Question about Coby DVD-937 5.1 Channel DVD Player/Receiver Home Theater Speaker System System
Keep getting unsupported mode message on my new coby monitor
I have a dell pc and it works fine with the dell monitor but not the nice coby i just got. is there an adapter i can purchase so that i can fix this and use the coby
  • 3 Answers
Adjust the resolution on your computer to one of the standard resolutions - 800 x 600, 1024 x 768, or the native resolution of the screen.
Posted on Mar 30, 2010
Why is my dell inspiron 531s stuck on black screen with input not supported message?
Start pc in safe mode and try to change resolution.
Then update the graphics driver.
May 06, 2014 | Dell Inspiron 531s Desktop Computer
Dell backlight indicators
A computer monitor has a front-mounted LED that displays its current status and flashes in the event of an error. When an error occurs, the flashing may be accompanied by an error message on the screen. If the screen does not display an error message, the problem most likely falls into one of four common categories.
Unsupported Display Mode A video card has the ability to send output to the monitor at many display resolutions and refresh rates. However, no single monitor is capable of supporting every possible display mode. When the video card sends an unsupported display mode to the monitor, the monitor shuts off to prevent damage and blinks, or displays an error message. Standby Mode b> When a monitor detects no video signal from the computer, it assumes that you have turned the computer off and enters standby mode to reduce power consumption. Dell and HP monitors display an amber light when in standby mode. The status light on an Apple monitor blinks slowly. Incorrect Power Supply Some monitors such as certain Apple Cinema and Studio displays use external power adapters. Because different power adapters may have similar connectors, these monitors are designed to detect when an incorrect power supply is connected and blink the status LED rather than attempting to turn on. In the case of an Apple display, the LED blinks in an alternating short and long pattern. b> Backlight Failure b> A flat panel LCD display has an LED or fluorescent backlight that illuminates the pixels and makes it possible to see the contents of the screen. If the backlight fails and requires replacement, the monitor is unable to display any information. In some cases, you may be able to resolve this issue by turning the monitor and computer off, disconnecting and reseating all cables. If the monitor still has a backlight issue, it requires professional service.
Jan 14, 2013 | Computers & Internet
My TV/Monitor says "Unsupported" when
The problem is not in your monitor.The problem is in your computer.So try to fix your computer with upgrading the board,Use high specs of memory and card reader.Thanks..
Aug 21, 2011 | Coby TFDVD1973 LCD TV
I have a coby 27 in monitor i just got from a friend my pc is a dell. when i hook the coby monitor up to the dell its like it freezes up all the screen will say is unsupported mode, is there an adapter i...
It is likely that the monitor in question does not support the video settings you currently have your graphics card or chipset set to.
If you are using Windows XP reboot your system hitting <F8> until a menu appears to select a mode to start XP in. Choose "Standard VGA". This should resolve the immediate problem.
Since you don't mention the model number of the monitor in question I couldn't look up the supported screen resolutions for you but right clicking an empty space on the screen and selecting "properties" should bring up the video settings dialog box where you can try various screen resolution settings [rebooting each time] until you find one you like that works with the monitor.
Feb 05, 2010 | Computers & Internet
Unsupported Video Configuration Detected
Apparently you set a video resolution which your monitor isn't able to handle. Try booting in safe mode by holding the F8 key at boot, then change resolution to something safe such as 1024x768. Reboot in normal mode and set the resolution you're most comfortable with.
Oct 29, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell Monitor in Power Save mode
Hello there:
i would refer to your users manual to see if there is a power save mode setting on the monitor it'self and to see how to adjust it or contact the manufacture of the monitor . ok ?
hope that this is helpful
Aug 06, 2009 | Dell E173FP 17" LCD Monitor
Dell E173FP stuck in power save mode
Good morning! kindly try to review/check the operations manual of your monitor as there might be proper set-up settings / compatibility requirements to a certain PC. best regards
May 09, 2009 | Dell Dimension E520 PC Desktop
Showing message out of range
Your monitor settings within windows are set too high for the monitor to display... When computer first boots.. be ready and press the F8 key...
Enter safe mode.. Reset the display properties in control panel to 800 by 600 for a start. Setting the resolution too high past the monitors ability will give you that message.. Most monitors are able to display 1024 by 768 just fine.. Out of range.. means the display settings within windows are out of the monitors range of ability to display the screen resolution you have set... Good luck!!
Feb 18, 2009 | Dell Dimension 8200 PC Desktop
493 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
