Question about Boating
Motor stalls when idling
I have a35HP 3cylinder Evinrude regularly seviced.Front controls and key ignition.The motor runs well but wnen idling it stalls. when this happens it is difficult to get the motor restarted rquiring the ignition to be pumped vigoursly. there does not appear any oiling up of spark plugs.
    Top Expert:
  • Boating Master
  • 48,532 Answers
Sounds like a fuel problem .
Posted on Apr 26, 2010
What is the idle timing for 1993 90hp evinrude
90 hp 1993 evinrude idle speed - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 3, 2008 - 2 posts - ‎2 authors
"How many rpm should the engine idle at,and where and how do you adjust it Thanks" 50 hp evinrude no idle and no top speed need assistance ...
Jul 6, 2013
1993 50 HP 2 cyl Evinrude stalls, runs at idle when ...
May 7, 2012
adjust carburators and idle speed 1993 48hp
Jul 29, 2010
90 hp stalls when going in gear
May 21, 2010
More results from www.marineengine.com
1993 Johnson 90-HP Runs Only At Idle Speed On Spring Start-Up
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55https://www.youtube.com/watch?v=ReeuaVh8uZQNov 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
Dec 14, 2015 | Boating
STARTS BUT STALL RIGHT AWAY
Sounds like it could have a worn ignition switch.Not the key part but the electric switch the key is connected to.
Oct 31, 2009 | 2001 Ford Escape
Adjust the motor idle on a 1974 evinrude 50
Seat the idle mixture screw. Turn counter clockwise 1 1/2 turns. With engine running in gear under a load at idle slowly turn the screw clockwise until the engine bogs down and then turn back out 1/2 a turn. That is your correct mixture.
Sep 29, 2009 | Boating
My 1996 130 Johnson outboard is difficult to keep running when it starts. Doesn't seem to be priming correctly. Once I manage to get it into gear and moving w/o stalling, it runs great. Just having...
check your idle stabiliser-it advances /retards the ignition timing directly associated with RPM-if you dont notice any differencewhen moving the spaRK advance lever then replace it-no seviceable on mercs anyway!
Aug 22, 2009 | Boating
40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Apr 27, 2009 | Boating
1996 evinrude outboard stalls when put in gear idles good in neutral & runs out good in gear but stalls idling in gear
Start by adjusting your idle mixture screw. Start at 1 1/2 turns out and with the engine in gear at an idle slowly turn the screw clockwise until the engine starts to die, then back off a half turn and that will be your proper setting. If you need to you can bump up your idle stop screw just a touch so it will hold also.
Mar 23, 2009 | Boating
Boating Logo
159 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
