Question about Kenmore 24 in. 15933 Built-in Dishwasher
Top sprayer not turning
Hi -- our dishwasher has suddenly stopped cleaning as well as it had been. We see that the top sprayer is not turning, but it doesn't seem clogged and water is coming through.
There is a film on our glasses, water spots on dishes, bits of food that are baking onto the dishes -- usually it cleans beautifully.
This is a Kitchenaid dishwasher, model KUD1220T4
  • biddersweet5 Jul 31, 2008
    Did you check the rack? Ours have rusted out (same model) after 16 years of ownership and it makes the sprayer inoperable. No one seems to carry the racks so we need to buy a new dishwasher.
5 Suggested Answers
jbjaxiis
  • 95 Answers
SOURCE: kenmore dishwasher
Check the motor pump housing for an obstruction on the impellor. Impellors can go bad and not actually churn the water around the way they are supposed to.
Posted on Jul 06, 2008
mrswiff
SOURCE: film and food residieu remains on upper rack
Hi, is the wash arm underneath the upper basket turning freely and is it not blocked with any food particles? I've had items out of my dishwasher with a similar problem and it's been when the upper wash arm has been blocked or a spoon has fell through and prevented it from turning and washing properly.
Good luck.
Posted on Oct 04, 2008
heatman101
  • 43501 Answers
SOURCE: All of a sudden my dishwasher is leaving a white
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Posted on Mar 14, 2011
heatman101
  • 43501 Answers
SOURCE: The soap does not dispense entirely (the soap
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker
Wirl pool dishwasher is not cleaning top rack does not get enought pressure
Do you have multiple sprayers or only sprayer for water on the lowest level? If this is the case (only lowest level sprayers), look at how you're loading the bottom rack. If you are putting items that would stop the sprayers, like mixing bowls or casserole pans, that would be stopping the sprayers from hitting the top tier item.
May 23, 2012 | Dishwashers
I have a Kenmore dishwasher, purchased in 2000, it is not cleaning the dishes on the top rack, just happened all the sudden.
You should check to make sure that the lower sprayer is extending to spray the bottom of the top rack and that water is being pumped up to the top sprayer. You will need to take the dishwaher out of the cabinet to test.
Jul 15, 2011 | Kenmore Dishwashers
The top section wont wash clean
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. Then rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up.
I hope this works. If it does, please let Fixya know by rating my solution.
Dec 04, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
Top water sprayer not getting water. does not clean dishes on top shelf.
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Sep 06, 2010 | Kenmore Dishwashers
What would stop the sprayers from spinning freely, A bearing?
Plugged, take em apart and clean all the crud out of them, its alot of work but has to be done.
Apr 22, 2010 | Hobart AM14C-155 Dishwasher
We have a GE dishwasher with upper and lower sprayers. The upper sprayer (one located right under top rack) won't spray or turn which leaves the dishes in upper rack dirty, any suggestions on how to fix...
try c.l.r. to clean dishwasher check and clean lower and upper spray arms out, run no detergent you can also run vinegar in it as well about a cup full,let the machine start to run then stop dish washer for a few hours then restart see if this works for you use a short cycle.
Dec 01, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Top sprayer not working
Check and clean the filter inside at the bottom of the dishwasher. Make sure the spray arm rotates freely and that the holes are not clogged. If the dishwasher has a collapsable tower to shoot water into the upper spray arm, make sure it is not stuck and that nothing is blocking it from rising.
Sep 21, 2009 | Dishwashers
Spray arms do not turn. water to them but not
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 23, 2009 | Bosch 24 in. SGS43C12 Classixx...
My kenmore dishwasher model66516034401 does not
do you have a sprayer on top portion of dishwasher? if you do make sure it turns when dishwasher is running. check to see if holes in sprayer are open and not colgged up. you can clen it by pacing it in vinegar.
Aug 20, 2009 | Kenmore Dishwashers
Kenmore 24 in. 15933 Built-in Dishwasher Logo
60 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
