Question about Emerson EWV601 S-VHS VCR
Magnavox VCR has a stuck VHS tape, need to remove it safely. Please advise.
  • Emerson Master
  • 12,061 Answers
Well I have done it by, remove from power and wait 10 mins, then removing the cover and locating the white worm drive & motor usually at right side of tape tray, then manipulate that worm with your fingers and "Wind" it out.
Posted on Feb 05, 2010
VHS tape will not eject and unit shuts down
It's not loading correctly. You need to open the cover (unplug first) and get familiar with the loading mechanism. You can get the tape out by rotating the loading motor wheel.
Mar 22, 2015 | Magnavox ZV427MG9 DVD Recorder/ VCR
I hav a magnavox mwc24t5 triple combo. When I put a vhs tape in it spits it out. Sometimes it gets stuck in there and I have a time trying to get it out.
Please check your VHS tape's CONDITION. See if U can play it on another VHS. BE CAREFUL. sounds like a damaged VHS. You might need to take that to the shop. Better to have it checked than damage your materials. Had a similar situation with a DVD/VHS. Finally, the VHS got stuck inside. Thankfully the shop fixed it but my VHS never worked again properly.
Dec 20, 2014 | Televison & Video
Power off when inserting vhs tape
I had this problem when copying an old family vhs tape. I had to unscrew the top of the magnavox to access the vhs tape. Then, I gently removed the tape and replaced the cover. After winding the tape back, I put it in the player and immediately pushed fast forward for about 3 seconds before hitting play followed by d.dubbing. I was able to make a copy of the tape and did not damage my original.
Jul 30, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Vhs tape stuck in vcr
Some one needs to open it to see if the tape is loaded but wrapped around a post or tangled up.
What usually causes this is the mechanism that moves the tape has a problem---bad or broken belt or rubber drive wheel that moves tape is bad.
Its called eating tapes.
With it apart you may be able to extract the tape and then insert with it apart to see if reels etc are or are not moving in RR and FF first and then in play to see what is not moving.
May 26, 2012 | Magnavox ZV450MW8 DVD Recorder VCR
My vhs tape is stuck in vcr it is a toshiba with vcr and dvd combo?
The only safe way to remove the cassette without damaging anything in the vcr is to remove the vcr and carefully remove it. Don't force anything. It can be accessed by removing the rear cover. There should be two srews holding the DVD/VCR mechanism then pull the whole "tray" out at once. There may also be a metal cover over the vcr section. Just follow the screws until you can see where the tape is caught. Thanks for using fixya.
Nov 28, 2009 | Toshiba Televison & Video
Tape stuck in vhs players
Yes you can cut the tape, remove it and then go to radio shack or walmart electronics dept and get some special vhs repair tape.
Apr 27, 2009 | Sony SLV-D300P DVD Player/VCR
Magnavox VCR/DVD player CMWR 20V6
The same thing happened to me and it is the power supply. You can get a new one at parts@funaiservice.com
Nov 26, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox TV: Somehow the record button on the remote will not record VCR. It ejects the tape and does not record. Please help. Thank you.
Try Using a new VHS tape. If the new tape ejects when press recording, the recording switch inside your VCR could be defective.
Let me know if you require further assistance.
Aug 26, 2008 | Televison & Video
Dvd to vcr?
Plug the DVD connections into the INPUT on the back of the VCR. This is sending the signal from the DVD player INTO the VCR.
If you are familiar with the VHS to VHS, then remove the VCR and replace it with the DVD player.
I hope this helps :)
If the question changes it will send me an automatic message. So if this was not enough info, just let me know! I'll actually hook mine up to record this way then I'll be able to tell you step by step if need be.
Jan 11, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Emerson EWV601 S-VHS VCR Logo
653 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
