Question about HP LaserJet 2300dn Printer
Pager jam after 5 pages
We are facing some problem with laserjet 2300d when fire the 10 pages comand the printer will be printer only 5 pages and 6 & 7 pages are jam in fuser and transfer roller
    Scholar:
  • 61 Answers
Usually when this happens its because toner, dust and other contaminants have "gunked up" the paper path and is causing the jamming. Cleaning instructions are usually in the user's guide or manual. That would be my first step to resolving the problem.
If cleaning doesn't work than check to see if the transfer roller is seated properly against the fuser to allow for proper toner bonding with the paper. It locks in place and sometimes can get loose.
If that isn't the issue that you have potentially moved beyond that which is readily serviceable by and end user and you probably have a situation that will require a service call.
Posted on Feb 05, 2010
  • 77 Answers
Clean the tunner or change the roller
How to fix blank pager printing on hp laserjet 2420
the laser beam is block you need to open the printer and unjammed
since every time you put a toner cartridge there is a fin that moves the cover over the laser or maybe you have a faulty cartridge that the fin is broken
Apr 09, 2014 | HP LaserJet 2420 Printer
Printer jam after first copy
  • If a paper jam occurs when using the optional lower tray unit, check for correct installation of the upper paper tray.
  • Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and reduces paper jams.
If you need any technical help on printer then you can reach at here
Mar 08, 2013 | HP LaserJet 2300d Printer
Does fault cartridges cause double images when printing using laserjet P3005 Printer?
Try pull-out first the toner cartridge and then shake it, in 5 to 10 second. then insert again and test print. if same problem? clean the exterior using soft and clean cloth to wide dust, paper stain off of the device.this built up cause print quality problems, such as toner cartridge. power on your printer,
1. Press menu
2. Press down(in the laserjet unit) to highlight configuration device, and then press check (select).
3. Press down to highlight Print Quality, and then press check (select).
4. Press down to highlight Create cleaning page , and then press (select).
5. Remove all paper from try1.
6. Remove the cleaning page and load it face-down in tray1.
7. At the device control panel, press down to highlight Process cleaning page, and then press check (select).
Hope can help you,
Regards
Jul 19, 2011 | HP Office Equipment & Supplies
HP L7680 black print streeks every 5-6 lines
Any inkjet printer with this problem is caused by a build-up of ink on the undercarriage or the wiper assmbly.Usually on the right side where the cartridges are at rest. You have to get messy and clean that build-up with moistened cloth, qtips etc.
Jul 30, 2009 | HP Office Equipment & Supplies
Smudged Printing
change ink cartdidge then try. check also paper jam.
if still problem then change ink cartridge then check.
Jan 05, 2009 | HP LaserJet 2100 Printer
HP 2605dn- replaced all toner cartridges now it won't print-
There might be a problem with the network connection. Is the cable connected to the back of the printer?
The printer could have lost the connection.
If the printer is able to print a configuration page and if the display responds to comands from the buttons in the display panel there is a very good chance the network connection was lost.
Yo mentioned "paper jam" is the printer identifying a paper jam?
Nov 19, 2008 | HP Color LaserJet 2600n Printer
Help find installer softwareforhp laser jet 2300d
Pls start here. Click on the appropriate Operating System.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 02, 2008 | HP LaserJet 2300d Printer
Light print over entire page
clean the scan unit reflector
Mar 15, 2008 | HP LaserJet 2300d Printer
HP LaserJet 2300dn Printer Logo
76 people viewed this question
Seeker5211
Seeker5211
