Question about Ricoh Aficio 450 Copier
Sc492-00 Boots up, makes noise and comes out with the error sc492-00 any ideas ppl?
  • 87 Answers
The AC/DC power supply fan motor is locked. It could be dirty, bad, or a bad connection.
Posted on Feb 23, 2008
Front end has clicking or popping noise when making sharp turns right or left when vehicle is in drive or reverse. there is no noise when car is coasting in neutral and making the same tight turns. Any...
The noise is probably warn constant velocity joint in the half shafts the rubber boots are probably broken on 1 or both sides dirt enters in through the broken boot and causes wear which damages the joints they should be replaced before they break and cause serious damage
Mar 26, 2013 | Cars & Trucks
Samsung vrt steam washer makes noise and there are no codes but won't spin or rinse or anything .
Get a new one'if you didn't by now. get the ppl that you brought this from, or tell them that your having trouble with your equipment. tell them to come and fix it. Tell them your not playing. maybe you got this fixed sense then.
Oct 05, 2012 | Washing Machines
I have bad road noise after 40 mph. This started after changed tires and both front boots and axles
to possible answers
the axles are new and the cv joints mat be firm resulting in noise transmission through failing engine mounts ( unlikely but possible )
the tread pattern may be the cause of the noise especially if the tyre pressure is incorrect
Take it back to the shop and take them for a road test to see if they can find the reason
when drive axles have to replaced , it generally means that the front lower arms have to be disconnected so a wheel alignment may also be in order
May 04, 2017 | 2006 Subaru Outback
With the steering wheel straight if u turn it right or left there is a clunking noise comming from under the car. the power steering fluid was low and i filled it up but the noise is still htere. any...
the drive couplings on the end of the drive shafts are noisy but not worn out so ignore ,make sure the rubber boots are not split and in good condition,if the boots are perished and split then replace them and whilst the coupling is off i always stip then by turning and moving teh cage do teh balls come out then wash in diesel and refit so the balls are in different positions ,repack with grease and then after rubber boot is pushed up the shaft refit the coupling and i always buy some big jubille clip for a chimney pipe from hardware shop and use these instead of them plastic tie things as they always come off allowing dirt back in ,if after cleaning and fitting a new boot they still make a noise just ignore it as its not dangerous or life threatening ,just a pain listerning to it .
Feb 10, 2011 | 2003 Ford Focus
We receive a partial or a blank page for incoming faxes followed by an error report pade with a 00-23 Quick Service Code. Can you help?
too many errors during reception
check the line 1st
too much noise on line
if its all the time from different ppl my guess is its ur end
connect a phone dial 1 and listen to the line if u hear any noise then its u
Nov 10, 2010 | Ricoh 3320L Laser Fax
Noise coming from lower left side of car
I don't know about the boots, but my 93 Saturn SL2 was doing the same thing and I found out it was the clutch.
Jul 12, 2010 | 1993 Saturn SL2
I have the acer aspire 5532 and windows error recevery keeps coming up please advice. It makes a weird noise and a blue screen pops up that says a problem has occured......
You will have to do a repair of your windows installation. You need to boot on your Windows DVD and do a "Repair" install. OR if you have System Recovery in the PC then you should try that first. Also you could try booting up in SAFE mode, press F8 before it boots, and when, if? it boots to desktop you could either troubleshoot, or restore your system to another time using system restore.
Jan 27, 2010 | Acer Aspire 3610 Notebook
CRV has knocking sound coming from rear passenger side
inspect the braking system for warped or uneven rotor surface, as this may cause this noise and uneven pad wear. CV joints also could cause this if the boots are torn, have insufficient grease, are damaged,or have worn bearings. Hopefully this helps
Jul 22, 2009 | 2002 Honda CR-V
Car Rumbles, CV Joint?
you may have wheel bearn going. they will make noise grinding when you trun
Mar 22, 2009 | 1992 Buick Park Avenue
Laptop amkes a beep sound but doesn't boot
Hi Saniple, more than likely those are beep codes and should give us an idea of what is going on. Typically there is a specific pattern of long and short beeps. If you can identify them for us we can start the troubleshooting process
Feb 02, 2007 | NEC Versa LX Notebook
Ricoh Aficio 450 Copier Logo
238 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
