Question about Baby Gear
S10 4.3 liter -
Which repair manual can I get that tells in detail how to replace valve guide seals in a '93 S10 4.3 liter?????
Never mind. Chilton is the best
Posted on Feb 21, 2008
Replacing timing belt??
The alignment marks on the cam gear will tell you that. You did not mention what engine you have. 2.5 liter or 3.0 liter
May 02, 2014 | 1992 Plymouth Acclaim
Whats wrong with a 93 volvo 850 when the timing belt breaks but then repaired but the car dont run
U have bent the valves ..........when the belt broke......... i presume u have timed the engine properly, u could do a compression check to make sure,........ but sounds like a new head is nessary or take to garage very extensive job will cost a lot
Oct 10, 2013 | J Concepts Bar Codes 2.2 1/10 Truck Tire...
Why does my 93 toyota pick up smoke oil when first turned on
You need to have the cylinder head rebuilt, possible worn valve guides and valve guide seals leaking.
Sep 03, 2012 | Cars & Trucks
When it idles for a while and then you step on the gas blue smoke comes out of the tail pipe 2004 BMW X5,4.4 with 90000km
you have the n62 engine in this x5 valve guide seals are leaking causing the blue smoke but i hate to tell you people havnt had much luck with repair in fact i am replacing the cylinder heads on a 750 with the same engine right now after an attempt to replace the valve guide seals failed to resolve the problem
Jun 08, 2011 | 2004 BMW 5 Series
93 sundance 3.0L replace the valve seals
it is more than just the valve seals.the 3.0l engine is notorius for the valve guides slipping down into the valve pocket. there is a fix that involves adding a keeper to prevent them from falling but it requires removing heades and taking them apart. yours may have already have had this done so valve seals may fix it.
yes you can change without removing heads you need to have piston at the very top off stroke if off by a little the piston will be forced down by the air pressure so somehow locking crankshaft from moving would be a good idea.
remove plug from a cyl and fashion or buy a fitting to screw into plug hole that will also hook up to a air hose from a air compressor. the air pressure holds the valve closed then you will meed a valve spring compressor designed for removing the springs with head still installed. can rent them at auto parts stores.remove spring and replace seal. then reassemble and move on to the next
but sometimes the valve opens or piston moves down and the valve falls into the cylinder. you can pull it back up and try again or just take the heads off.
my recomendation is just take the heads off they are fairly easy to remove and instal. then have machine shop cut the grooves in the guides and install keeper clips
Apr 04, 2010 | 1993 Plymouth Sundance
How to change a valve seal on a Dodge Ram pickup V6 3.9 liter
replace valve guide seals in a 1999 dodge dakota 3.9
Sep 26, 2009 | 1998 Dodge Ram 1500 4WD
V6 XLE using oil huge white smoke cloud on cold start but not on hot start.
You have what is known as a valve guide or valve guide seal problem. as the car sits, the residual oil in the valve cover is seeping into the cylinders through a faulty seal or excessive clearance of the valve guides and is now sitting on top of the pistons, so when you start the car. it burns and goes out the tailpipe. Id recommend you take your car to a certified engine repair facility to have it checked for repair. "Valve guide seal" replacement can be done without too much headache . If the "valve guides" need to be replaced, then the cylinder head/heads must be removed. and this is a lot more costly.
Aug 23, 2009 | 2002 Toyota Camry
List of all components for a top end rebuild. Is there a kit out there?
  1. Piston
  2. piston rings
  3. head gasket
  4. Cylinder base gasket
  5. Fresh bore on cylinder (if it can be bored), see note
  6. Possibly valves, valve guides and valve seals, see note
  7. Miscellaneous seals and gaskets
NOTE; some cylinders are nickle plated and can not be bored unless re-plated. If cylinder is beyond repair then replace it. The valves should be re-seated. If any dishing or valve stretch is present, the bad valves must be replaced. Valve guides seldom need replaced but valve guide seals could be bad. If the bike gives a puff of white smoke when started after sitting for 5 or 10 minutes then replace the seals.
A “very helpful” rating on this answer? Thanks!
Jul 02, 2009 | 2003 Yamaha WR 250 F
1993 TOYOTA TERCEL 1500cc Valve Seals Replaced now smokes much worse
You either have had the wrong valve seals installed, they are physically missing, or the valves are incorrect (too loose in the guides/stem too thin). The rocker arm seals will not contribute to your issue. If it did not have the oil smoke before you took the head off, the issue is with whatever the machine shop did. Valve seals have to fit TIGHT, or oil will go down the valve stem into the intake.
Take the head back to the machine shop & tell them to fix it. For free.
Aug 23, 2008 | 1993 Toyota Tercel
Tub Seal needs to be replaced
This video will show you how to replace the Bosch washing machine door seal with step by step guide on the process
Aug 31, 2007 | Bosch WFMC 3200 Front Load Washer
Baby Gear Logo
42 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
