Question about Toshiba 42H81 42" Rear Projection Television
Vertical hold wavy then no picture and power lite flashing
No picture power lite flashing when plugged in. at first vertical hold wavy then warm up and picture would stablize
  • the Broz Feb 23, 2008
    toshiba projection tvs require repair more often than their tube tvs
  • Anonymous Mar 14, 2008
    Same thing has happened to ours. Do you know what the estimated cost is to get this resolved?
    Sergeant:
    Champion:
  • 301 Answers
You are probably having 2 problems. on that model there was a jumper wire the fed the convergence amps power and would get very bad cracked solder. and casue some fuses to open on the main deflection board. if that is there i would recomend replacing the 2 convergence amps(stk392-110) and open fuses. but your wavy lines are going to be all the 10mf16v surface mount capacitors inside the hyperunit(figital scan card) it is a square metal case located behind the input board.*****it is soldering in with 4 tabs on the bottom side of the signal board so be careful not to just start pulling on it to get it out*****
Posted on Feb 21, 2008
24af45 from top to bottom picture is wavy until set warms up
Check and replace all the electrolytic capacitors at its vertical scan output stage circuit. Replace all of the once.
Apr 04, 2013 | Toshiba 24AF45 24" TV
Hitachi 50UX11K wavy pic
Since the comb filter is discontinued is will be best to bypass it by using the S-video input especially if you are on satellite receiver or use a composite to S-video adapter if you don't have dish. You might get the adapter at Radio Shack or shop online at Circuit City or Best Buy
Jan 01, 2008 | Televison & Video
Mitsubishi VS-4543
is that wavy in vertical motion? and bending?  in that case maybe you have low voltage in your power inlet! or can you specify the color of wave and motion, if horizontal or vertical?
Oct 16, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Sony trinitron KV-32HS510 has vertical hold problem
It could just be a resistor or two ,
check for Vert Oscillator Circuit & AGC
Jul 27, 2012 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Mitsubishi WD5725 DLP set. Picture is Ok before
The set has over 150 capacitors that could be causing the problem but it is at least 1 doing this. Contact Mitsubishi. Some people have been able to get new replacment TVs because of this problem
Mar 04, 2010 | Mitsubishi Televison & Video
About two months ago when we first turned on the TV there were wavy lines across the whole picture. When it warmed up they would go away. Now, the lines are there almost all the time and it's getting...
hi
You are experiencing a lack of vertical deflection or vertical collapse. Since it will come back the first thing I would suspect is “ring cracks” in the solder joint in the vertical circuit, mainly the vertical IC. These suspect solder joint can be re-soldered and the television set repaired.
I would suggest that you contact a local servicer. If you are repairing the set yourself, be careful, there is always a risk of shock when dealing with electronics.
OR
Check your equipment connections. Disconnect your equipment (VCR, DVD or set-top box) from the TV and reconnect, making sure each connection is in tight.
OR
chek this site,i blieve u will b helpfull
http://www.dshosu.com/how-to-fix-toshiba-rear-projection-hdtv-wavy-lines/
regards
Jul 01, 2009 | Toshiba 57H82 57" Rear Projection...
Wavy picture for Toshiba Model 50H12 Rear projection TV
In general, these problems are usually caused by leaky output filter capacitors in either the low voltage power supply or, depending upon the type of waviness you're attempting to describe, it could be in the vertical deflection circuits (either the vertical oscillator or vertical amplifier). I would estimate cost to repair from $200 to $350 dollars, depending on how long it takes to find the problem. It most likely though is a component issue in the circuitry.
Dec 28, 2007 | Televison & Video
Picture Jumps/flashes for first 5 minutes
There is a module called a hyper board that is vertically mounted near the jack panel. Inside the module are 10mf/25v capacitors they are grtting weak. The module is fully shielded and pluggs into a socket. the module has 4 tabs (2 on each end) that must be unsoldered before it can be unplugged. This repair should be done by a qualified technician. The caps are surface mounts and very small. Unless you have excellent soldering skills and a rock steady hand DO NOT ATTEMPT to repair this problem on your own.
Nov 16, 2007 | Toshiba 57H81 57" Rear Projection...
I had the same problem and followed the instructions from Jack and my 57h81 is bak up and running. Thanks Jack. RonD
Jul 02, 2007 | Toshiba 36HF72 36" TV
Toshiba 42H81 42" Rear Projection Television Logo
66 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
