Question about Microsoft Xbox 360 Console
Hello i fixed a xbox 360 and tried playing a game and everything was ok but it says play dvd and it will not let me play a game but only dvd have any idea?
  • 340 Answers
This is a drive fault,have you put the power and sata cables back in the drive upside down? turn then around and test again.The laser may just be dirty,carefully clean with some alchol and a q tip.Are you using the original drive for that console? if not you may have the wrong drive installed. Did you drop or bang the drive when it was removed, the laser could have become mis aligned, there are plenty of guides on youtube if you want to have a go at a fix yourself at re aligning.
Remember thumbs up if this helps.
Posted on Feb 05, 2010
Testimonial: "thanks alot im goin to look now but no it wasnt the orginal drive i dont think..you have any other suggestions to make the drive work in the xbox 360?"
  • damonumber5
    damonumber5 Feb 14, 2010
    If you swop drives, you have to change the drive key from your old drive to your new one, this is just removing a small circuit board out of the drive, if its a samsung or hitatchi this is easy, if its a benq you need a soldering iron and a steady hand, comment back if you need assistance with this.
When we put in a game for our 360 system it says it's playing a dvd we can't get the game to work. how do i fix it so it says play game amd not play dvd? (it only does this with 1 game. the rest work fine
Ok if your for certain thats the original dvd drive and the other games work then its too many scratches on the disc or your laser lens needs wiped off with qtip and rubbing alcohol.
If you get an xbox thats say play dvd all the time on every game and it says to play this disc stick in a xbox 360 console then its the wrong dvd drive for that motherboard and you wont get the key (on a chip in the motherboard on the cd drive) unless you have the original dvd drive taken out of your xbox. Then you can just switch that little motherboard on the bottom of the dvd drives and it will read games. This is for those who will look at this with a xbox off ebay that they cant figure out how to fix. Its just an expensive dvd player.
Dec 26, 2010 | Microsoft Xbox 360 Console
Xbox 360 - Please put disc into an xbox 360 console to play
Try getting a disc drive cleaner. (Maxwell).
www.walmart.com is and example retailer.
May 24, 2010 | Microsoft Xbox 360 Console
My disc drive says play dvd at the dashboard when i have a 360 game in it and when i press play it reads, to play disc put it in a xbox 360 console
Hello, Thanks for using FixYa. If you are encountering this problem it means that your xbox360's dvd lens had gone bad. Lenses have life time. Try to get a DVD lens cleaner disk first then use it on your xbox. If this doesn't solve the problem you will then need to have your lens aligned or changed if aligning doesn't fix the issue. I hope this helps. Thanks and good day. - HotRatchet
Feb 15, 2010 | Microsoft Xbox 360 Console
DVD
If your Xbox 360 will not play your games this is because of the sensors on the back of the drive overheating it is not normally the laser.
Luckily you can fix this yourself and get back to your games and to do this you need the proven Xbox 360 Repair guide.
Or you can send it in and they will fix it for you the repair will take about 4 weeks.
The DVD issue normally happens as you will find that it can still read DVD's!
You will need to stop the heat to read games.
Feb 10, 2010 | Microsoft Xbox 360 Console
Xbox 360 will play DVD's but won't play games
Needs new laser, buy'em cheap for like 15$ or less.
-easy fix :)
Aug 27, 2009 | Microsoft Xbox 360 Console
Xbox 360 Doesn't recognize Xbox 360 games
try going into your settings and family prefrences and if tht doesnt work tht means your game is scratched
Apr 24, 2009 | Microsoft Xbox 360 Elite Console - Black
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
Xbox 360 plays dvd but not games
you probably didn't flash the drive correctly. you can find guids how to online. its a pretty in depth process though.
May 24, 2008 | Microsoft Xbox 360 Console
Xbox 360
Get A New DVD drive.
I,d suggest That Your Laser is,nt kicking up the required Voltage To read The dual-Layers ?
X-Box games Are single Layer DVD. 360s Are Dual Layer ( DL )
Also try An Original Or Over 5 gig DVD ( Thats most likely to Be Dual Layer )
Mike @ Compurepair.
Posted @ 22.36 PM ( G.M.T )
Mar 02, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
32 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
