Question about LG Televison & Video
Fan speed changes so slightly it's hardly noticable. Is this normal?
    Brigadier General:
  • 3,006 Answers
You haven't stated which exact model, but yes, on many electronic devices the cooling fan speed is automatically controlled according to need. Most current flat panel tv's (except for ultra budget, old technology "no name" designs) incorporate this feature.
This cuts fan noise, prolongs fan life, and uses a little less power. Just make sure that the ventilation slots on the tv are not choked with dust, and on models with removable gauze filters make sure that you clean them every month or every week if it's a dusty environment. Removable filters are more commonly fitted to LCD projectors, but I've seen a few flat panel tv's with them fitted as well.
If the fan becomes especially noisy or stops altogether (some designs do allow the fan to stop for short periods though) then you must get the tv serviced as a failed fan is cheap, but an overheated tv can be more expensive to repair. They all have thermal cut-outs which usually put the tv into "protection mode" if the tv overheats, but fault diagnosis is usually faster and cheaper if this can be avoided. Much better to avoid letting it overheat to begin with.
Relax and enjoy your tv :-)
Posted on Feb 05, 2010
Hi, my toyota yaris engine fan was working well but since winter come its working slower than in summer.is it normal??
Most radiator fans have two speeds ( high and low ). Depending on engine temperature, the computer decides which speed to operate the fan at. This may be a normal situation and you may just be noticing the fan when it is operating at the lower speed
Dec 05, 2015 | Toyota Cars & Trucks
I NOTICED ON MY 2009 DODGE RAM 1500 4.7 THAT IT HAS TWO FANS ONE IN FRONT OF RADITOR AND THE OTHER ONE ON ENGINE WELL THAT ONE IS RUNNING SLOW EVEN IF I GIVE IT GAS SPEED DONT CHANGE IS THIS NORMAL
the one on the engine is probably a viscous type fan.It spins freely until the heat causes it to 'stiffen' up and assist in drawing heat off the radiator.Prior to this it is not needed and would only rob engine power and slightly affect fuel economy.Easy way to check if it is viscous,with engine off,just spin the blades.It should spin with a little resistance onlyThe electric fan on the radiator is switched on by a temp sensor or by using the air cond(unless it has another for this task).Hope this helps you.
Apr 11, 2011 | Dodge Ram Pickup 1500 Cars & Trucks
Blower only operates at full speed ; what needs to be done so it will operate at lower speeds?
you need to change a part on the blower syatem , that a resistor is mounted near the fan . that will give you the lower speed
Jul 26, 2010 | 1992 Honda Accord
I have an existing ceiling fan with a three speed controller. The low speed setting was too high so I have engaged an electrician to install a variable speed controller, Clipsal 32E500F Series. The new...
some manufacturer already attached a variable speed controller when you purchased them, meaning the unit requires this control, but in your case when you purchased it, it does not have any, meaning they sell it to the market as ready to use, so why install additional control?
There might be an installation error during the assembly, so all you have to do is just interchange the wire connected to the control from LOW, MEDIUM and HIGH, it is a trial and error thing but it won't affect or damage your unit, maybe your high speed connection was connected to a low speed control, so just inter-change it. Remove the variable speed control
Nov 01, 2009 | Aloha Housewares (93645) Ceiling Fan
I have a 2004 MPV with 88k miles on it that feels as if it is missing when I drive. When I am stopped and it does this I notice a slight drop in RPM's. In addition the engine cooling fan is not running at...
The cooling fan turning on will normally cause an amperage draw making the engine drop in rpm's. However I beleive there may be a problem with the fan relay which switches the fan on at different speeds depending on the temperature demands of the engine.I dont beleive a bad relay will come up as a code because it's not a sensor.
Sep 14, 2009 | 2004 Mazda MPV
1997 Suburban 4x4 5.7L Transmission whines until it shifts
You rear planetary set is worn from a restricted cooler.
May 06, 2009 | 1997 Chevrolet Suburban
Car overheating
fan relay or fan motors also try the fan fuses
Oct 06, 2008 | 1999 Chrysler Concorde
Fan louder than normal
Sounds like whoever did the txv, changed the fan speed. Yes, the fan speed is adjustable. Some HVAC units can have up to 4 speeds on the motor. Low, Med Low, Med Hi, and Hi. this is so the same unit can be used for several different cooling coils and tonage. The faster the speed in the cooling mode, the less cool the air will be.
Sep 29, 2017 | Carrier 38CKC036 Air Conditioner
Main cpu fan high speed
the speed of the cpu fan will go up and down depending on the work load that your pc is going thru,lets say you start a game and the speed increases then drops down thats all normal
Oct 06, 2007 | ASUS 865G (MBAS-P4P800VM) Motherboard
Televison & Video Logo
49 people viewed this question
Computer Repairing
Computer Repairing
