Question about Gateway MX8738 MotherBoard - DAPA6AMB6D5
Where are the conectors for screen located on the
I had to take the screen off from the motherboard. there are two power supply wires that i think should be connected to teh motherboard. however i don't see the connector on the mother board. any idea wher they might be? if i had a motherboard layout i probably can recognize it.
Thanks
    Problem Solver:
  • 5 Answers
Are you sure they are power wires? many notebooks have the antenna wires for the wireless go up and around the screen. if the seem to have a tiny coax connector that is what it is. they are tricky to re-route. follow the bends in the wire for a clue. The wires can also be for a mic or web cam. The harness to the screen is usually one large connector
Posted on Aug 24, 2010
Test watt voltage
Connecting two wires with a jumper will turn it on. Google the model to find out which wires.
Nov 28, 2013 | Dell - NPS-460BB-B (NPS460BBB) Power...
Name of wire based on color coding wire
Special (only on the ATX conector)
-Green is PSon(put a wire between green and black to turn the power on)
-Gray is PWRGOOD
-White is -5V(optional)
-Blue is -12V
-Purple is 5VSB(Always on when the PSU is plugged on)
Power
-Orange is 3.3V
-Red is 5V
-Yellow is 12V
-Black is Ground (0V)
Dec 20, 2012 | Lite On LiteOn 204Watt PA-4022-6B Power...
No video, i try unplgu power cord and power supply conectors, change microprocessor,change power supply, change memmory modules, clear cmos
Hello
either your video card is faulty or if its build into the mainboard then most likely the mainboard is faulty.
Jan 30, 2011 | Biostar U8668D (802700113338) Motherboard
Problem with panel front conector in Dell Dimension 2200 motherbo
The following information is to assist you in performing the right connections. You should take precautionary measures such as grounding yourself and completely disconnecting the PC form any source of power.
This picture shows the connector for the front panel power button, reset button, and power and hard disk lights: an 8x2 pin connector with 1 pin missing:
The table below lists the pinouts for the connector. The orientation of this table is the same as the picture above, this shows the top part of the connector. All the pins below pin 8 appear to be non-connected.
Each pair of pins labeled Power and Reset goes to the 2 wires for the corresponding button. The hard disk and power LED wires connect to the corresponding LEDs, you need to ensure the proper polarity of the + and - wires for each LED or it will not illuminate.
The above information is for your information only.
Mar 01, 2010 | Dell (2M502) Motherboard
Compaq presarios s5500uk wont boot up fitted new motherboard,pentium e5200 processor. existing hard drive ide seagate barracuda 7200.7 120 gbytes os windows xp
check the power supply: unplug the main connector from the motherboard,plug in the ac/mains power cord and switch on the on/off switch if any located on the power supply, locate the GREEN wire on the main connector that plugs on the motherboard, using a small length of wire insert one end into the plug where the GREEN wire is located and the other end into a BLACK wire on the connector. the power supply should power on if it is good: you will see and hear the fan turn on in the power supply. if it is good remove the wire and re-plug it.if it is not good replace the power supply. also check that the 110/220vac swithch is in the correct position for your mains voltage.do you have a floppy drive connected to the system? if so un-plug it and try again,re-check that you pluged the power button switch connector on the mainboard correctly,
Nov 19, 2009 | EliteGroup G31T-M7 Motherboard
Screen display nothing
change the screen.i think your screen crashed
Nov 13, 2009 | Compaq Presario R3000 Notebook
How to connect power supply to intel desktop board of d845wn
hmm strange question but you cant really get it wrong you plug the 20 pin conector from the power supply into the board then plug the little 4pin block which is on a diffrent cable into the little 4 pin block on the motherboard there all shaped to fit the conections so you cant get them wrong
Sep 24, 2009 | Intel Desktop Board D845WN Motherboard
MSI 1996 Motherboard: Power on Signal to PS staying high
check motherboard wire conector, make sure its not reversed
Dec 23, 2008 | Intel Motherboard
Need wiring diagram for emachines t2200 motherboard
If you are replacing the power supply and it has 4 pin 12v conector and your motherboard doesn't, just disregard the 4 pin plug. The 20 pin conector will supply sufficient power for the processor. Many of the older motherboards did not have a separate 12v supply for the processor.
Apr 18, 2008 | E-Machines eMachines Desktop PC
Open Questions:
See all Gateway MX8738 MotherBoard - DAPA6AMB6D5 Questions
Gateway MX8738 MotherBoard - DAPA6AMB6D5 Logo
42 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
