Question about Furuno Sc 50 Satellite Compass
Hi, i have installed Furuno antenna unit SC-303, processor unit SC-501, and display unit SC-502. the problem is the heading randomly changes between 4-6 degree even when the vessel is in stationary position. tried to change the processor unit and antenna unit with spare but the problem persist.
  • John Barry
    John Barry May 11, 2010
    This sounds like maybe you have 2 data steams feeding your display.
    Troubleshooting this would require a complete explanation of attached devices!
3 Suggested Answers
TechnoMarine
  • 132 Answers
SOURCE: furuno radar antenna not rotating
yes, this is a common failure after hours and hours of use
Posted on Jan 13, 2010
MNfisherman
  • 11896 Answers
SOURCE: hello i have an furuno
Yes they are soldered in. They have a hot glue on top. You can heat up the glue and scrape it away. Then heat up the solder and remove the batteries and place new solder on the new battery terminal connections
Posted on Sep 19, 2010
Antenna GPS Tram 1655 is compatible with GPS FURUNO?
If the Furuno unit you're referring to uses a GPS antenna with a coax (i.e. GP31/32) then the Tram antenna will work but the connector is wrong. The Tram antennas usually come with BNC connector and Furuno uses a TNC. Will need an adapter.
Oct 14, 2013 | Furuno GPA019S GPSDGPS HField Antenna...
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Does my furuno GP32 have an internal antenna or do I need the to install the extra one?
Hi!
Your Furuno Does NOT have an internal antenna. You have no choice but to install the external one.
Hope this helps.
Jan 27, 2011 | Furuno GP32 GPS Receiver
Furuno GaAs FET Front End 4 Tone Daylight Display - when closing the DC breaker for the rada unit, the 10 amp fuse blows. Don't have a schematic. Don't know the model number. There are no data nor...
unplug the radar from it and turn on the display. If that does not blow the fuse, then your problem is either in the cable to the antenna or the antenna itself. Start there.
Nov 10, 2010 | Furuno 1715 LCD Radar System GPS Receiver
1942 mark2 has power to display but no rotation on screen. Head unit turns.unit has worked for years and all of the sudden quit.check fuse and is ok
To be check the Fuses:1)for antenna ,2)for modulator unit
that are from 4amps until 7amps slow blow
rgrds
Grigorios
May 19, 2010 | Furuno 1942 Mk2 Radar
Furuno 1942Mk2 Problem
it cannot determine a heading, have you also damaged an internal antenna or positioning / gps device inside it? It is unsure which direction it is pointing in but uses triangulation to determine this.
That requires either an electronic compass unit, or gps to achieve correct heading and hence correct orientation of the radar image
Nov 14, 2009 | Furuno 1942 Mk2 Radar
My radar displays all contacts reverse. How do I get the display reversed? model #1731
I agree with Nico-Fixus, the heading alignment is one of the things to be checked. Unless this is a new installation it is unlikely that the Radome (antenna) got removed and reinstalled facing the wrong way. So antenna orientation would not be a concern.
I have seen units that for some reason the wrong Radome was selected in the configuration of the Navnet display.
Read the model number on the Antenna, then check that correct antenna type in loaded in your display.
Oct 22, 2009 | Furuno Navnet 1732 GPS Receiver
Furuno radar antenna not rotating
Apr 06, 2009 | Furuno 2.2kw 18" Radome
Furuno 1623 Radar reading "no heading pulse"
The messages “NO HEADING PULSE” and “NO BEARING PULSE” means that the display is not communicating with the scanner (antenna). Both of these signals are generated in the scanner if you get this error check that the antenna cable is firmly connected and that the contacts are clean and corrosion free.
If the connection at the display looks good and feels like it’s properly connected, check the cable for any damage If you find damage you could try to repair the wires BUT (because of corrosion and moisture problems) IT IS STRONGLY REMENDED that the cable be replaced, but it’s kind of expensive $275.00.
The Part number is 000-130-034. Depending on the marine shops in your area they may have it in stock (or they can order one) but you can get it directly from Furuno at;
http://www.furunousa.com/Furuno/Rooms/Search/ProductPropertySearchResults?_webrFormIdentity=com.webridge.layout.FormLayoutExImpl%5BOID%5B47F81E95CB197F4C8708859EA0E22F08%5D%5D&_webrFormUniqueID=0&_webrCharacterEncoding=iso-8859-1&_webrLocale=en-us&_webrClusterUpload_2=&ptype=com.webridge.entity.Entity%5BOID%5BE670694808555649838ED263AA4CAB0A%5D%5D&productname=000-130-034&searchOption=normal&searchOption_webrHidden=radio
I hope it’s just a loose connection. Good luck!
Apr 28, 2008 | Furuno 1715 LCD Radar System GPS Receiver
Installation furuno GP7000F/NT
This unit has built in sonar, so no DFF1 is required. The 1KW transom mount is in stock here, with the proper Furuno 10 pin connector. That is all you need, the display, the power cord, the GPS antenna, the transducer and THE BOOK! We are a Furuno dealer in the Great Lakes
Mar 03, 2008 | Furuno GP7000F/NT GPS Receiver
Furuno Sc 50 Satellite Compass Logo
252 people viewed this question
Top Furuno Boating Experts
Daniel Dollive
Daniel Dollive
Colin Stickland
Colin Stickland
David Burbee
David Burbee
Are you a Furuno Boating Expert? Answer questions, earn points and help others
