Question about Kenmore Elite 45986 Front Load Washer
He 4t washer with a fault code of F 11 - Kenmore Elite 45986 Front Load Washer
  • 572 Answers
Going to need th main board (pricy) F-11 is a door lock error code.
Posted on Feb 05, 2010
Why washer will not do diagnostic test or erase E38 error code
[PDF]Fault Code Bible v1.2 - ResearchGate
www.researchgate.net/publictopics.PublicPostFileLoader.html... ResearchGatesimple, clear instructions on how to read the faults or use the diagnostic routines. .....Resetting the error indication does not rectify the fault but only erases from .... E53 Input circuit EMC errors Displayed as error code, washing machine start ... if you choose position 10, 11 or 12, the test will terminate without pressing.
Sep 16, 2015 | Washing Machines
What does F-11 error code mean on my Kenmore HE 4t front loader washer?
I believe it means motor control unit failure. Make sure nothing is plugged into same circuit unplug unit for 10 min. and try again . If it still does not work you will need a tech
Nov 20, 2010 | Kenmore Elite 45986 Front Load Washer
Machine stopping mid cycle
Count the number of green flashes(1st number of error code). count number of red flashes(2nd number of error code).
Common codes are:
E10 or 11 water pressure faults.
E20 filter/pump faults.
E30 pressure switch/heater faults.
E40 door switch faults.
E50 motor faults.
E60 Heater faults.
These are some of the error codes but there are many variations on some codes depending on the model.Hpoe this has been some help.
Apr 24, 2010 | Zanussi ZWF10070W Front Load Washer
Kenmore front load HE 4T error code 2F what does this mean?
Its been my experience this is related to the drain pump being plugged.
First, you need to take out as much water as you can. Empty the washer and then select drain with NO spin. It may help to drain water.
Second step, unplug your machine, and unscrew the front-bottom panel (there are three screws on the bottom, you need to go to the floor)
Third, there is a plastic cover for the draining pump. WARNING - There is still, water inside, so have plenty of towels handy!
Unscrew the plastic cover and there is a good chance you'll find the clog.
Sep 15, 2009 | Kenmore HE2 Plus Front Load Washer
F11 CODE
you have bad communication ,,between the control board and themotor control board..,,check for a lose harness at booth ends
Dec 28, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE 4T
HE 4 front load remove bottom panel 3 screws once remove now you have access to pump get towels and bucket oper lint filter and remove debris from inside ,,,,, and that its F2 long drain,,,,,,
Oct 13, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore Elite He 4t washer
washer weary, You need to clean the filter on the pump. Remove the bottom panel and the filter will be right in front. 3 #11 torx screws it will pull down and off. Get yourself a bucket to catch the excess water. Unscrew the filter and clean it. Check to see that nothing is in the impeller. The F02 should go away..Catriver.
Sep 11, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
108 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
