Question about Gaggia Titanium Espresso Machine
Milk not frothing
The milk is no longer frothing and the nozzle comes apart when you wipe it.
  • ifr500 May 11, 2010
    You will need to replace the whole frother.
  • Gaggia Expert
  • 109 Answers
You require a new frother
Posted on Feb 12, 2010
Outlet pipe blocked. Descaling not helped.
You may have to clear the hole with some sort of thin probe, if you have a very small drill bit you can use that. You are only drilling out the hardened milk, not increasing the hole size so be careful. In the past I have used gas welding plant tip cleaners so if you know someone with an oxy/acetylene welder they should have a set of tip cleaners. If you have ever watched a barista frothing milk you would see that they ALWAYS blow an extra shot of steam into a damp cloth & wipe the outside of the nozzle after every use for frothing milk. This is to prevent exactly the problem you now have.
Mar 08, 2015 | Krups Nespresso Xn250140 U Coffee Machine,...
THE FORTHED MILK NOT HOT
Try steaming less actual milk and allowing the froth and expansion to make up the volume you need for the size of the cup. This allows you to steam the milk longer achieving a hotter froth.
Dec 20, 2014 | DeLonghi Magnifica Coffee Makers &...
I have a Delonghi Prima Donna. Blows lots of stem but wont froth milk. The 3 orings have been replaced and the fittings cleaned, but still no frothing. I pulled the lid apart and it seems ok. Any...
Where is it blowing steam from? If it is coming from the milk spout then it most likely that the milk jug is blocked somewhere. If it is coming from where the jug connects to the machine (coupling) then you might need to change the complete coupling (assuming you used the correct orings). The biggest cause of frothing problems with these machines is lack of cleaning of the milk jug. Soak the top in quality milk cleaner for at least an hour and rinse thoroughly. Also run cleaner through it regularly using the milk only function.
Nov 19, 2010 | DeLonghi Prima Donna Avante ESAM6700...
I have an Impressa Z5 and it won't **** milk up the tube as either part of the cappucino program or the stand alone milk program. I've checked and nothing in the nozzle is blocked and the plastic pipe...
There are three possible causes to milk not frothing: 1. The frothing tap is blocked: to unblock either use the cappuccino cleaner from Jura, or in 400ml of luke warm water dissolve a teaspoon of vinegar or 1/2 teaspoon of bicarb and run this liquid through the frother until completely finished (or run the cleaning program). The run about 600-800ml of water through the system. While passing the liquid through let the tap rest at froth, and milk setting for 5 seconds at a time. Repeat if necessary. To prevent this in future clean frother after 5 minute of none use. 2. The breathing nozzle is blocked, you can use the Jura Maintenance guide to see how to disassemble and clean and reassemble, but most Juras come with a spare, so replace it. 3. The machine needs to be descaled, since there is lime or scale in it.
Jan 15, 2010 | Jura Capresso Impressa Z5 Espresso/Coffee...
Frother builds up too much pressure and explodes off the machine
I had the same problem. All you need to do is take the steam nozzle apart and clean it. I tip can be cleand with a neadle. Just make sure you unblock the little side holes and make sure to thoroughly clean the little hole in the front. Over time the milk builds up in the nozzle, clogging up the "steam holes", so the preassure gets too big and the rubber attachments can't hold it any longer. Hope that helps.
Jun 05, 2009 | Jura Capresso F8 Espresso Machine
Seaco Odea Go
You can not adjust the amount of this.
/Mirran
Aug 17, 2008 | Saeco Odea Go
Saeco milk island - no froth
I tried cleaning the thing throughout, and drying it on paper towels, but still no froth. Luckily, I bought the machine from a reputable dealer with superb integrity. He fixed the problem for me by returning the milk island and getting me a new one. It works perfectly now.
Nov 05, 2007 | Saeco Milk Island Automatic Frother -...
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
129 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
