Question about AOC 5 En 15" CRT Monitor
My Monitor turns off and on. I can here the relay
My AOC CRT 5en colored Monitor turns off and on. I can here the relay switch switching. I defenitely know how to use a soldering iron but... I'm have some trouble trouble shooting Could it be the relay switch or what? Can somebody help with my problem. Thanks in advance ^^.
  • maxeemaxee Feb 05, 2010
    @ Sebin
    I don't think so Sir. I mean... I don't think thats the solution cause I replaced the defective monitor with a known good monitor and it worked. The problem stays at the first monitor. I think the problem is not in setting, coz I tried the defected monitor on other unit(CPU) but results the same problem.
  • 712 Answers
I think it's the refresh rate.
In XP:
Right-click, properties on the desktop
Select settings tab
Hit the advanced button
Select the monitor tab
hit the box (hide modes that this monitor cannot display)
Select a new screen refresh rate
hit ok twice.
Posted on Feb 05, 2010
  • Sebin Punnacheril
    Sebin Punnacheril Feb 06, 2010
    Then you should replace your monitor i think.
Need schematic diagram for AOC 5 En model (white 15 inches color monitor) - thank's
my AOC crt monitor 5En model has this problem. it has over width the compress button (<> ) is no longer functioning what particular component should i check or adjust inside the circuit? please i need ur help..
Nov 21, 2009 | AOC 5 En 15" CRT Monitor
AOC color monitor 15in. 5En model. during power on all led lights functioned and no display was observed
u try to reorient ur vga connection it might be a loose connection between ur monitor and ur cpu otherwise ur vga cable is defective...
Nov 02, 2009 | AOC 5 En 15" CRT Monitor
AOC color monitor model 5En...during power on all led lights blinks then stops blinking without display action. all led lights on no more action observed.
actually if u repair an aoc monitor alone without getting connected to cpu once u switch on the monitor all led's will lit on ( green light ) it will remain on situation until u connect the vga connector to cpu that's the time led's will lit off and only the power led will remain in green condition.some aoc 5en once u power on power led is in green condition and if not connected to cpu it will be in orange condition.hope u get some idea but i am not sure if it will work with ur monitor. but as long as LEDs lit on i think no problem with ur monitor.
My AOC 5en CRT monitor have a horizontal line whole screen... how i fixed it?
this is called hline problem. only a thin line is seen in the screen and the screen is black. the cabinet needs to be opened then it needs slight setting from the picture tube to get the whole picture.
Sep 05, 2009 | AOC CT720G 17" CRT Monitor
I Want to know ,what is the code of R939
Try this:
http://www.eserviceinfo.com/downloadsm/35768/AOC_CT700g.html
Aug 09, 2009 | AOC CT700G 17" CRT Monitor
No power dead set 5en aoc monitor
just try to change the horizontal transistor C5386 or CXXXX... with a new one....
Feb 22, 2009 | AOC 5 En 15" CRT Monitor
AOC 53N PROBLEM
DO YOU KNOW HOW TO SOLDER. IF SO, TRY TO OPEN THE MONITR AND LOCATE THE VERTICAL SECTION AND YOU WILL FIND LOOSE SOLDERS. A SINGLE HORIZONTAL LINE MEANS THAT THERE IS A PROBLEM WITH THE VERTICAL LINEARITY OF YOUR MONITOR. FIND SOMEONE WHO KNOWS HOW TO FIX COLD SOLDERS
Aug 06, 2008 | AOC 5 En 15" CRT Monitor
Having a form of glasshour display
yes i have repaired my AOC 5En 15" CRT monitor diode # Diode 406 or check IC401,Q404,Q405,Q406 or visit my site for symatic diagram
Jul 12, 2008 | AOC 5 En 15" CRT Monitor
Aoc 5en no display
I alreeady encountered this problem. I fix it temporarily.... I just turn it off, Press all the Function btn and the recall btn, then pres the On btn... wait for 2 sec then release the func, recall btn. Then I already able to use the PC for about o hours without interrupted signal (on/off). I call it temporary fix because whenever you turn off the Monitor, you have to do the same process again..
Try it it can help.. Thnaks.... If you already find solution , maybe you can share it to me too .. Thanks..
Jun 25, 2008 | AOC 5 En 15" CRT Monitor
AOC 5En monitor
replace new moitor....
Nov 13, 2007 | AOC CT720G 17" CRT Monitor
AOC 5 En 15" CRT Monitor Logo
299 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
