Question about AOC 5 En 15" CRT Monitor
I need a schematic diagram for my AOC Colored MONITOR model no: 5 en. Can somebody lend a hand?
  • Kishanaghera May 11, 2010
    model 1445 sr98j417837 hori zontal out out transistor demeg
Go to www.schematicdiagram.com
Posted on Apr 22, 2010
Backlight inverter aoc lm729 Schematic diagram Please I am a repair technician (Retired) Lcd layer working picture on screen backlight goes off intermittently and now for almost all of time. Flashes...
Here is the service manual: http://elektrotanya.com/?q=showresult&megnev=AOC%20&megnev2=LM729%20&kategoria=&kat2=all
You will need test lamp to verify if it is the inverter or the lamp assemblies.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 09, 2010 | AOC LM729 17" LCD Monitor
AOC color monitor model 9g1rs, dead, ** volt, fuse good
Hi
You need to replace HOT(Horizontal Output Transistor) see number carefully before you replace it.
Mar 14, 2008 | AOC CRT Monitor
Color problem
try to press the recall botton is it works then good for you...
If not then try a degausser tool.
if it still have the same problem after using a degausser tool, then there might be some parts of the monitor which is defective..
May 25, 2010 | AOC 5 En 15" CRT Monitor
My Monitor turns off and on. I can here the relay
I think it's the refresh rate.
In XP:
Right-click, properties on the desktop
Select settings tab
Hit the advanced button
Select the monitor tab
hit the box (hide modes that this monitor cannot display)
Select a new screen refresh rate
hit ok twice.
Feb 05, 2010 | AOC 5 En 15" CRT Monitor
Need schematic diagram for AOC 5 En model (white 15 inches color monitor) - thank's
my AOC crt monitor 5En model has this problem. it has over width the compress button (<> ) is no longer functioning what particular component should i check or adjust inside the circuit? please i need ur help..
Nov 21, 2009 | AOC 5 En 15" CRT Monitor
AOC color monitor 15in. 5En model. during power on all led lights functioned and no display was observed
u try to reorient ur vga connection it might be a loose connection between ur monitor and ur cpu otherwise ur vga cable is defective...
Nov 02, 2009 | AOC 5 En 15" CRT Monitor
AOC color monitor model 5En...during power on all led lights blinks then stops blinking without display action. all led lights on no more action observed.
actually if u repair an aoc monitor alone without getting connected to cpu once u switch on the monitor all led's will lit on ( green light ) it will remain on situation until u connect the vga connector to cpu that's the time led's will lit off and only the power led will remain in green condition.some aoc 5en once u power on power led is in green condition and if not connected to cpu it will be in orange condition.hope u get some idea but i am not sure if it will work with ur monitor. but as long as LEDs lit on i think no problem with ur monitor.
No power dead set 5en aoc monitor
just try to change the horizontal transistor C5386 or CXXXX... with a new one....
Feb 22, 2009 | AOC 5 En 15" CRT Monitor
Hello please help me to solve my problem. my monitor blow the power ic or power transistor. my monitor model are AOC 5 En 15 in.CRT.... now i hope solve my problem because i dont know what value of...
MR. elydon AOC 5 En mostly use this parts IC901 # UC3842AM and Q901 IRFBC40 or K2544 this parts usually use in power supply circuits or visit my email add almer_daxenreplica@yahoo.com
Jul 18, 2008 | AOC 5 En 15" CRT Monitor
Having a form of glasshour display
yes i have repaired my AOC 5En 15" CRT monitor diode # Diode 406 or check IC401,Q404,Q405,Q406 or visit my site for symatic diagram
Jul 12, 2008 | AOC 5 En 15" CRT Monitor
AOC 5 En 15" CRT Monitor Logo
328 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
