Question about Compaq Presario M2000 Notebook
My laptop shows Colored Vertical Lines. OS is Windows Vista. My laptop is Compaq- 3 years old. Please help!!
    Scholar:
  • 51 Answers
Okay, firstly please try and boot into safe mode and see if the problem persists then. If yes, then boot from a recovery CD (so that the OS is not in use - instead the CD is). These two steps will test whether the problem is to do with software/OS or a hardware issue. If with the CD boot the problem still persists then you know it's not a malware or OS problem. At this point if you have another (LCD) monitor to connect to your laptop, please do so and then see if the colored lines appear on your spare monitor. If not, then your monitor needs to be replaced (or use the spare one instead). And if the problem still persists, then it could be a motherboard fault or some other internal part. In that case, contact Compaq for any replacement part possibility. If any of my suggestions help you, please do rate me. Thanks and good luck. Hope all goes well for you.
Posted on Feb 05, 2010
    Scholar:
  • 61 Answers
While it is possible that this is a driver related issue that would be rare.
When I have seen this in the past can be a video card or chipset going bad but even more often it is the wiring to the LCD screen that is failing. You can tell if you apply some pressure to the base of the screen, especially if you now the area where the wiring come up from the base and into the screen, and the problem stops.
Unfortunately if it is either the video chipset on the mainboard of the system or the wiring these are not problems that can be dealt with by the average end user and you need to seek the services of a professional repair tech.
  • 107 Answers
I have gone to this issue before this might be on the connection between the panel and the motherboard, connecting your laptop to a monitor will confirm this either way. This will confirm only that the video card is working properly or not . if its working fine upon connecting to a different monitor/lcd
this confirms that it might be on the connection between the panel and the motherboard if not this would prove that it is really an hardware issue primarily on your LCD screen.
Touchpad VERTICAL and HORIZONTAL SCROLLS are not working.
The software for Win8 is not compatible with your touch ad, Re install Vista or Win7 or download apropriate drivers from Windows.
Mar 20, 2013 | Compaq Presario V3700 Laptop AC Power...
Display resolution decreases unexpectedly. I find that the resolution is set at max but display settings show multiple monitors. I am only using the laptop display. I can temporarily resolve this issue by...
old compaq Notebooks.
running what OS what windows is there, of the 14 made.
my guess XP on up.? the hp data sheet says VISTA.
is it still running VISTA? still have the HP recovery disks>?
all modern screens and GPU chips have many possible resolutions.
this great benefit allows you to run old APPS that only do low (poor)
resolutions, (i can name some if you ask, some old video players)
the only problem using old laptops is the lack of support after 10 long years, and HP ends that. I';d give on finding HP drivers. this old.
and that Vista support ended this year, HP and at MS.
V1000 to V6000 are now retired. see here for proof
THAT being said, i plunder on and try to find the correct drivers
first I attempt to ID that GPU chip, (i have scanner to make that easy but can do that here can I) so i must google to find the data sheets.
step one is what OS, you never said so the job expands or fails.
Nvidia. GeForce Go 6150 , VISTA
the makers (nvidia )web page is tricky,
ill teach you how to use it , and it is there. link below.
drivers, top box click Gforce
box 2 pick Gforce 6 series
box 3 pick your unstated OS/
box 4 you lang.
box 6 all.
click search and then pick newest WHQL driver.
DL it. run it , use it.
bingo?
https://www.geforce.com/drivers
my wild coin toss , landed me here Vista 32b
https://www.geforce.com/drivers/results/82701
Jul 31, 2017 | Compaq Presario V6310US Notebook
When i turn on my PC it starts beeping continuously and sound stops after one minute,then i have to press F8 which shows some instructions from which i select "start windows normally" my display shows...
I m sure that it is a problem from inside.
Go to the nearest notebook repair center,i probably think there is a problem with your laptop video card.
Oct 08, 2010 | Compaq Presario Laptop
Getting colored vertical lines on the right 1/3 of my 52" Toshiba LCD why? can it be fixed?
looks like the lcd panel is damaged contact the toshiba service on your area
May 04, 2010 | Toshiba REGZA 52RV530U LCD TV
Screen problem immediately after the "Welcome" page
well went wrong.thats the first question.maybe the screen is bad.check for a local repairer in your area.
Jun 05, 2009 | HP Compaq Presario C500t Notebook
Vertical lines in my laptop screen
I had the same problem - sent it in to Acer and they replaced the LCD for 500 bucks!
Aug 18, 2008 | Acer Aspire 9500 Notebook
if this line is there during boot up then it is a monitor problem usually. but if it is not then it is a problem with your windows files. you could try reinstalling your windows from the disks you were given with it? otherwise i will look into it. email me if you need more help. milliprowd21@yahoo.co.uk
thanks
matt
Jul 30, 2008 | Acer TravelMate 2300 Notebook
Half Screen has colored lines, Half screen is working ok
there is a defected capacitor in the vertical circuit trouble shoot and replace. or if the vertical circuit is separate then replace the whole board.good luck
Jul 11, 2008 | LG 42PX5D 42 in. Plasma HDTV
Vertical colored lines on screen-no picture
It's definitely possible. I'd have it checked by a repair center for something like this.
Jun 09, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Compaq Presario M2000 Notebook Logo
135 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
