Question about Refrigerators
I have a hotpoint ctx16bazbrwh. Recently the frige part has stopped cooling but the freezer is still working fine what can it be, what should i do? it is a top and bottom, freezer on top.
  • 572 Answers
Ice blockage occured. check the damper in back of fridge to check air flow. usually when the drain is clogged it acumulates water causing it to freeze on the damper causing blockage
Posted on Feb 05, 2010
The evaporator fan is blowing the freezer works fine but the frige don't,?? what else can i check?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 14, 2011 | Hotpoint-Ariston HSS22GFTWW (22.0 cu. ft.)...
Freezer works frige dont unplug for an hour then it works .
I would suggest check the coils to make sure they are clean . Also check the fan which cools the compressor to make sure it is working . When you unplug , it gives the compressor time to cool down a bit , but after it restarts , it will get hot again and stop cooling .
Jul 06, 2009 | Refrigerators
Hotpoint FFA71 fridge and freezer suddenly stopped working
Sounds as though the compressor has stopped working. It feeds both compartments with control from a printed circuit above the top door.Where all your red lights are ablaze! (This can be replaced by removing the 2 screws and "clicking" out the small panel) Check that the compressor is running at the bottom rear of the fridge/freezer before anything else.
Jun 30, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Frost build-up causes cooling to stop
Sounds to me like a intermittent defrost timer not advancing.
It is located behind the plastic cover over the controls.
Remove the switch knobs, then remove the cover. The defrost timer access is on the right hand side. You can turn it with a flat blade screwdriver. Turn SLOWLY clockwise until the compressor kicks OFF. That is when the defrost heater is energized.
After a few minutes you may be able to hear a sizzling sound from the freezer. That would be defrost water hitting the defrost heater.
If it does the defrost at this point, replace the timer. about $30.00
Mar 28, 2009 | Hotpoint Refrigerators
Freezers cold but refrigerators warm
see if there is a big block of ice on the back plate in your frige, if there is then your thermostat is set to cold or broken. if no ice in the frige then it has a gas leak!
Dec 27, 2008 | Magic Chef MCBR440 Compact Refrigerator
My freezer is working but my frige is not cooling
wrong model # ,defrost problem. remove freezer panel, check heater, check limit switch while still covered in ice, if both ohm infinity, replace defrost timer.
Sep 15, 2008 | Haier HTP18GAA Top Freezer Refrigerator
Refrigerator side not working
The freezer is workig fine but refrigerator side is not cooling.
Jun 10, 2008 | Whirlpool GS6NBEXR Side by Side...
Hotpoint ultima fridge freezer
It's just simple.Keep the refrigerator open for few days with power on.After when the electricity bill comes,eveerything will be cooled.
May 28, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
100 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
