set to S video,go into the hv-dx300a menu and look for the video or picture out put settings and set to VIDEO or RGB, rgb is the best if it works for you.
Hope this helps.
Nov 16, 2008 | Sony DAV-SA30 System
I switched to progressive scan on my lg hdd dvd recorder and now i cant switch back .. i have no picture or menu screen
It says in the book that the video output jack has to be set to RGB when using the SCRAT jack. Is that the correct setting?
Jul 26, 2008 | Televison & Video
Wharfedale dvdrhd400 problems
Change the Scart setting (in the setup menu) from the default setting (RGB) to the other available setting (CVSC?).
I have a problem with my box restting the clock on a random basis, making it impossible to set a timer to record anything - let us know if you get the same problem via this site!
Jan 03, 2008 | Wharfedale DVD-M3 DVD Player
Pioneer DVR-520H DVD Recorder Picture is Yellow
If running component or RGB try replacement lead set. Otherwise is TV issue.
Oct 12, 2007 | Pioneer DVR-520H DVD Recorder
Fuzzy Picture
Are you using the component (RGB) outputs, and a Sony TV? I believe that there is something in the output of at least some Panny DVD recorders (over the RGB component path), which Sony TVs don't process properly.
Aug 15, 2007 | Panasonic DMR-EZ17 DVD Recorder
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
