Question about NetGear WGR826V Router (wgr826vna)
Sorry silver dragon did all that already with port after port...no joy...I understood the manual, however after trying and checking 100 or so ports not one was connectable via PFPortchecker, zip...Nada...NO JOY...
  • mazehere Feb 05, 2010
    the manual is also incorrect; when creating a new service to un-dissallow (which is the clear as a brick part as that phrase is non-phrase as it cancels itself out), you cannot leave the second field blank the router's GUI wont let you save if you do so to use only one port not a range you have to enter it twice. The router is fresh out of the box two days ago so its not dead, Internet is working fine am using to send through now, just wont forward, I asked because perhaps there may have been something I missed...But now Iam simply convinced this router is a piece of junk with major flaws...Think I'll just buy a Watchguard Firebox and get it over with tired of playing with the junk Cisco puts out since Linksys bought Netgear, and Cisco bought Linksys they have all been garbage!
  • 12,061 Answers
Hmmmmm yea ya sounded pretty savy... Well maybe router is kaput, I reckon ya woulda figured it by now, when this happens to me, it is usually the hardware?
Posted on Feb 05, 2010
  • electronic & computer repair&  servicre
    Yes I see what ya mean, so you liked my Un-dissallow did you.. yes that sorta describes the manual beautifully, . .you know I wonder if maybe it just fowards ALL ports hey I see in the manual there is a place 6.4 Select NAT mode.. have a look there, see that well maybe that will work?
Does the Dragon Touch 10 have a sim port?
The Dragon Touch X10 is a tablet, not a phablet. It does not have a SIM card slot or any cellular connection hardware. The same is true for the i10X and the V10 Dragon Touch models.
I hope this helps.
Jun 03, 2018 | Dragon Cell Phones
Need motherboard manual for soyo k7v dragon plus
SY-K7V DRAGON Plus! - SOYO
AMD Socket-A Based VIA KT266A Chipset ATX Motherboard
AMD Recommended Motherboard
D: DDR266 SDRAM
R: Promise IDE-RAID (0,1)
A: CMedia 8738 6-channel hardware audio on board
G: Universal AGP Pro slot
O: Overclocking, set up FSB by 1MHz increment
N: 10/100 Mbps Ethernet by ICS PHY Controller
Specifications
Processor
Click here for maximum CPU support
Click here for maximum Front Side Bus (FSB) support
Interface
Socket "A"(462)
Chipset Type
VIA KT266A
Chipset Description
VIA KT266A / 8233 CE Version Chipset
Supports 200/266 MHz FSB
Form Factor
ATX
Memory Type
DDR SDRAM
Memory Description
Three DDR 2.5V DIMM sockets support up to 3GB*.
184-pin PC2100/PC1600 non-ECC, unbuffered DDR SDRAM memory.
*recommended to use 3 sticks of DDR200(PC1600), or 2 DDR266(PC2100) memory on this board.
Expansion Slots
Five 32-bit Bus Mastering PCI slots (V2.2 compliant)
One Universal AGP Pro slot (supports 1x/2x/4x modes)
Expansion Slot Types
IDE Type
UDMA 33/66/100
IDE Description
Four independent channels for 8 IDE devices (2 for RAID)
Supports up to PIO mode 5 & Ultra DMA 33/66/100
Two PCI bus mastering ATA E-IDE ports
Audio Description
On board CMI 8738 audio chip providing 6-channel audio solution
IO Port Description
Two RS-232 serial ports (16550 UART compatible)
One parallel printer port (SPP/EPP/ECP mode)
One FDD port (supports 3 modes, 1.2/1.44/2.88MB FDD)
Provides IrDA with optional cable for transceiver
Provides 6 USB ports (2* rear, 4*front)
IO Connection Description
PS/2 Mini-DIN mouse & keyboard ports
Two USB ports
One RJ45 connector
Two D-Sub 9-pin male serial ports
One D-Sub 25-pin female printer port
Audio I/O: LINE-OUT x 1, LINE-IN x 1, MIC JACK x 1
One game port
BIOS Description
Award PCI BIOS with ACPI function
Supports multiple-boot from E-IDE / SCSI / CD-ROM / FDD / LS120 / ZIP
2 Mbyte Flash ROM
Health Monitoring Description
On board voltage monitors for CPU Vcore, +3.3, +5V & +12V
CPU fan speed monitor
CPU temperature monitoring through flexible thermal sensor
Dimension Description
Four layers, 30.5 cm x 23 cm (12" x 9.05")
ATX form factor
Certification
FCC Class B & CE EMI Regulation CompliantPC99 Compliant
Compatibilities
WinXP / Win2000 / WinNT / WinME / Win98SE / Linux / FreeBSD
Warranty
All SOYO products are designed to offer stability and flexibility, and are tested to ensure highest reliability. We offer a 1 year limited warranty on this SOYO product.
CPU Support
Compatibility
RAM Memory Support
Compatibility
Manufacturer - downloads drivers, manuals and BIOS : SOYO
Prodejce v èR : Mo?nost vlo?ení odkazu prodejce - info zde
Recenze : Odkazy na recenze vlo?íme po dohodì
Problems, experience, griffs.....:
Jun 06, 2010 | Computers & Internet
Hp PSC2355 scan function inop
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
aswq9
Aug 25, 2009 | HP Officejet 5610 All-In-One InkJet...
My packard bell has stoped charging
If your laptop has stopped charging and you've already replaced the AC adaptor, then most likely it's either the battery itself or the power port on your laptop. If the battery was fine up to that point then it's probably not the battery. To replace the power port can sometimes involve soldering the new port onto the motherboard of your laptop so it's usually best left to a professional. The port you can usually find on ebay. I've replaced a few that is just a small power board that plugs into the mainboard but other have to be soldered. It's not really hard to do, but it involves dismantling the whole laptop to gain access to the motherboard and sometimes requires soldering. Sometimes its very obvious and you can tell by trying to move the metal pin in the center of the plug on your laptop where it plugs in. If the center prong moves then it has become detached and must be replaced. If not it could also be a connection problem due to corossion. Without pulling it apart and looking at it, it can be hard to tell. Deptending on the extent of the work, it can cost from 50.00 - 200.00. I hope this helps.
Apr 17, 2009 | Packard Bell Easy One Silver 2120 Notebook
I need the manual for a soyo sy-kt400 dragon lite motherboard
Hi freebird2k6,
Go to this Soyo link:
http://www.soyousa.com/content/Downloads/155/&c=35&p=173&l=English
Drivers, bios & manual located on this site.
Manual is at the bottom of page. (Soyo no longer supports the board so download everything & burn it to CD).
Soyo may stop listing these drivers soon.
Mike
Dec 31, 2008 | Soyo SY-KT400D DRAGON Lite Motherboard
Router gateway error
Problem sorted not quite sure how but it is just tried one more time to log in and it worked??????????
cheers
Jul 25, 2008 | Gateway Wireless-B Router (wbr-100)
TI-84 Plus Silver Edition - Slow or no response
Blow in the i/o socket on top of the calculator. There's probably some dust stuck in it or something.
Mar 13, 2008 | Texas Instruments TI-84 Plus Silver...
TOSHIBA e-STUDIO16/20/25 PCL 6 Installation Problem Mac OS.
You will need to do it through a server LIKE WINDOWS 2003 SERVER , and set up a print server role on it, this allows multiple protocols to be understood ,, including windows, linux, mac, os2 freebsd etc...
Jan 17, 2008 | Office Equipment & Supplies
NetGear WGR826V Router (wgr826vna) Logo
29 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
