Question about Toshiba 57H82 57" Rear Projection Television
I could hear the backround music somewhat, but the voices are really really low. The problem started last night when i was changing the tv settings
  • jl_morales_6 Feb 06, 2010
    AUdio
    mts -stereo
    bass-50
    trebble-50
    balance-0
    reset
    sbs - ON
    sbslevel-50
    speakers-on
    audio-mai
    stable sound-on
    Theather
    Srs3d-on
    Cinema mode-wide
    I have the volume all the way up but could barely hear the voices. The backround sounds loud, but the voices really low.
  • Toshiba Master
  • 5,807 Answers
a ) Sometimes it happens , presumably it is caused by these transistor
these Q683 mutes pin 11 of IC TA8216
b ) if trying to unmute using the remote wont do, you may need to
temporary extract these transistor for the process of eliminating
the cause.
c ) If it works, then " b " ( base of transistor ) is high, or you
can use a multimeter to measure voltages on the base of the
transistor
d ) There could be other causes like the Audio IC ( TA8216 ), which is
less likely , although possible .
e ) if you have a signal tracer you can verify audio signal from pin 2
of the Audio IC if the audio signal is present.
Posted on Feb 06, 2010
  • 3 more comments
  • Rommel Cana
    Rommel Cana Feb 06, 2010
    you can also try these:
  • Rommel Cana
    Turn OFF SBS
  • Rommel Cana
    try also turning these off
  • Rommel Cana
    On your settings
    SBS - ON change these to OFF
    SRS3D on change these to OFF
    Stable Sound change to OFF
  • Rommel Cana
    hope these helps
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
Look in the customer menu for what may be advanced audio choices--some of these sets had a feature called steady sound or something similar---background will be louder than people speaking.
In some versions it is also called hall effect, etc.
Let me know what the options in the 'AUDIO" and "THEATER" MODES are as it has to be one you changed.
SD TECH
Posted on Feb 05, 2010
  • 2 more comments
  • SD Tech
    SD Tech Feb 06, 2010
    Turn SBS and STABLE SOUND both off----ONE OF THEM IS CAUSING THE PROBLEM.
    let me know.
    SD TECH
  • SD Tech
    IF neither of those turn 3d off in theater mode.
  • SD Tech
    Did you get it working right?
    Please let me know.
    SD TECH
  • SD Tech
    If the information I gave you solved your problem rate mine 4 thumbs up and DO NOT rate any other attempted answers or I will not get credit for having solved your problem.
    SD TECH
WHAT SHOULD I DO THREE OF MY SPEAKERS DOES NOT ON TWO REAR L-R AND THE CENTER I PLUG IN THE BLURAY PLAYER AND FROM THERE USE MY HDMI FROM THE BLURAY PLAYER TO THE HDMI ON THE SAMSUNG FLATSCREEN TV ANYONE ...
Hello there,
It sounds like everything is working correctly to me. Voices / spoken dialogue should mostly be from the front speakers and surround audio (music, effects, etc) from all speakers.
The TV screen is in front of you so the people on the TV screen are also (technically) in front of you. Naturally, I would expect the spoken dialogue to come from the front speakers only - except in some instances, where dialogue in the movie is from a character not currently on screen. If you had voices from both in front of and behind you when the characters are only in front of you, it would be totally disorientating.
If you have audio from all five speakers during a movie then all of your connections and settings are correct. The problem you are describing is really just a description of how surround sound works.
I hope this helps. If I misunderstood the question or the problem, please let me know.
Regards,
BElectric.
Mar 08, 2011 | Samsung Audio Players & Recorders
Back ground music louder than voices watching movies on cable
Is this a new problem or always like this? <<<<<<<<
What is your speaker complement? The center usually carries the dialog.
Are the receiver and its speaker systems set up per the manual? Make it so.
How is the TV-related (Cable) audio entering your receiver? It SHOULD be from the cable box, digitally if available, NOT the TV. You don't need a Low-Fi middleman handling your audio.
Mar 05, 2010 | Denon AVR-3805 Receiver
Backround sound is fine but voices speaking are muted
I'm not sure of this system but if this was mine I would say it sounds like your playing this in a 2-Channel mode which eliminate the center channel.
you music may be set up fine, but the mode you play a dvd in may be set up for 2-channel mode. try a dolby prologic 5-channel or some other mode if you have one.
Mike
Oct 18, 2009 | Audio Players & Recorders
The background music is louder than the voices
try resetting the equalizer in your wm player...
May 22, 2009 | Microsoft Windows Media Player
Rx-v563 backround music much louder than people when watching tv
I would check your center speaker wiring and setting. Then switch to a different audio setting (pro logic, theater...)
Jan 12, 2009 | Yamaha RX-V563 Receiver
We have a Technika DVDR2005 DVD player and it is only playing the backround audio i.e. music etc but not the full sound with voices. We've tried all of the audio setting but it won't work! It's not the...
Hi Rachael, I dont know anything about your DVD player itself but from what you have said assuming you have a stereo TV and you can only hear music etc from both channels in a movie then you MIGHT have it set for 5.1??, which means instead of everything coming out of the L+R the VOICES and music etc are being sent to the CENTRE CHANNEL and the other channels.
As I dont know that model, all I can say is try menu or options etc and go to audio and change the output for stereo. (You said you tried AUDIO but I am assuming you mean the audio button on the remote which changes between the audio versions on the DVD Disc.)
or maybe try checking the cables, what ones are you using? Scart? Composite? maybe the audio cables have been plugged into the wrong sockets on the DVD player if it has multiple outputs on it?
I dont know what else to say... But the above 2 options are worth trying. I hope you get it sorted OK :) Bye.
Dec 20, 2008 | Televison & Video
Can't hear voice/some audio
your audio setting is set to 5.1 and your do not have enough speakers to hear all the sounds. I suggest to change the setting to 2 speakers and you will be able to hear everything. good luck
Apr 03, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Actors voices
Hi....
If your system is set up for surround and you dont have a center speaker that will happen.
Check the manual for best setup
Jan 05, 2008 | Pioneer VSX-D711 Receiver
Sometimes voices are low on playing of music/films
hello Mike
Well, it sound to (recording ) on each songs, depending on how it record, if happen only with some , it is no problem but if all songs you play happend then its a problem with the drivers, or program to control your music, try to down a notch on control panel the hardware acceleration. it solve a lot problems of this kind, or reinstall the drivers for the sound card.
Good Luck
Nov 20, 2007 | Logitech X-530 Computer Speakers
Toshiba 57H82 57" Rear Projection Television Logo
303 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
