Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
The dishwasher starts fine and then it will just shut down. The lights won't shine at all on the front. Then when you open the door there is water standing in the bottom. When you shut the door the green light start/resume starts flashing again. You start it again and then it does the whole thing all over again.....please help. I hate the thought of replacing it. Thanks! Whirpool Quite Partner II. DU1100XTP
  • 572 Answers
Check how many times the light flashes. if it flashes 7 times you have a too cold water going in error. or you heater could be faulty
Posted on Feb 05, 2010
I have a whirlpool awm295 that worked fine but
There is a safety switch that works with the door shut ,it is open circuit and needs replacing.
Oct 13, 2014 | Dishwashers
Dispenser door will not open
Do you have calcium build-up on the lid or catch? Is the spring that makes the lid spring open broken? Are you placing pans or large plates up against the front of the dishwasher that is holding the lid shut? In most cases, question #1 is the cause. Mix some Lemi-Shine powder in some hot water and use an old toothbrush to clean it off. You can also use "CLR" to clean it off. Or you can just buy some Dishwasher Magic to clean out the calcium throughout the dishwasher.
Jul 27, 2014 | Kenmore Dishwashers
Lights flash on dishwasher but it won't turn on
maybe a problem with the sensor 'door open/door close' check if its dirty or stuck if mechanical. press door to close and hold tight close while starting to identify.- or no sufficient water supply- or used water cannot drain out
Jun 15, 2012 | Frigidaire Dishwashers
Dishwasher will not start andthe green lights on control panel on front of dishwasher door blinking. I have look for obstructions and the door seems to shut good.
I have had this problem with a different make of dishwasher. The light came on but then it did not work.
It turned out to be the water had been turned off to the dishwasher.
Check your water supply is on!
Sep 01, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
My dishwasher ( 66517269400) won't turn on. Circuit is fine. It is getting power. I replaced the fuse. Clean light is flashing 7 times. Manual says "dishwasher has malfunctioned. Call for...
The F7 error code(light flashes 7 times) is a one of these, Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
So what you need to check is if the correct water level is in the tub,to check that start d/w let it fill and once you longer hear water entering,open door and the water should be level or just above the heat element, if not enough water first check water pressure to inlet valve,if pressure is good replace the water inlet valve part # 8531671 it could be picked up from your local appliance parts store,or online at;
repairclinic.com
searspartsdirect.com
apwagner.com
apdepot.com
midwestapplianceparts.com
Aug 20, 2011 | Kenmore 24 in. 17269 Built-in Dishwasher
My Frigidaire Dishwasher FDB1050RES2 gets stuck in a rinse cycle. The light on the front will be lit "clean" but the bottom of the washer is full of water. Opening the door does not turn off...
by the descrition you are giving you will need to replace the main control board.Part number 154568401.you may also need to check the float switch.The part will run about 110.00 dollars from a local parts store
Dec 29, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Water won't come in
Cynthia,
There's a flood/safety switch in the dishwasher. It's there to monitor the water level. It does this by rising as the water rises... if it gets too high, it'll shut the water off.
Open the door and remove the lower rack. You'll see it right there in front. Lift and drop it several times to clear any debris. (In order for the dishwasher to get water, it has to be all the way down.) Now try your dishwasher.
SG
Mar 27, 2009 | Kenmore Dishwashers
Whirlpool dishwasher stops midcycle and control panel goes blank
and the controls dont advance? to the end of cycle?
Feb 26, 2009 | Dishwashers
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
248 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
