Question about Kenmore HE2 Plus Front Load Washer
Keep getting error f20 - Kenmore HE2 Plus Front Load Washer
    President:
  • 1,554 Answers
Press the Pause/Cancel button twice to clear the display and cancel the cycle. Unplug the machine and remove the fill hoses from the water inlet valves. Check the inlet screens for clogging and clean it. Make sure that the water supply valves are open and water is present. Check the drain hose for siphoning.
Press and hold the Start button to start a new wash cycle. If the error code flashes again, verify if there is water present inside the tub. Check the water inlet valve if no water is present. Check the pressure switch if water is present.
Posted on Feb 05, 2010
  • Jahn27
    Jahn27 Feb 05, 2010
    Checking the Water Inlet Valve
    1. Disconnect the machine from the power outlet.
    2. Remove the three screws securing the top cover to the back of the machine.
    3. Slide the top cover out to release the console tabs from the slots in the cover and lift it off the machine.
    4. Disconnect the wiring harness connectors from the water inlet valve solenoid terminals. Label the wiring harness to avoid reversal of the connections.
    5. Set the multimeter to X100 and measure the resistance between the solenoid terminals. Resistance should read between 750 ohms and 850 ohms for a good solenoid.
    6. Replace the water inlet valve assembly if any of the solenoid reads open or too far from the range given.
    • Remove the fill hoses from the water inlet valves.
    • Remove the inlet hose by loosening the inlet hose spring clamp and pulling it off the valve assembly.
    • Remove the water inlet valve screw at the back of the machine and pull the valve assembly out.
    • Install the new water inlet valve assembly in reverse of the steps above.
  • Jahn27
    Jahn27 Feb 05, 2010
    Checking the Pressure Switch
    1. With the top cover removed, look for the pressure switch at the rear right side of the cabinet. It has a small hose connected to its bottom.
    2. Press the wire connector locking arms and pull the connector off the pressure switch.
    3. Remove the pressure hose from the pressure switch fitting.
    4. Turn the pressure switch clockwise until the key on it is aligned with the slot in the chassis and remove it from the cabinet.
    5. With the pressure switch terminals facing up and the hose inlet at the bottom, check the continuity (set the multimeter to X1) between Pin 6 (right end terminal) and Pin 4 (third from the right). It should read zero ohms. Continuity test between Pins 1 and 2, Pins 3 and 4, and Pins 4 and 5 should read open.
    6. Blow into the hose inlet to activate the pressure switch diaphragm.
    7. Repeat step #5 above while the diaphragm is activated. Pins 4 and 6 should read open and the rest should read zero ohms.
    8. Replace the pressure switch if it fails in any of the tests above. Install it in reverse of the steps in removing it.
Washer model number WFW9400VE error code F20 keeps coming up. Is there a way to reset?
F20 No water detected entering machine, Defective flow meter, clogged water valve inlet screens.
Duet sport service manual
Jan 07, 2011 | Whirlpool Duet WFW9400VE Front Load Washer...
I keep getting an error code ... F-20. Please
F20 indicates a water inlet problem (no water or insufficient water supply) in your washer. To resolve this issue check your washer inlets, maybe the water valves are off or you don't have enough water pressure.
Thank you!!
Jun 29, 2010 | Maytag MAH8700A Front Load Washer
I have a kenmore elite HE5t steam front load washer that keeps putting up f20 error the water lines are not plugged water is flowing into it i moved it out to check the water lines and it ran 3 loads then...
http://www.fixya.com/support/r3608632-f20_error_code
This code is tricky to troubleshoot, so jsrock516 advices to eliminate the easy common sense items first.
May 14, 2010 | Kenmore Elite 45986 Front Load Washer
Our Kenmore HE2 keeps giving f20 error. Water pressure is fine. No kinks in hose. Cleaned out junk in trap behind the bottom panel. Ordered new pressure switch. Works fine on clean washer cycle, but with...
This code is tricky to troubleshoot, so jsrock516 advises to eliminate the easy common sense items first
Dec 02, 2009 | Kenmore Elite 45986 Front Load Washer
F20 Error for Kenmore HE3 Gas Dryer
make sure your vent for the dryer isn't starting to get clogged or it may have a hole in it therefore hot moist air is getting in the closet instead of outdise
Sep 07, 2009 | Dryers
When I go to look at the pictures I have taken, it keeps reading "read error" and won't let me look at the pictures I have taken.
try a different card. I bought a card on ebay ant it randomly did that. I have 4 cards and only on of the cards does that.
May 31, 2009 | Fuji FinePix F20 Digital Camera
F20 error code no water coming into kenmore he3t washer
The following provided by fixya has the solution to error F20.
Click here for detailing on F20 Error
Good luck and please do rate my answer.
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
I have a knemore elite HE5T and keep getting the code F20?
The following link explains the "F20" error code:
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
If you have questions, or require additional assistance, please let me know. I hope this helps you.
Jan 05, 2009 | Kenmore Elite 45986 Front Load Washer
Writing error keeps coming up
Try formatting the xd card. The f20 has enough internel memory for a few pix, if the card is not working it uses internal memory. Also look for the number of pictures remaining if this is low the card is not working.
Jul 05, 2008 | Fuji FinePix F20 Digital Camera
Kenmore HE2 Plus Front Load Washer Logo
388 people viewed this question
fordexpert
Mike Squire
Robert Rankin
