Question about Stainless Patio Heater - Steel Outdoor Table Top
The gas bottle is on and but there is no gas getting to to the patio heater.
  • 73 Answers
Regulator maybe frozen if its cold there. if so take it off and thaw it out inside for awhile, no hot water om it only creates more issues later!! if you are hooking it to a BBQ tank that has a new Qcc1 valve you have toopen the valve on the tank very slow when you have it hooked up or it slugs off. hope this helps, you also may have a blocked pilot orifice or other issues hard to fix without seeing it and little info..
Posted on Feb 09, 2010
How is the propane fitted to the heater
In the heater base should find the gas hose with the gas valve on the end. Plug on the valve on the propane bottle and turn it on.
Nov 05, 2010 | Endless Summer 1501 Patio Heater
I need to replace my patio gas bottle...
always remember the threads are reverse on a gas cylinder and you are likely tightening this joint if your going the wrong way. some also have a quick disconnect and are like an air chuck and should be removed this way.
May 31, 2010 | Grilling
I have a Gasmate patio heater ph 900 that won't ignite
Before you take it apart, try replacing the hose and regulator, easy to do and inexpensive. If that does not work, you will need to take the heater apart to get to the pilot orifice. The orifice is very small and easy to get clogged up. If the igniter sparks, then it is most likely a gas flow problem.
Apr 30, 2010 | Heating & Cooling
How many hours can I get from a 20 lb. propane tank on a Pro com 45,000 btu patio heater?
approx 380000 btu in bottle
380000 / 45000 = 8.44 hours running on full.
Oct 06, 2009 | Procom DPL400HA Patio Heater
Coleman 5040 Patio Heater w/ Light - Light works, Heater does not
BE VERY CAREFUL sticking matches in any propane appliance! With the gas OFF see if you can physically see the spark when you push the ignitor, if yes, the problem may be the regulator or bottle pressure the only test i am aware of for the regulator is replacement.
Jul 13, 2009 | Coleman (5040B750) Patio Heater
Unit will not light
you probably have a clogged pilot assembly or pilot tubing this is usually an aluminum tube that runs to the sparker try to pullit apart and clean it
Jul 05, 2009 | Uniflame 233000 Open Flame Patio Heater
Napoleon PTH10PSS Infra-Red Patio Heater
If you have a piezo ignition, then all you will hear is one click when you turn the knob. If I am guessing correctly, when you push in the knob and turn it, the gas flows to the pilot assembly, when you turn the knob far enough it will clilck and that sends the spark to the pilot assembly to light the pilot. Try turning the knob slowly before you get to the click, that will allow more gas to flow to the pilot. If this does not work, then you may have a blockage in the pilot.
Jun 29, 2009 | Napoleon PTH10PSS Infra-Red Patio Heater
Patio heater
There must be a blockage in the hose and regulator or your large tank may be checking and not allowing the unit to stay lit. Remove the large bottle. Let the gas line equalize for about 30 seconds and then reattach the bottle. Very slowly, open the knob on the large tank and I mean very slowly. Did I say open it slowly. The new OPD propane tanks often have a very touchie excess control valve that won't allow enough gas through if opened too rapidly. Now tray and light the heater. If you still experience the same, get a technician involved so they can inspect the gas pressure.
Oct 23, 2007 | Heating & Cooling
Heating & Cooling Logo
118 people viewed this question
Top Stainless Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Stainless Heating and Cooling Expert? Answer questions, earn points and help others
