SOURCE: temporary overload
hi, Ok u do one thing just remove the memory card from ur mobile & give a code *7370#..it will do hard reset on ur mobile..so before doing that just save ur cntcts & all as they all will be delted if they r in sim memory. Thanks Gizmo1
SOURCE: problem with nokia 6600 is turning off automaticly
maybe the themes did not fit your phone.try other themes or try to format you MC then install the themes back or try install fileman and by using this you can check anything that you install..hope this help..
SOURCE: nokia 6600 doenot show the missed call and message standby mode
format the fone by
typing *#7370#
or
press power button,without releasing it press
green, *,and 3
after a few seconds a the default screen will appear.thats it..u just formatted ur fon .
now you can enter the default code which is 12345
SOURCE: farmating mmc card for nokia 6600
TRY TO REFORMAT YOUR MEMORY CARD USING PC THEN REFORMAT YOUR NOKIA 6600 PHONE USING THE HARD RESET CODE.
***NOTE THAT REFORMATTING YOUR SYSTEM WILL LOSS ALL DATAS AND FILES
SOURCE: Where do i have to insert the memory card in Nokia 6600?
Hi and welcome to FixYa,
The SD memory card is inserted underneath the battery below the SIM card. The same lock the holds the SIM card also locks the memory card.
Good luck and thank you for using FixYa.
hi,
Thanks
Gizmo1
