Question about Indesit W 123 Front Load Washer
The door latch has no tension in it and door will not open. the wash finishes completely and no water is left in drum?The latch seems to be broken and I need to open door....how can I do this?
  • Indesit Master
  • 3,463 Answers
The normal procedure is to remove the top cover, and force the door open from inside by reaching down and pushimg the door latch open with a screw driver or similar.
Posted on Feb 05, 2010
What could be causing the door latch to release late in the wash cycle of my Kenmore Ultra dishwasher?
The door spring tension might be causing the door latch to become disengaged. Check the level of the dishwasher and also adjust door spring tension. Will need model number to provide more details.
Jul 31, 2014 | Kenmore Dishwashers
Kenmore Ultra Wash Dishwasher door won't open
It seems most likely door latch stock and you going to need buy new door latch as for stock one most likely you hsve to forceit to open and replace it with new one
Dec 09, 2013 | Kenmore Dishwashers
Hi, I am not able to open the door of my Whirlpool washer dryer AWZ 5140 E after it finishes the cycle. It shows up E13 with ticking noise. There is no water left at this stage and I am able to open the...
E13 is a dispenser error the appliance diagnostic believes the appliance is full of water so won't release the lock first thing to try is the drain filter bottom right hand corner at the front unscrew it clean and refit just be prepared it's likely u will get some water out it when u remove it.
Dec 08, 2013 | Washing Machines
Machine only hums, will not spin, wash nor will the door open.
  • It sounds like the motor is spinning, but the drum is not spinning. This usually means the belt has broken, or come off of the pulley.
  • Not pumping out the water - if the washer cannot pump out the water, the washer will not be able to spin...check the pump for not pumping.
  • Door not locking - if the door will not lock, the washer will not enter a spin mode. See if the lock light is lite on the console.
  • Broken wires at one of the out off balance switches or a bad switch itself.
  • A fairly common trouble maker has been a burnt diode on the main control board.
Maytag's Neptune washer has a latch and lock on the door. If this lock fails to open when the cycle is finished. You can rescue your clothes by:
  1. Remove the bezel from the soap/bleach/fabric softener dispenser.
  2. Locate the red cord near the right front corner of the dispenser opening. Pull on this red cord. This will unlatch the door so you can rescue your laundry. Then call for service.
Feb 22, 2011 | Maytag Neptune MAH5500B Front Load Washer
The washing machine keeps blinking sud what does this mean? It won't finish the cycle.. it is a kenmore front loader HE 5t
Either you have too much of the correct detergent in there or the wrong detergent in there. Here are a few of the errors:
1)Water fill problem: water took more than 10 minutes to fill to desired level sometimes indicated as a LF/IE or long fill/inlet error. Water valve screens clogged, hoses kinked, low water pressure, unpaid water bill. Check hose, clean screens.
2)Excessive vibration: noisey,roar, knocking noises. Bad damper,bearing or broken trunion. no error code
3)Dispenser drawer open/detergent in wrong compartment: washer will not operate with drawer open or cleaning products in wrong compartment.
4)Washer won't drain: clogged pump/filter, slow or clogged drain usually indicated as a LD/DE, if a code is given (long drain/drain error) Clear pump of objects
5)Drum overfilled: usually caused by sediment in the water level pressure sensing tube going up to the main control.Find it and blow out the sediment, re-secure pump out water and retry.
6)Door open, Door not latched, clothes/objects keeping door from completly closing. Tighten door latch, add washers if nessesary to make good contact and close door tighter in case of leaks.
7)Cold water does not enter washer: hoses connected backwards. Oops.
8)Oversudsing: Wrong Detergent, turbidity monitors pick up particles in the water and judge soil content then the washer allows for extra time to wash the clothes, if the wrong detergent is in there the machine thinks that is too much and declares a suds error. Remove detergent, retry
9)Locked motor: error LE,loose connection,broken wire/hallsensor, motor overheated/failed.
10)Water heating error, hE, the thermister/heater is out.
Feb 01, 2010 | Washing Machines
Door latch broken on hotpoint wt761g washing machine. Machine has gone through wash cycle and emptied all the water, all lights have gone out but I can't open the door.
Depending on which part has gone, some hotpoints door trim post snaps which makes too much play not allowing door to open, in this case needs new door trim. others need drum to be empty of all Water, or could be door interlock faulty .give it a slight bang with your hand to ease open, remember has a 3 min delay on door....
Nov 20, 2009 | Washing Machines
Door Stuck after wash completed
You will have remove top cover, and release door latch from inside the front, with a screw driver pushing against the latch to open door.
It does mean that you probably have a faulty door lock, or broken door handle.
Please rate my fixya solution.
Thanks
Jan 11, 2009 | Ariston Technologies Ariston AWD12 Front...
Beko WMA 765s washer, power works no display
If there is power and lights are showing, but the door will still not open, then it could be one of several things.
First and foremost the door lock could be faulty, or the door handle or latch mechanism could be faulty or broken, if the door lock is not getting power then it is probably the main cotrol unit at fault.
I feel you should get someone to look at it for you.
Dec 07, 2008 | Washing Machines
Not finishing wash cycle
you have a clogged water pump,thats  why water is left behind
May 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Door will not release after wash completed
You may have a failed door latch.  Have it replaced and it should be ok.
Dec 28, 2007 | LG WD-16115FD Front Load Washer
Indesit W 123 Front Load Washer Logo
139 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
