Question about Wacom Intuos3 12x19
When drawing with intuos 3, stylus flashes from arrow pointer to hour glass time out symbol and back to drawing mode very quickly .its doing my head in .iv'e got cs2 and plenty of hard drive left.
SOURCE: The cursor stops moving.
I have found the same problem here. I use my plasma as a monitor and that interferes with the tablet when up close.
I also read somewhere it also can be your wireless router that causes the same problem. Perhaps using a different channel in your router preferences.
Posted on Apr 02, 2008
SOURCE: Pen skipping in Photoshop CS3 with Intuos 3
Brush diameter set to Fade?
Posted on Jun 18, 2008
SOURCE: My Wacom Intuos3 tablet won't switch into pen mode
I had the same problem with my Intuos3 on Vista. Tech support suggested the following.
Do this.....Go to Start--->control panel---->system(in classic view)---->device manager--->click on "human interface devices"--->then click on "Wacom virtual HID driver" and right click on that and disable it. Your computer will ask you to restart and you will want to do that.
Everything works fine now.
Posted on Aug 14, 2008
The winning answer came courtesy of Mr Benedikt Schmitt of Wacom Europe, who offered the following solution: from the Windows Device Manager, disable the “Wacom Virtual Hid Driver” device. (Go to Control Panel > System and Maintenance > Device Manager, find the driver, right-click it and choose “Disable”.) One reboot later (welcome to Windows-land, circa 2008?), everything works as desired. Pressure and tilt sensitivity inside Photoshop still work, and the pen functions just fine in the rest of the Windows desktop. The absolute mapping makes it an absolute pleasure to point quickly and precisely. It makes my laser mouse feel rather clumsy navigating a large 24′ screen!
Posted on Mar 22, 2009
  • 396 Answers
SOURCE: Intuos 3 Pen/Stylus suddenly stopped working (as in dead).
Will the tablet work with the mouse? If it does not, is not working is the blue LED light on. If the LED is not working try another usb port. If the mouse works go into the Wacom tablet properties from the start menu. Select the grip pen from the tools. Click on the default button to restore the stylus to factory settings. When you press the pen you should see the pressure scale rise. You can also test the eraser pressure. You could also replace the stylus tip to see if that works. From the Wacom site you can order a new stylus or tips if it is found defective.
Posted on Sep 08, 2009
How do i change the time on T5K801 Marathon watch
To set time and date:
1) With time and date showing,
press SET and hold for 2 seconds.
2) Seconds flash. Press START/STOP to set seconds
to zero.
3) Press MODE
Hour flashes.
Press START/STOP
to change hour, including AM (no symbol) and PM.
4) Press MODE
Minutes flash.
Press START/STOP to change
minutes; hold button to scan values.
5) Press MODE. Year flashes.
Press START/STOP to change year.
6) Press MODE
Month flashes.
Press START/STOP
to change month.
7) Press MODE
Date flashes.
Press START/STOP
to change date.
8) Press SET
, at any step, to exit and save settings.
With time and date showing, press SET
to switch between 12- or 24- hour time format.
Date (day of month) appears in upper part of display in Time
mode. Press and hold START/STOP
to see month, date, and year in large digits
Or go to:
http://assets.timex.com/user_guides/Marathon/W292-Marathon-AllLanguages.pdf
Jul 31, 2017 | The Watches
How do i set timer
How to program Raindrip R673CT
Download R673CT manual at raindrip
Other models
R683CP
R672CT
Raindrip drip water guide
R673CT
Install 2 AAA batteries to power display
Set current time:
Press TIME and hour digit flashes > Use up-down arrows to set 24 hour clock
Press SET to confirm hour
Use up-down arrows to set minute
Press SET to confirm minute
Use up-down arrows to set day of week
Press SET to confirm day
Program review
Timer can set 16 watering schedules
When programming, look at display:
Notice: PROG for programming mode, #1, start time, run time, SU MO WE for days
Press PROG and display appear just like image above
Use arrows to select 1, 2, 3, 4 through 16 different watering schedules
Programming
Start time hour will flash
Once hour flashes, use arrows to select hour
Minutes will flash
Use arrows to select minute
Press SET to confirm minutes
Run time hours will flash
Use arrows to set run time hours duration (0 to 9 hours)
Run time minutes will flash
Use arrows to set run time minutes
Press Set to confirm
Now #2 shows on display this is about which days the timer will water
Decide 1) every other day, 2) every third day, or 3) watering at will
1) To water every other day:
While 2nd is flashing, press SET and SU TU WE FR will appear in display
2) To water every third day:
While 2nd is flashing, press down-arrow
3rd will start flashing and TU WE SA will display
3) To water at will:
While 2nd is flashing, press down-arrow twice
SU will flash
Press down-arrow to go to MO TU WE etc
Press SET when day you want appear on display
To set another watering program
Scroll back up to "programming" on this page
Press arrows to select programming 1 thru 16
Repeat programming sequence
After programming is set, press clock button and current time will show
Oct 07, 2010 | Raindrip R673CT Digital Water Timer
I have a Starter Brand Watch that did not come with a manual. I can't seem to get the chime to stop chiming on the hour.
Just bought a STARTER Sport Watch Model# STW14 @Walmart
TO CHANGE TIME:
1. Press and release MODE button quickly 3X in a row(top middle no.(Seconds will flash)& change Seconds by pressing START button 2. Press & release RESET button 1X quickly(Minutes will flash) & you change Minutes by pressing START button 3.Press & release RESET button 1X quickly(Hour will flash) & you change Hour by pressing START button. 4.Press & release RESET button 1X quickly(Date will flash) & you change Date by pressing START button.5.Press & release RESET button 1X quickly(Month will flash) & you change Month by pressing START button 6. Press & release RESET button 1X quickly(Day of week will flash) & you change Day by pressing START button 7. Press & release MODE button 1X quickly to return to Normal use
TO SET ALARM: 1. Press and release MODE button quickly 2X in a row(Hour will flash)& you change Hour by pressing START button 2.Press and release RESET button quickly 1X (Minutes will flash)& you change Minute by pressing START button 3. Press & release MODE button 1X quickly to return to Normal use
TO VIEW MONTH & DAY: 1. Press & Hold START button 2.Just Release START button to return to normal use.
TO USE STOP WATCH: 1. Press and Release MODE button quickly 1X 2. To START stop watch: Press START 1X quickly 3. To STOP Stop watch: Press Reset button 1X quickly 4. To RESET Stop watch: Press & Hold START button and press RESET button quickly @ the same time, 2X in a row 5.Press & Release MODE button 1X quickly to return to Normal use
Sep 12, 2009 | Bulova Watch
Wavy lines when I try to draw straight lines.
same too me.on my old pc.that center thing was working fine.there wasnt any vibrtion at mouse pointer.i cant explain but i know same problem here..mouse pointer slips
Aug 12, 2009 | Wacom Intuos2 Grip Pen (XP-501E) Digital...
Wacom Intuous 2 stylus continues action after lifting
metho is good at cleaning electronics. it has to be high 95 %
Jun 01, 2009 | Wacom Stylus Pen for Graphire4
Olympus sp 350
There is a "quick" button located on the back of the camera just for flashes. It is the first button to the right of the power button and it looks like a crooked lightning bolt arrow that points down. If you are in any picture taking mode, push this button and it will toggle you through each flash option, auto, red eye (eyeball symbol), flash (same symbol as the button, this mode will make the flash work everytime you take a picture), red eye and flash, and no flash (careful, in this mode you have to allow for the camera to focus, the lens will stay open a long time in a dark atmosphere -- if you don't hold the camera still you will get a blurry picture).
Apr 09, 2008 | Olympus SP-350 Digital Camera
Red L.E.D light won't stop flashing
Shaving head check indication After two years of use the red shaving unit symbol î will flash for 30 seconds during 7 shaves to indicate that you should check the condition of the shaving heads. This indication is based on an average shaving time of 3 minutes per shave. When the shaving head symbol flashes, all other symbols and lights are out. When the shaver is switched off, the shaving unit symbol disappears. When the red shaving unit symbol starts flashing, you should check the shaving heads for possible damage. If the shaving heads are damaged in any way, they must be replaced in order to obtain optimal shaving results
Nov 20, 2007 | Health & Beauty
Nikon Speedlight SB-800
I had the same problem. You locked your flash by mistake if you have a lock symbol on your LCD. Press the ON/OFF & Sel buttons simultaneously & the lock symbol will disappear. Then reset your unit by pressing Mode & ON/OFF simultaneously for 3 second & you are good to go!
Nov 16, 2007 | Nikon Speedlight SB-800 TTL Flash
Olympus Stylus 410
try to clean the pad using water damped cotton if you are techie, professional fix is needed if you're not.
Sep 07, 2007 | Olympus Stylus 410 / ? 410 Digital Camera
SHARP WIZARD OZ-590A DATA ORGANIZER
Turn on your organizer and touch the Clock Icon with your stylus. Just to the right of the bold heading on the top of the screen is a downward arrow. Touch the arrow with your stylus and a screen should come up with with six different modes of your choice. Touch the Home clock. Now touch the Edit on the bottom right hand corner of the screen. Touch the left solid arrow on the bottom of the screen enough times to bring you to the Country at the top of the screen. Touch the solid up or down arrow until you come the USA. Touch the solid right arrow unil you see the USA city field. Now touch the solid down arrow until you come to your city. Touch the solid right arrow once and the hour should be highlighted. Enter your hour. Now touch the right arrow to enter the minutes. Continue with the right arrow to fill in all the values and touch am or pm. Finally touch save or enter. The little smilly face is for daylight saving time which is touched on in the summer time. Hope this helps you, criszhill@yahoo.com
Jul 19, 2007 | Sharp Wizard OZ-590A
Wacom Intuos3 12x19 Logo
69 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
