Question about Tascam 2488 Portastudio Multitrack Recorder System
2488 Mk 1.
I just purchased a 30 month 2488 Mk1 s/hand.The seller hasn't used it for quite a while,and has said it was working fine..it appears that the stop button doesn't do anything,also,with a guitar in there is input on the meters but nothing thru the monitor..except when using the tuner.all I've done is to delete the existing songs.Is there a total reset option thru a combination of buttons?Thanks in advance..Mike ...Oxford UK.
  • Drizabonio Feb 27, 2008
    Thanks for the reply,as you rightly point out the stop button seems to just be dirty or something,if you press it quite firmly it operates,but cleaning would be the obvious first step,as for the other issues,I seem to have those more under control,the manual seems to be a bit curious,to say the least..But I have taken to checking other forums as well,and there seems to be far more information out there than I would have imagined.again,thanks for the reply and many thanks from jolly ol' Oxford(the original one)
    yours Mike..
  • vandyke Sep 07, 2008
    Is there any danger of messing up my Tascam 2488 if I remove the cover to see if the stop button is dirty? Because I have just developed the same problem. My 2488 dosen't stop when I push the stop button PLUS if I press rewind and the stop button at the same time it returns to zero and starts to play from the beginning instead of just stopping like it used to do. What do I do HELP!!! This one of my main pieces of recording equipment.
    Thanks. Thomas - anotherapproachmusic@yahoo.com
    Novelist:
  • 189 Answers
Hi Mike,
To reset the 2488 to factory defaults: Simultaneously press quick routing/shift/send/shutdown & turn on the unit.
The 'stop' button problem may require a look under the cover to see if the button is dirty or damaged under there. A good cleaning might do it. As for the 'no guitar out the monitors' issue, this sounds like it might have something to do with the setting of the monitor selector. Make sure it's set to 'stereo' and not effect loop or effect send or even muted. You might want to also make sure your monitor level pot is working properly.
Best of luck.
D.
Posted on Feb 27, 2008
Can't figure out how to mix down tracks to stero master on 2488 mk 2
Your owners manual can be found at manualslib.com by searching your model number and choosing manualslib under the heading TASCAM 2488MKII OWNER'S MANUAL Pdf Download.
Tascam has a help line at 323-727-7617. If you haven't done your homework in deciphering the users manual, I would not call them. Their service is free, but their on phone time for help is limited and they can be quite surly.
Dec 16, 2017 | Tascam Audio Players & Recorders
VW Golf 1600 ignition wiring diagram
in usa (are you?) we use the Factory FSM.
if in a rush, we go to alldata.com and its all there, no where as detailed as the real deal the FSM. but pretty good. or at michells.
diesel ignition? huh? (in blue box above?)
Dec 10, 2013 | Vw Mk1 Rabbit Caddy Jetta Pickup Golf 1.6...
MY PC wont recognize my Tascam Portastudio device2488, i have Vista
Tascam 2488:
I use Vista and my 2488 MK1.
When you plug in the USB cable from the 2488 into your Vista PC, Vista will always say 'not recognised'.
You do not need any PC drivers for the 2488. On the Tascam 2488, go to 'Menu', then 'Disk', then 'USB Open/Close', then click 'Yes'.
On your PC the 2488 will appear as a new hard drive in the 'Computer' folder, called HDR2488.
You'll see three folders in there: WAVE, SMF and BACKUP.
Use the WAVE folder to import and export WAV files, the SMF folder to import midi files to the 2488, and the BACKUP folder is where you can import and export Backup files to and from the 2488.
Hope this helps!
May 09, 2012 | Tascam 2488 Portastudio Multitrack...
Mk 4 golf, remote key not locking/unlokcikg doors?
unlock with key and hold key over for 30 secs(windows may go down)then lock with key and hold over for 30 secs(windows may go up)then press remote unlock button and hold for 30 secs,you have just reset system...the closer you have to get to the car for the remote to work the lower the battery power.sensor on top of dash(little black dimple)rarely,if at all, goes wrong.....
Jun 11, 2010 | 2003 Volkswagen Golf
The click track on my TASCAM 2488 Mk 2 won't click
There is likely an amplitude setting (probably available in a menu) for the click. Make sure that is turned up.
Jul 18, 2009 | Tascam 2488mkii 24 Track Recording...
Screen lights up but cannot see or read anything
This issue just popped up on here a couple of weeks ago. Here is a copy of that exchange which might address your problem too:
posted by calman71 on Nov 01, 2008 screen lights up white, no picture Best Solution posted on Nov 03, 2008 3%20stars.png
BostonDave The only thing to try would be to locate the contrast knob next to the screen (near lower right of screen) and turn it to see if the picture gets better. I have the Mk1 which has a green screen, but I find that one is only visible when the contrast knob is pretty much exactly on center.
If that doesn't do it, I would begin to suspect a loose connection behind the LCD screen. You could probably remove the cover and locate the connector yourself, but depending on how old your 2488 is doing so might effect the warranty.
Cheers.
bd. Comment by calman71, posted on Nov 06, 2008 Turns out to be loose wires.Thank you for helping ,
Nov 14, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio screen.
You could add an HGR monitor interface module to display the 2488 on a PC monitor.
www.hgr2488.co.uk
That way you don't need to look at a damaged display and the 2488 (MK1, MKII and NEO) work just like before.
Aug 31, 2008 | Tascam 2488 Portastudio Multitrack...
BURNING A CD 2488 MK.1
you have to mix it down and master it first
Jun 21, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
285 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
John
John
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
