Question about Miller SPECTRUM 375 PLASMA CUTTER 903891 115 230 VOLT
Miller 375 cutmate no power from circuit board to gun
2 Suggested Answers
CarlGehrke
  • 169 Answers
SOURCE: plug wiring
When wiring a new plug for which voltage input?
The cutter has a white wire, a black wire, and a green one - white is the neutral line, black is the hot line, green is ground.
You can see this in section 4-9 of the owners manual, if you don't have a manual you can go to www.millerwelds.com and get a PDF file of the manual.
Rank this answer please,
Carl
Posted on Dec 02, 2008
Esab plasma cutter fault light comes on as soon as it is turned on
The cable or cutting head may be damaged. The power connections may be loose, an internal circuit breaker may have failed. If the cooling fan does not come on, check the wiring in the cabinet for damaged wires. Disconnect fan wires- noting where each connected and check to see if the fan burned out- if it did, replace the fan and it chould begin to work correctly. If the fan checks out okay- it will have 2 discrete sets of windings-one for the fan, the other to provide control voltage.Check that board with the rectifiers as a rectifier may have failed or there may be a fuse on the board.
If it were mine, I would check everything under the cabinet after it has been thoroughly blown clean.
Sep 06, 2012 | Miller Spectrum 375 Cutmate Plasma Cutter...
Spectrum thunder plasma cutter will not cut steady, keeps stopping and have to pull trigger to cut
Check the contactor contacts for pitting. if severly pitted, replace contactor. If a death grip on the switch makes it work better then a light touch- replace the trigger switch.
Aug 17, 2012 | Miller Spectrum 375 Cutmate Plasma Cutter...
Green light flashes
always remember the ground...
have a big air supply. small compressors can not keep up and machine stops cutting.
Nov 24, 2011 | Miller Spectrum 375 Cutmate Plasma Cutter...
When you start cutting it will cut about 2 inches and kick out you let off the trigger and pull it back on it will do the same as long as you do that it will not cut continusle please advise does not...
You may need a better air supply. Also check the tip. This sometimes happens with mine when the tip gets pitted, not sure why but changing the tip sorts it out. They are fussy machines in some ways. Dont like dirty material, need a good earth.
Aug 31, 2011 | Miller Spectrum 375 Cutmate Plasma Cutter...
All lights correct, no start
loosen the retainer cap and twist the consumables and retighten
Apr 24, 2010 | Miller Spectrum 375 Cutmate Plasma Cutter...
Plasma cutter no cutting
the tech is probably pretty close to the cost of board,but you may have moisture in air that still wont take out the p.c..you have a warrenty on the unit,go to your local welding store and request a new one if refussed tell them you want to talk to the miller salesman which they should have no problem to set up.if not call miller direct in appleton wisc.they are good people.
Apr 07, 2010 | Miller Spectrum 375 X Treme Plasma Cutter...
How hard is it to change out the main circuit board on a spectrum 375 plasma cutter? What is the cost of the board?
The replacement of a board is no TOO hard, just DRAW a Diagram of ALL connections when you take the "Old" one out. NEVER work on the machine live Duh, also always wait a bit to allow capacitors to discharge, or use a shorting stick, if in a hurry. Anyhow, make sure you keep all fixtures together note down all connections and label them with little stickers, With any other information on the stickers as need be. I always do this as one never remembers whats what after a bit, anyway. Just be methodical, and you will prevail.
Feb 24, 2010 | Miller Spectrum 375 Cutmate Plasma Cutter...
Miller Spectrum 375 problem
It sounds like you have a problem in the power supply input area. Make sure your voltage select switch is in the correct location. Unplug the unit and switch back and forth between the two positions to clean the contacts. Try again. If still bad check you terminal lug connections on the input lead wires. If still bad please answer these questions.
Does the power indicator come on at all? Does the fan start?
Nov 12, 2009 | Miller Spectrum 375 Cutmate Plasma Cutter...
Plug wiring
Carl
Nov 26, 2008 | Miller Welding Tools
Cup light is on machine will not work
The cup light is referring to the outer most part on the torch tip, the purpose of the cup is to create a gap between the tip and the work piece. The light is indicating that the cup is worn and must be replaced.
Nov 09, 2008 | Miller Spectrum 375 Cutmate Plasma Cutter...
Miller SPECTRUM 375 PLASMA CUTTER 903891 115 230 VOLT Logo
123 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
hubiam
hubiam
Level 1 Expert
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
