Question about Refrigerators
Looking for year model of this fridge... SJ-W39J-WH
3 Suggested Answers
  • 1122 Answers
SOURCE: need two trays for sharp
go to sears .com,click on parts,put in your model number get your part,cross check the price at repair clinic .com-mike
Posted on Nov 11, 2008
  • 12 Answers
SOURCE: IFrost Free Sharp Refridgerator & Freezer-Fridge not keeping cold
You have a defrost problem. You need either the defrost timer, defrost heater, or the defrost bi-metal. If you have a meter you can ohm out the heater and the bi-metal ( as lonh a s the bi -metal is frozen as it opens when it gets warm to cut out the defrost heater) if you have an ohm reading on either one of the two the replace the defrost timer, if you don't then replace the part that has no ohm reading.
Posted on Sep 14, 2009
Our sharp fridge/freezer model SJ-45F-WH ISNT GETTING COLD IN THE FRIDGE. THE FREEZER IS WORKING PERFECTLY.WE HAVE TURNED IT OFF FOR A FEW HOURS AND TURNED IT ON AGAIN. THAT WORKED LAST TIME.Not now.
If your freezer is full of food move everything about an inch away from the back wall. This should let the air flow better the fridge gets its cold air from the freezer. So you have to make sure your not blocking the vents.
Nov 03, 2016 | Sharp Refrigerators
Sharp Fridge is collecting water under veg compartment
Drain Try is full with water its fix on compresser. Empty Drain try and try.
Jun 26, 2012 | Sharp Refrigerators
I am considering buying a sharp bottom freezer refrigerator (SJ-F78SP). I want to know if there is any problem with the cooling or the auto defrost system. I had a panasonic bottom freezer refrigerator...
I would not buy a Sharp refrigerator. They make decent TVs, but I would be cautious purchasing a fridge. But something american like GE or Whirlpool. It's just my suggestion.
Feb 23, 2011 | Viking DDBB363 Bottom Freezer Refrigerator
Our Sharp refrigerator model SJ-F60PC. 4 doors, freezer at the bottom and fridge at top. The fridge section is not cold although the freezer section is working fine. Much appreciated if anyone can help!
Your defroster timer switch may be at faught. The defrost timer turns on a heating coil to defrost your frige. This is only a guess since I don't have the year. Do this: feel the walls if they are hard and they have no give to them, then your fridge is frozen up solid and no air can circulate. Unplug you fridge for 24 to 36 hours. Put towels on the floor to catch the water. If the defrost timer is bad it will defrost naturally with room temp. Plug back in after 24 to 36 hrs and see if bottom is now getting cold. If it is the defrost timer, the solution is not cheap. It's up to you to repair or invest in new. Good luck Google burdfrenzy
Nov 26, 2010 | Refrigerators
hello sir/mam
please check the blower of the refrigerator if this is not working the refrigerator wont get cold.
Sep 14, 2009 | Refrigerators
Need two trays for sharp sj-25j-wh
Nov 11, 2008 | Refrigerators
Sharp SJ-42-WH self-defrosting fridge. Freezer works fine, but fridge doesn't cool down - no airflow to fridge. 1. Damper working perfectly and not jambed in closed position. 2. Fan working...
I recently had exactly the same problme with this model refrigerator. I found the problem to be the defrost timer. It is located behind the panel on the back of the refrigerator where the mains cord is located, you will need to replace it with the exact same model. I am in Australia and managed to find the exact part on ebay cheaply from a local appliance parts supplier, any appliance parts supplier that deals in Sharp refrigerators should be able to help you.
You will have to defrost the refrigerator overnight again before doing this repair.
Of course there are a couple of other components that could cause this problem, you can acutally check to see if the defrost time is moving by taking note of it's current position and then checking it every thirty minutes or so. If it does not move then it could be faulty, make sure also that power is getting to the timer as well.
Sep 26, 2008 | Refrigerators
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
