JVC BR-DV600U Mini DV VCR Logo
Posted on Feb 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I purchased a JVC BR-DV600U DV deck to use with my Mac computer for video editing. When I plugged the Firewire cord from the deck into the computer, problems began to happen. Two of my three external Firewire drives disappeared from the desktops. What is causing this and what can I do about it?
electronic & computer repair& servicre
Level 3:
  • JVC Master 12,061 Answers
  • Posted on Feb 05, 2010
JVC Master
Level 3:
Answers
12061
Questions
0
Helped
4005262
Points
36390
There exist a number of methods for dealing with FireWire device interference, a few of which are explored here. Switching Ports The first procedure you should try when experiencing a problem that you believe to be caused by device interference is to simply reconfigure the arrangement in which your FireWire peripherals are connected. Try switching each device to a different port, or temporarily disconnecting one or more of the devices. In particular, if you are a PowerMac G5 owner, trying switching devices from the front to back ports or vice versa. Adding an external hub In some cases, it appears that FireWire devices are not drawing enough power from the computer. This can cause a sundry of strange issues, including apparent conflicts between devices and unexpected power-offs during device operation. In these instances, adding an externally powered FireWire hub can clear things up. One of the reasons an "under-powered" situation can occur is that different Mac models have varying power capacities available through their FireWire ports. PowerBooks and iBooks have the least, generating around 7 watts. The iMac G5 also generates a relatively low amount of FireWire power, sharing 8 watts between its two FireWire 400 ports. The Power Mac G5 shares 15 watts between its one FireWire 800 port and two FireWire 400 ports. Place devices on different FireWire busses/Isolate the iSight Similar to the above procedure, adding another FireWire bridge -- via an extra PCI-based FireWire adapter or another means -- can eliminate conflicts from devices that reside on the same bridge. Power cycling the system Simply cycling the power on your system may be enough to temporarily eliminate a few FireWire conflict issues. Shut down your Mac, and disconnect all FireWire devices as well as the computer's power cord. Leave the system off for about 10 minutes, then plug it back in. First turn your Mac back on, then re-attach the FireWire devices one at a time and check for the conflict to resurface. Disconnect specific FireWire devices (especially iSight) to check for conflicts As noted above, the most common cause of interference is Apple's own iSight. In case after case, simply disconnecting this single device has eliminated problems with other FireWire devices. Other devices often implicated in FireWire conflicts include video-related devices; cameras, the EyeTV, video decks, etc.
Disconnecting the iSight has proved particularly successful for an issue where the iPod disappears from the Desktop and from the iTunes playlist, while the iPod status screen cycles from the Apple logo to a "Do not Disconnect" message over and over. The exact reasons why the iSight causes more than its fair share conflicts with other FireWire devices are many, and sometimes unclear. One potential source of conflict, however, could be the unit's high bandwidth usage. The iSight captures video at a 640 x 480 pixel resolution, at 30 frames per second in millions of colors. Such throughput uses a significant chunk of the standard FireWire port's 400 Mbps bandwidth. As such, when other devices are connected, the bandwidth requirements for satisfactory performance may not be met. Try disconnecting all FireWire devices, then adding them back one by one and repeating the originally failed operation to check for conflicts. Apply the latest updates Make sure that your FireWire drives are using the latest firmware (check the manufacturers' Web site) and the most recent iPod update has also been applied. Of higher importance, if you have an iSight, is the iSight 1.0.2 updater. In a large number of cases it has resolved conflicts caused by the camera. Re-apply the most recent Mac OS X combo updater In some cases, re-applying the most recent combo updater can resurrect seemingly defunct FireWire ports and allow devices -- drives included -- to be recognized again. The most recent combo updater is available from Apple's download page. Clear caches Try using a tool like Tiger Cache Cleaner or Cocktail to remove potentially corrupt system caches. Restart, then check if your FireWire devices are recognized.
What cord do I need to purchase to connect a JVC GR-DVL305 camcorder to a VCR or Mac Computer?
Hi The GR-DVL305 should have come with a composite AV cable (a 3.5mm jack to 3 RCA plugs). On the VCR you would need a composite input or possibly a scart input. If you have a scart input you would need a convertor from RCA to Scart (available from Amazon etc.). If you want to connect the camcorder to the Mac it would depend on what Mac. Your Mac may have a FireWire input. If so you can but a firewire cable to connect the JVC to the Mac, but and it's a big but (!) Firewire is not a plug and play system like USB. You will also need software on the Mac that can take the analogue signal from the camcorder and convert it to digital. Hope that helps.
2helpful
I bought a mini DV GR-D31U years ago and the cord that came with it does not allow me to connect to my dell computer. Years ago I asked around as to what could be done to remedy this as far as there being...
You apparently have a Firewire (DV) cable.
This type of camera usually downloads better with a Firewire connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. The way it works on my computer, the camera is controlled by the computer software through the Firewire cable.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As your Dell Windows PC did not come with this interface, you need to fit an add-on Firewire interface card to the internal expansion bus (PCI). This will come with a driver for the card. You can buy one of these cheaply on eBay or Amazon.
Problem my mac and mini dv deck when they are connected with dv ports
Hello, the mini dv is the port that carries images and video to a television for example, or a computer, but will not help to transfer data to a computer. the firewire port does transfer data to the computer though, this is the reason why it is ackowledged as an external hard drive when you plug it this way. The best is to plug both, this will give you the opportunity to watch on your desktop, and to transfer data
My JVC GY-HD111E isn't located in final cut pro
Are you using HDV, make sure you set the signal to DV on the camera. Does it have a signal out option to switch from video to dv / firewire? Have you checked to see if it is supported? Also just keep trying, turn camera on and off, restart the computer with firewire connected then without. I had this problem with a deck and it randomly started working after my 5th try.
Cant detect camera on dv video recording transfers.
Hi, I hope the camera you are talking about is ZR200 Mini DV.
As per its specifications. It has a firewire/DV port.
Therefore, follow these steps. I assume you are using this cable. http://cdn.overstock.com/images/products/L10726964.jpg
I am not sure how you used the firewire cable before.
So, try this. Connect one end of the cable to computer and other to the camera. Switch on the camera and keep it in play/ edit mode (not in shooting mode).
When you connect the other end to the computer,  There should be a popup asking you what to do.
If there is no popup,  Open Windows Movie maker and import video from device. You should see the camera in it.
Hope it works.
Panasonic PV-GX31 DV Camcorder - Need Help!!
I can't find any reference to a PV-GX31 model, BUT if your camcorder is a PV-GS31 MiniDV model, then you need special software for it to show up on your computer screen. Panasonic supply the software to show and edit still shots (through your USB cable). But if you want to show and edit movies, then you need a firewire cable, a firewire connection on your computer to connect it to, and most importantly some editing software. PCs are pretty slack in this area, so you should use a mac!
Transfer JVC GZ-HD7AATOD Files into IMAC IMOVIE 8
download tod converter for mac program, which allows you convert .tod file into imovie understood video, mp4, mov, dv, etc.
I am trying to find a way to transfer my video from samsung digital cam. sc-dc164 to my computer so i can edit and make dvds. .
Make sure you have a firewire port on your computer. If not, go out and buy a firewire card. Then purchase a firewire cord. plug your camera into the firewire port using the firewire cord, boot up your video editing software (I use Adobe Premiere, personally. Final Cut Pro is the best to use if you're running a Mac), and capture your footage. Edit your footage if you'd like and all that stuff, and then export the video to your desktop. You'll then have the same quality of what you shot in one file.
Sony DSR-45 Lost Firewire Signal
Port's fried for sure -- that's a classic Firewire Port Burnout problem. Could be a cheap repair if you can take it to someone who's not afraid to get their hands dirty (soldering, perhaps). I don't know how integrated the port is to the unit (like on a laptop) so good luck!
Help meeee pls! JVC mini DV cam problems
just joking althoe macs are crap tho,you need a firewire cable and firewire support on your mac its that easy,you just plug in and the pc does the rest,not sure about mac thoe cause there crap
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
