Question about Canon MultiPASS F60 All-In-One InkJet Printer
Canon F60 Multiprinter printing random light lines.
My f60 has started printing random whole lines very light (every 3 or 4 lines). I have tried the maintenance cleanings with the menu button..no help. I have also cleaned the printer head well with alcohol - no help.
    Scholar:
  • 51 Answers
I had a case just like yours where the printer wasn't in use for some months because there was a second, better printer to use instead. So when the abandoned one was to be used again, it was no longer salvageable. And I tried cleaning it and maintaining it doing everything in the book to make it work again but no matter what I did, it ended up in the garbage bin after all my wasted time and effort. I'm sorry. I wish I had better news for you but I'm speaking from experience. Yours might be a write-off too in which case you are better off to just buy a better one.
Posted on Feb 05, 2010
My MultiPass F60 Alarm light is blinking. It says "Check Printer/Press Resume". I have swabbed print head with alcohol to clean it. Could waste ink tank/reservoir be full. If so, where is it located and...
Fello there try
This works on the F30, F60, and F80.
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Skip step (6) since there is no [OK] key on F30 printers.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 27, 2009 | Canon MultiPASS F60 All-In-One InkJet...
Stripes printed on every picture
go through your printers software in your start menu and clean the heads.
Aug 21, 2009 | Canon PIXMA MX850 multifunction InkJet...
Cannon multipass F60 scanner/printer striped color printing
What you have is a dried up color cartridge. You can try to use the <clean print heads> in the diagnostic tools section of you priner software. (usually, just try to print something & the window will appear) Sometimes you have to clean heads, then print test page like 2 or 3 times before it clears up. If that doesn't correct it, don't worry. Have your color cartridge filled (staples, office depot, & other stores do it cheap) - or - replace it with a new cartridge. You may have to run the clean print heads program after installing a new cartridge, but this will definitely fix your problem.
Jul 26, 2009 | Canon PIXMA MX850 multifunction InkJet...
Will not print canon multipass f60
in colour printers tat too in canon the printer will work only if both the color and black catridges r filled with ink otherwise it wont work
Mar 17, 2009 | Canon MultiPASS F60 All-In-One InkJet...
Canon MultiPASS F60 failure to communicate
Go to this web site. In the search window in the center of the screen, type "windows xp drivers" and click on the Search button. Select the first answer that shows, and you will receive instructions for downloading and installing drivers which were developed for using the MultiPASS F60 with Windows XP SP2.
Sep 26, 2008 | Canon MultiPASS F60 All-In-One InkJet...
Is the canon multipass f60 compatible with windows vista (on an hp laptop)?
Canon does not offer Vista drivers for the MultiPass F60. Vista may have some generic drivers that will work, so don't delete or over-ride them in the system.
The major problem is that the printer only supports USB 1.1 and not USB 2.0
Here is a link to Canon's MultiPass F60 Printer site ...
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=7174
Sep 20, 2008 | Canon MultiPASS F60 All-In-One InkJet...
Canon MultiPASS F60 Problem
ok maybe the nozzle is blocked (specially if u didnt use the printer for a while
so try to clean the nozzles
and by the way in the cartridges there are some kind of plastic strip did u remove that before installing the cartridge in ur printer???
that should be it my friend
cheers
Jul 06, 2008 | Canon MultiPASS F60 All-In-One InkJet...
Help, Multipass F60
This will be very expensive to repair.
I,d suggest That You Pay The $19.99 Premium support Rate offered on this Site, which is £10.00 G.B.P.
where a technical specialist, will be only too happy to assist You further.
I hope this Has helped your enquiry.
Mike @ compurepair.
Mar 01, 2008 | Canon MultiPASS F60 All-In-One InkJet...
Canon f60 print check
i cannot print alarm light is on window reads "waste ink near full"
Mar 04, 2007 | Canon MultiPASS F60 All-In-One InkJet...
Canon f60
before you clean your printer head, try identify if there're other problems, for example maybe your ink is running low, this will cause bad quality printing. To clean your printer go to control panel, click printers and other hardware, click printers, right click on your printer icon and select properties, click on the tab maintenance and you will see what options are availible. In your case my look for something said cleaning. (NB: this is winXP)
Feb 28, 2007 | Canon MultiPASS F60 All-In-One InkJet...
Canon MultiPASS F60 All-In-One InkJet Printer Logo
60 people viewed this question
old marine
old marine
