Question about Dell Dimension 3100 PC Desktop
I have an old (5 years) DELL PC with a CRT monitor. Of late the display has on the screen appears to be vibrating a little. This is causing eyestrain. The brightness, clarity & colours of the display are perfectly OK, which I think means that the monitor still has some useful life. Please advise.
  • Dell Master
  • 32,281 Answers
The monitor is probably faulty. To determine if the monitor or the video card is faulty, connect a different monitor to your DELL. If the image is OK on the other monitor then the other CRT monitor is faulty. Repairs to the CRT monitor may not be a cost effective solution, I suggest you buy a LCD monitor.
Posted on Feb 05, 2010
I have a 1cm verticle stripe on my Dell Studio 1737 ?
Your lcd screen is going bad. You can verify this by plugging an external monitor to your laptop. if the external monitor shows without the vertical stripe it means the video card is good but your old screen is bad. If the external monitor shows the stripe then it means the video card is bad.
Plug in an external monitor and see if thedisplay shows up on it. It can be any kind of monitor even the old big fat crtmonitors as long as it has a vga cable to connect to your computer's vgaport. If so that proves your video card is ok. The video will showon most systems when you reboot without you having to do anything. Some systemswill require you to hit the FN (Function key) + F1 thru F12. Hold downthe FN key then hit the correct key for displaying on the monitor (F1 thruF12). The correct key will normally have CRT/LCD on it or it will havethe icon of a display.
May 02, 2012 | Dell Studio 1737 (Studio 1737-RubyR) PC...
Monitor image is "posterized"...red,yello, blk and white only
you have defective RGB circuit, or re solder all CRT Board maybe you have lost contact at the RGB CRT Board. RGB means red, green, blue. CRT means Cathode Ray Tube.
Oct 08, 2007 | Apple Studio Display 17" CRT Monitor
I have a Dell 2007WFPb 20
If your LCD monitor displays your desktop fine as it boots up and then goes blank after a few seconds, but you can still faintly see your desktop then this may seem like a brightness issue but it's not. The picture displays very faintly, this is because the LCD backlighting isn't working properly. Which in turn is either because (most likely in cases like this) the inverter circuit has failed or the cold cathode tube has blown. If you're new to the electronics business and are not sure how to solder and connect circuits then this is the job for a qualified repair technician. So i suggest you head on down to your local PC store and have a technician take a look.
If you want to try it youself go here to order some spares.
If the monitor switches off and you can't see your desktop faintly then this may just be a power saving issue. Yo fix this check out my other tip here.
If your monitor is less than a year old then I suggest you take it back to where you bought it and have them send it in for repairs or swop it out with a new one. LCD monitors usually have at least a 1 year warranty sometimes it can even be up to 3 years if you register yours when you purchase it or if it's a really expensive screen.
If the monitor is a good 4-5 years old then it may not be worth fixing or may be too expensive. I suggest you invest in a newer widescreen option. LCD monitors have drastically come down in price over the years and you can easily get a wopping 23" for as little as $180.
Dec 14, 2011 | Dell 2007WFPB LCD Monitor
When i start my monitor the display comes very late.it is happening since last one year. i am using it very smoothly. Please tell me what the actual problem is. Model no DV992AB serial no....
If this is a crt(Cathod Ray Tube) monitor the older they get they sometimes take a little longer to warm up and get to a display.
Just age..
Aug 23, 2010 | Computers & Internet
I am experiencing a high pitched buzzing noise coming from the dell monitor #cn-0p0151-64180-3a5-3642
CRT monitors and TVs do this after some time. It is caused by high frequency alternating fields - think transformer - when things get old and loosen up enough to vibrate.
The good news is that it is time to upgrade to a modern flat screen monitor, and this will be cheaper than repairs on your old tube.
Dec 14, 2009 | Dell E773C 17" CRT Monitor
Dell laptop connected to 1209s projector...dell page indicates searching for signal and can't
Using the Display When you start the computer with an external device (such as an external monitor or projector) attached and turned on, the image may appear on either the display or the external device.
Press <Fn><F8> to switch the video image to the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and an external DVI monitor simultaneously, external DVI monitor only, and external CRT monitor and external DVI monitor simultaneously.
May 15, 2009 | Dell Latitude D800 Notebook
Bottom third of screen went black
Vertical section problem
change all caps in vertical sec and replace vertical IC
Oct 10, 2008 | Dell UltraScan 1000TX 17 in.CRT...
LG STUDIOWORKS 500g - FULL SCREEN NOT GETTING DISPLAYED
It's Loose contact Problem in Vertical section
Pl corrected dry points all over the vertical section.
Aug 31, 2008 | LG Studioworks 45 14" CRT Monitor
No lights or monitor
first of all you will to replace those buttons as its useless after few years. as per your problem is concern you might see some change after replacement. still it does not work then there is a video problem 1 crt filament supply less 2 voltage on g2 is less . 3 check voltage on video ckt to be normal. 4 crt base loose. 5 there might be crt weak if it is old. hope this will help.
Oct 06, 2007 | Acer AL1914 19" LCD Monitor
Check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Feb 05, 2007 | IBM E74 17" CRT Monitor
Dell Dimension 3100 PC Desktop Logo
75 people viewed this question
Alun Cox
