Question about LG WM2277HBW XL Front Load Stackable Washing Machine
My LG Tromm WM2277HB washer shut down during a power surge and will not power back on. Have unplugged for several hours, still no good. Looked at solutions posted on this site and it appears my PCB board may be bad as I checked getting 120V coming in but no LED light and about 10V coming out to front panel. How can I be sure it is the PCB main board and not something else causing it not to power on.
  • LG Master
  • 12,061 Answers
Well I for one would go along with your prognosis, it seems logical to me.. this IS a common occurance when this type of thing, a power surge happens.. Remember Occam's razor.
Posted on Feb 05, 2010
My LG steam/washer, 2 years old, power switch does not stay on after pressed. It turns on and turn off right away
Posted on Nov 05, 2013
My LG TROMM Hot water continually fills even after machine is turned off and unplugged. I have to shut off water supply to stop it.
Unplug the washer removing all electrical power from the machine. Turn the water back on and confirm that water is still entering the machine.
If the condition is true no power to washer and water enters machine it is very likely that the fill solenoid has failed.
this part is not that difficult to replace.
Water Inlet Valve part 5220FR2008F LG Washer Repair
Dec 31, 2015 | LG Washing Machines
Washer was spinning out. It got unbalanced. And stopped before I could get to it. Now it won't start. Why?
try unplugging and plugging back in. if that does not work, try unplugging and then plugging back in while holding down the power button. good luck.
Mar 03, 2015 | LG 4925ER1015B 4924ER1010 Used Frontload...
Hello, I have a front load LG TROMM WM2277HB and yesterday it wouldn't spin anymoreand there was a noise coming from inside like 2 metal cylinders were rubbing on each other. I called SEARS Serv
if the machine fails to spin and makes noise there are thee things to check .if it fails to drain the water check if something is stuck on the drain pump no 2 turn the drum with your hand and check if the drum is moving freely if not something is stuck between the drum and the housing if the bearings are faulty the machine spins but makes alot of noise towards the end of the cycle i hope this will help you.
Jan 21, 2013 | LG 4775er2002a Door Hinges for Wm2277hb...
LG TROMM WM2277HB Washer will not dispense Bleach from the Bleach compartment. Thank you.
Pull out the dispenser drawer far enough to be able to just see the tray with the bleach in it, select the (final?) rinse and check that water is entering the tray. If it isn't there is a fault with the water distribution and an engineer call is required ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 19, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I HAVE A LG TROMM WM2277HB and its not spining i keep getting a LE ERROR CODE
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Jun 12, 2009 | LG WM2277H Stainless Steel Front Load...
LE Error Code on Tromm LG WM2277HB Clothes Washer
http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf page 18 of this service manual elaborates on the LE error code and what to check.. Hope this helps you..
Regards
Sep 19, 2008 | LG Washing Machines
Washing Machines Logo
444 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
