Konica 1212 again!
Hello again, thanks for previos advise. I manged to do "47" 51 check and now error code F26 comes up which I thinks is about the Toner again. any Ideas how to deal with this , thanks again, Martin
  • 86 Answers
Try "47" 51 it is possable to try the set up run again before but wait until the machine finishes its cycle if you still get F26
replace the deveolper.
Thank you
Posted on Feb 20, 2008
Am wale n base on konica marchine as an eng bt dis f26 always bein a problem on 1216 n 2223 why
Posted on Mar 04, 2012
What does f26 mean for siemens washing machine
F26 come up This error code indicates that the door needs to be opened and closed.The F26 code may appear the first time you try to use the washer. Open and ...
Jan 03, 2016 | Siemens Washing Machines
When I turn it on, why does it show 'error f26-1 call service'?
Your fuser is the issue the hot part (Fuses the toner to the paper)
To clear you going to do the following (DO this once if the code comes back fuser is bad have a tech look at it, if you reset again it may catch on fire!!!!!!!!!!!!!!!!! That will ruin a perfectly good day !!!!!)
Turn of the machine now hold down the 2 and the 5 button and turn on the machine you hold them both down until a screen show up with several icons, then select the soft switches, Then you will a 3 in the first box, then a 1 in the middle box then a 1 in the third box. then exit then power off the machine wait ten seconds then power on regular. if the code comes back get a tech out to check the fuser, do not reset again the fuser can catch on fire that will ruin a perfectly good day.
Oct 24, 2015 | Konica Minolta Minolta 7130 Laser Printer...
Konica 1212 copies to dark
1st the basic cause of dark/grey copies DUST. Clean w/ alcohol cloth then dry cloth totally all mirrors and the platen glass both side. If still dark check the "Optic slit " right in the upper of your halogen lamp remove it, still dark Check your halogen lamp maybe it already oxidized. The last solution adjust the CVR .
Nov 27, 2014 | Konica Minolta Konica 1015 1120 1212 Toner...
F26-1 error code
this is a toner density sensor error try replacing the toner density sensor
Dec 06, 2012 | Konica Minolta DF314 ADF Double Feed...
My maytag commercial washer display a code F26
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Oct 23, 2012 | Washing Machines
Error code F26
If opening and closing the door does not remove the error display, press Pause/Cancel twice
Oct 22, 2011 | Whirlpool WFW9200S Front Load Washer
P27 error keeps coming up on a Konica 1212
Run 47 mode output code 51 until the unit does not reoccour may take 5 to 10 attemp,
b. poor conection at cn95, reconnect cn95 located under the front of developer
Jan 02, 2009 | Office Equipment & Supplies
Code f32, f26
f 26 is for toner denisty sensor .just clean this one.f 32 is heater unit problem temperature of heater unit is very high.just reset it by 25 mode code p 47 set it to 0..'press 2 and 5 key before power on copier u will enter in this mode.by mian jee
Dec 15, 2008 | Ricoh Aficio 1013F Copier
Error code F35 on my konica 1212 photocopier
That's a fuser error condition...I'll have to get back to you because i have to check in my book to remember how to reset it...Thank you for your patient !
Mar 19, 2008 | Office Equipment & Supplies
Error code 27
The error code p27 the toner density sensor unplugged/dirty/faulty
Any problems please get back to me
thank you
Feb 19, 2008 | Office Equipment & Supplies
330 people viewed this question
jasbo
jasbo
