Question about Tapwave Zodiac2 Handheld
Bluetooth prob My palmOne shows that my motorola hs820 bluetooth is connected but, when I dial a number, it still goes to the phone. Are these phones outdated or what? Bought this one new online 6 months ago. Who sells the cable needed to hook to computer? Thanks alot...
  • crazyimightb Feb 05, 2010
    This is a palmOne treo phone. It is not that zodiac ph., dont kno where that came from...
  • 47 Answers
Last I checked, Zodiacs are not phones, but are able to connect to a bluetooth enabled phone. Google a chord for it, Google is always your friend.
Posted on Feb 20, 2010
My droid 2 is not recognizing the motorola hs820 bluetooth device; I have no info on how to set the hs820 to pair
I think I can help here:
Make sure your headset and phone are charged before doing anything else. The blue light on your headset will come on when it is charging, and will shut off when fully charged.
To put your headset in pairing mode, make sure it is completely off first (no blinking blue light). Then hold down the Call button for 6-10 seconds until the blue light stays on. (It will likely flash once and shut off, but keep holding until it is all the way on and stays there!)
From there, go into the settings on your Droid 2 and access the bluetooth connections. Do a new scan for your headset if you don't see it listed, pair, and connect!
http://www.motorola.com/mdirect/manuals/QG-HS820_9494A71A.pdf
Feb 23, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
I need instructions for a motorola hs820 bluetooths
You can download user guide for Motorola HS820 from below website
Thank You
Aug 10, 2010 | Cell Phones
Motorola HS820 - cannot hear anything nor can others hear me
It turns out it was the Blackberry's problem, which could only be solved by a 're-boot' - take off the back of the Blackberry, pull out the battery for 10 seconds or so, and replace it. The BB will 'reset' and all was fine then.
Feb 16, 2010 | Motorola Mobility HS820 Consumer Headset
How to connect a Motorola HS820 headset with a Sony Ericsson C510
the interface between motorola and sony ericson works only in some models..try some other headsets (of your friend's ). of the same company.if it works then its not possible to connect the device
May 27, 2009 | Cell Phones
Can't hear with bluetooth
That means the pairing is not successful.Follow the steps
1.Turn on mobile bluetooth and set the status to shown all 2.Tun on the bluetooth mobile and keep pressing the button on the  bluetooth for few seconds. 3.You will notice that light is continously ON and not blinking 4.Now find the device from mobile via search option 5 When it detect use this code 0000 to pair. 6.When the pairing is successful ,select option button and click connect.. 7.Now you should hear from your bluetooth..
Regards
Dilip Bagdi
Dec 27, 2008 | Motorola Mobility HS820 Consumer Headset
Can't hear headset
Here is a list of compatible bluetooth headsets taken from the Blackberry web site.
  • Flamingo™ Bluetooth Headset *
  • Jabra® BT250v
  • Jabra JX10
  • Jabra BT125
  • Logitech® Mobile Pro™ Headset
  • Motorola® Bluetooth Headset H500 **
  • Motorola Bluetooth Headset HS820
  • Motorola Bluetooth Headset HS850
  • nXZEN™ 5000
  • Plantronics M3000 Bluetooth Headset
  • Plantronics Discovery™ 640 Bluetooth Headset
  • Plantronics Explorer™ 320 Bluetooth Headset
  • Plantronics Voyager™ 510 Bluetooth Headset
  • scala-500™ ***
  • Sony® Ericsson® Akono™ Bluetooth Headset HBH-602
  • It may be a compatibility issue with the H700. You may want to make sure the volume is turned up fully on the headset as well.
    Good Luck
    Jun 28, 2008 | Motorola Mobility H700 Wireless Headset
    NOT PAIRING ANYMORE
    1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
    3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
    4.Select HS820 once a connection is detected.
    5.The passkey "0000" is now entered to confirm the connection has been made.
    6.The cell phone screen will now read "Bluetooth Connection".
    Tips:
    1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
    2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
    3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
    please give good rating if the solution works.
    Thanks for using FixYa.
    Mar 15, 2008 | Motorola Mobility HS820 Consumer Headset
    My Phone Does Not Locate My HS820 Headset
    Try the following:
    1) Make sure the HS820 is fully charged up.
    2) Remove the battery and SIM card from your phone for about 1 minute and put them back in.
    3) As soon as your phone is booted up, access the "find devices" function for adding your HS820.
    4) Hold the HS820 button down until the blue light is solid.
    5) Then do whatever your phone requres to "search for devices."
    6) Here's the key: as the phone is searching for devices, PHYSICALLY TOUCH touch the HS820 to the phone.
    I couldn't get my HS820 to synch with my new Blackberry Curve the normal way and ultimately got it to synch by going through this process.
    Sep 11, 2007 | Motorola Mobility HS820 Consumer Headset
    Headset will not pair up eith razr phone.
    Have you pressed and held the button on headset until light is always on, as this is in pairing mode, then search devices with your phone.
    Jan 15, 2007 | Motorola Mobility HS820 Consumer Headset
    Tapwave Zodiac2 Handheld Logo
    41 people viewed this question
    Top Tapwave Computers & Internet Experts
    David Payne
    David Payne
    Are you a Tapwave Computer and Internet Expert? Answer questions, earn points and help others
