Question about Sony BRAVIA KDL52XBR2 Television
Sony bravia intermittent sound
My TV was working fine the night before, when I turned it on this morning there was no sound except for the occasional breakthrough of sound. I have unplugged/plugged in the audio out cables several times with no fix. Any advice would be very much appreciated.
  • Anonymous Oct 12, 2008
    I have the same problem with my Bravia 52". I simply shut the TV off and turn if back on and it seems to correct itself.
  • Anonymous May 03, 2009
    My Bravia KDL-40VL130, about a year old now, drops audio for a second or two every few minutes when in HD from the cable box. This is the second one (from Costco) that had audio probs. The first one, out of the box, had no audio when in TV mode. Costco replaced it but here we go again...What is SONY doing for owners about this? Any fixit ideas?
Yep, same problem with mine. After many trial fixes, I discovered that it's the HDMI connection. I tried two different new HDMI cables in two of HDMI ports on the TV, but still got intermittent sound. The only way I solved it was going to component cables (RGB) with a separate audio cable. Works great now. Other Web sites say that HDMI connections do not always electronically "handshake" well between devices. Not sure how this HDMI problem can be permanently fixed, but using the component connection works fine.
Posted on Apr 30, 2008
Had same problem. I agree it's HDMI problem in HiDef only. Switch to a non hidef channel and back again...will work fine
Posted on Oct 13, 2008
Bravia TV has pink screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 01, 2015 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
Sony BRAVIA KDL-40V2500 audio not working
I would Google the model number carefully for "problems" "no sound" and usually this set will display some kind of error code===it may even have a hard reset to try===service manuals are available on the net/web to allow you to see how the sound circuit is set up etc.
Mar 29, 2012 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
My 46" SONY LED has no sound coming out now.
Hi this sounds very much like a dry or bad solder joint probably on the power supply PCB, if you have the necessary soldering skills and a magnifying glass you maybe able to fix this yourself.
The picture below shows an example of what a dry joint(s) looks like, if you are able to solder and understand the risks in taking apart your TV you could save yourself a good few bucks!
Always make sure the TV is unplugged and please be aware that voltages can still be stored even when the tv is turned off, if in any doubt or you are unsure about attempting a repair please consult a qualified TV technician.
Hope this helps
Midge.
Feb 10, 2011 | Sony BRAVIA XBR46HX909 46 in. 3D HDTV
Sony Bravia was working fine last night and when I turned on this am nothing. The light is not on and the set won't turn on. The cable box plugged in the same strip works but the tv won't turn on. Not even...
Try unplugging set for approx 5 minutes or so, cross your fingers and re-try. Other wise sounds like power supply board failure. Some shops repair the boards others replace them
Jul 03, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony BRAVIA sound cuts in & out
Go to Sony website and download the newest firmware for your tv
Jun 09, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony Bravia 46S2010 no picture only glows but, only sound on
sound like you had problem with the lcd display panel. The Tcon had problem that attack to the panel.
Mar 07, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No picture nor sound
I off my TV and remain it off 4 the whole night in the morning when my husband on in from a main switch it started working properly with no problem. A thanks alot for your replay.
Mrs Saimazeb
Mar 06, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sound problem
check the menu on the tv to see if the speakers are set to off
I think if you connect it to external amp the tv's speakers must be shut off beofre it will activate the line out audio
Nov 05, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
SONY BRAVIA KDL-40S2010 40"
Mine isnt even 1 year old and same problem. was fine last night, woke this morning, turned it on and there they are green and purple
Apr 08, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony BRAVIA KDL52XBR2 Television Logo
1,248 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
