Question about Fellowes P400C-2 Shredder
First plastic gear driven from motor pinion has
First plastic gear driven from motor pinion has stripped teeth; needs replacement.
I have a simple solution if you can think outside of the box. When my gear stripped, I chucked away the electrics, and now drive the shredder via a crank handle on the side. It gives good excercise, and isn't difficult to turn with anything up to 6 or so sheets.
If you want to do this, open the machine, and remove the smaller gear at the opposite end of the drive (take off the circlip) to expose a hex shaped shaft. You can also chuck all of the electrics, and all but the two gears that are on the shredder shafts. Then cut a hole through both the top casing, and through the bucket, to line up with the shaft end and allow a 9/16 socket to pass through. When reassembled, there is sufficient room to drive the mechanism with a standard 3/8 drive ratchet, although you could make a fancier drive with a handle on.
Happy Days
Garry
Posted on Jul 01, 2010
    Problem Solver:
  • 9 Answers
Try thetapped@yahoo.com he has new parts he might be able to help you out.
Posted on Mar 18, 2010
Emailed Fellowes, who replied very dismissively, "Please note that we do not have spares for this machine." There are many complaints about the stripping of Fellowes gears, and many comments that the engineering is rubbish. ©Brooke Harvey 2010
Incidentally, FixYa seemed to be asking me to give you my credit card details to receive a seven-day free trial. Presumably you are not serious.
You also want to assume copyright on my comments. Not so; it stays with me unless I transfer it to someone else.
Best wishes
Brooke Harvey
Posted on Feb 05, 2010
GL1800 has starter that ran after engine being turned off. Smoked and only stopped after disconnect of neg batt lead. what could be the cause?
pinion gear stuck in ring gear
could be a problem ring gear I damaged teeth), problem override clutch for pinion ( incorrect teeth pitch of the starter gear)
could be a short in the solenoid wire that kept in engaged
A new starter motor will be required and the circuits and ring gear inspected/replaced
Mar 27, 2017 | Cars & Trucks
1970 Chevy El Camino starter broke teeth on flywheel. What would cause this?
several reasons
the teeth on the ring gear were damaged from continuous grinding during pinion engagement or engagement of the starter when the engine is running causing a burring of the teeth that altered the mesh ability and jammed the ring gear and pinion
metal in the teeth of the ring gear that causes a jam in rotation
starter motor not engaging before rotating
wrong no of teeth on replacement starter pinion or starter motor
Dec 17, 2016 | Chevrolet El Camino Cars & Trucks
Troy built snow blower the electric starter grinds
sounds like your starter pinion is stripped. remove your starter and inspect the gear. If the teeth are worn then replace gear if not replace starter. you will also want to check the teeth on your flywheel
Oct 07, 2014 | Garden
How do you remove pinion gear attached to motor shaft?
with gear puller or press,sometime spring ring lock the gear on the shaft,remove it first
Nov 22, 2012 | Craftsman 10" Table Saw
Flexplate has 141 teeth, need replacement
There is too big a difference between the two ring gear teeth numbers. You could change the starter drive pinion to suit the new ring gear though.
Apr 07, 2010 | 1966 Ford Mustang
The teeth small pinion gear on the focus knob shaft are stipped
No. That's one of the trade-offs with cheap models, they can be fine but have absolutely no spares back up.
All you can do is to check whether the 'scope is covered by a manufacturer's warranty.
Jan 20, 2009 | Galileo 800mm-72mm Refractor Telescope...
2003 Buick park Avenue Driver Seat Adjuster...
After months of looking I found a shop who was willing to make me some brass gears. I put the brass gear in both my 2002 Park Ave seats. They work great. I sell them for 100 apiece. claygear@hotmail.ca
Aug 23, 2008 | 2003 Buick Park Avenue
Rear gear ratio for 93 toyota 4x4 pickup 5 speed.
The C/Tr: C refers to the colour of the vehicle Tr refers to the interior colour A/TM is your transmission type. None of those numbers identify the rear end ratio.
What you need to do: Since you have to replace the rear end, yank it out. Examine the ring & pinion gears on the differential carrier. Mark on each a starting point, and count the teeth on both the ring & pinion gears. Now, after you have both totals of teeth, divide the # of teeth on the pinion by the number of teeth on the ring gear. Example: 12 teeth on the pinion, 46 teeth on the ring
12/46 = 3.83 ratio
Aug 22, 2008 | 1993 Toyota Pickup
Fellowes P400C-2 Shredder Logo
644 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
