Question about Cell Phones
Need code entry mode for alg 290cm - Cell Phones
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You’ll need to dial *228 and push 1. Now wait until it is reset and the new password should be 0000 or the last 4 numbers of your mobile number.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 05, 2010
M phone wont call out.. it has a constant dial tone ..can you help me?
Might be a firewall setting in your router. See if you can change the SIP ALG setting. If it is off, you need to turn it on.
Here is a site that will help you identify the SIP ALG in your router:
http://www.nextiva.com/support/how-do-i-identify-sip-alg.html.
May 31, 2015 | magicJack Plus
How do i get the ALG below the numbers to go away?
Your HP 12c Platinum is in Algebraic mode. To switch back to RPN mode, press f then CHS.
Oct 15, 2014 | HP 12c Calculator
How do you clear RNP for an HP 12C
I take it you mean a 12C Platinum.
Press f ALG. ALG is the f-shifted function of the EEX key, just above the double-size ENTER key. This will switch the 12C Platinum from RPN mode to Algebraic mode, and ALG indicator will light up instead of the RPN indicator.
To switch back to RPN, press f RPN. RPN is the f-shifted function of the CHS key just above the EEX key.
Apr 23, 2014 | HP 12c Calculator
HP12C - get rid of RPN
Press f ALG to switch to the Algebraic mode.
ALG is the shifted function of the EEX key.
Mar 17, 2014 | HP 12c Calculator
I'm in RPN mode, how do I get out of RPN mode?
To switch to the algebraic mode press f [ALG] (the EEX key).
Dec 08, 2011 | HP 12c Calculator
WHY DOES MY LG 290CM HAVE THE WORD "HOME" AT THE
This option lead you to acces inetrnet facility
Nov 11, 2010 | LG Cell Phones
It just says prepaid service disabled i went into code entry mode on my safelink tracfone
MY CELL FROM FROM THE STATE SAYS I NEED THE CODE ENTRY MODE SERICE DISABLED
Sep 08, 2010 | Cell Phones
Ok i have a lg 290cm straight talk phone and i need a code for my phone's code entry mode
try the last 4 digits of your phone number, if that dont work try 1234 or 0000, i found mine to be the last 4 of my phone number
Dec 17, 2009 | Cell Phones
1999 lincoln con
SECTION 501-14B: Keyless Entry/Computer Operated Locks 1999 Town Car Workshop Manual GENERAL PROCEDURES Programming —Keyless Entry Keypad Code
  1. Enter the permanent factory keyless entry keypad code.
  1. Press the 1/2 button within five seconds to activate the programming mode. Holding the 1/2 button for more than two seconds will erase all stored customer codes. The existing codes do not need to be erased to program new codes.
  1. Enter the new five-digit keyless entry keypad code.
  1. To associate the new code with personality positions 1, 2 or 3, press the 1/2 button within 5 seconds of entering the 5th digit of the new code for position 1 or 3/4 button for position 2 or 5/6 for position 3. The door locks will lock and unlock confirming the new code is programmed.
  1. If another code is to be programmed, begin entering the code within 5 seconds of the last button pressed.
  1. After all new keyless entry codes are programmed:
    • Press keyless entry keypad buttons 7/8 and 9/0 at the same time to exit the program mode.
    • Wait for 5 seconds; the driver door module (DDM) will exit the program mode automatically.
Programming —Transmitter
  1. Cycle the ignition from OFF to RUN four times within three seconds. The locks will then lock and unlock, confirming program mode has been entered.
  1. NOTE: When the first keyless entry remote transmitter is programmed, all other keyless entry remote transmitters are erased.
    Press any button on the transmitter to be programmed.
  1. If additional keyless entry remote transmitters are to be programmed, repeat step 2 within 7.5 seconds.
  1. To exit program mode, turn the ignition to START or wait 7.5 seconds.
Programming —Remote Memory Activation NOTE: This procedure must be completed within 5 seconds.
  1. Press the SET button on the driver door panel.
  1. Press any button on the keyless entry remote transmitter to be associated with a memory setting.
  1. Press the 1 or 2 memory button on the driver door panel.
Programming —Autolock and Horn Chirp
  1. NOTE: This procedure must be completed within 30 seconds.
    Turn the ignition switch to RUN.
  1. Press the UNLOCK button three times.
  1. Turn the ignition switch to OFF.
  1. Turn the ignition switch to RUN. The doors will lock and unlock to confirm entry into program mode.
  1. Press the UNLOCK button once to toggle the Autolock feature on or off, or twice to toggle the Horn Chirp function on or off. The horn will chirp to confirm toggling of the Autolock feature.
  1. Exit program mode by turning the ignition to OFF, START, or wait 7.5 seconds.
Apr 07, 2009 | 1999 Lincoln Town Car
Cell Phones Logo
42 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
