Question about NetGear WGR826V Router (wgr826vna)
NetGear WGR826V has no clear port forwarding section in the setup, the mamnual is as clear as brick as to forwarding...so how do I forward a port on this brain dead router?
  • 12,061 Answers
Forwarding Port – If you select 'Same as Incoming port' then all incoming traffic on specified Service is forwarded to LAN server without modifying Destination Port. – If you select 'Forward to another port range' then all incoming traffic received on the Service port (or range of ports) is forwarded to this port or range of ports of the LAN Server. – This field is disabled if action selected is "Block Always". – If you want to forward the traffic to a single port then enter port value in start port and leave finish port empty. – If you want to forward the traffic to range of ports then enter non zero value in finish port and make sure that service record attached to this rule has range of ports and range is equal to that of forwarding ports. – For example if you select Service as HTTP (TCP/80), LAN Server IP address as 192.168.15.10 and Forwarding port as 8080 then all traffic coming from internet on – TCP/80 (HTTP) to this Router is redirected to TCP/8080 port of 192.168.15.10 • WAN Users: These settings determine which packets are covered by the firewall rule, based on their source (WAN) IP address. Select the desired option: – Any All IP addresses are covered by this firewall rule. – Address range If this option is selected, you must enter the "Start" and "Finish" fields. – Single address Enter the required address in the "Start" fields. • Log: This determines whether packets covered by this firewall rule are logged. Select the desired action. – Never - never log traffic considered by this firewall rule, whether it matches or not. – Match - Log traffic only it matches this firewall rule. (The action is determined by this firewall rule.)
Ok well this is out of the manual, to me it seems straight forwards, but it is a brick too though, there is an example to help you, basically you tell it the Address of the PC, (Right click on NIC and get address) that you want ports to go to.. then ALLOW it, UN-disable actually.. in the tables.
Posted on Feb 05, 2010
  • electronic & computer repair&  servicre
    Oh and ensure you "Open" that port through the firewall on the client PC too, as well.
Router port forwarding
I got the following from Netgear support on how to do port forwarding on my Netgear model # WNR1000
1) Start > My Network Places > View Network Connections to ensure Network connection is enabled
2) Open a browser and access the router by entering 192.168.1.1in the address bar.
3) User name: "admin" and Password: "password"
4) Click on Port Forwarding under Advanced on the left side of the Router page.
5) Click on "Add Custom Service" button.
6) Specify any name for the Service. Service Type - TCP/UDP
7) Specify the Start Port and the End Port. (80 & 90)
8) In the Server IP Address, Enter the IP address of the device (192.168.1.x).
9) Click on the "Add" button.
10) Follow the above steps to open any other ports with different service names.
11) Click on Apply.
Aug 12, 2014 | Computers & Internet
Set up port forwarding
This WEB site shows how to setup port forwarding with Netgear routers.
http://kbserver.netgear.com/kb_web_files/n101145.asp
Sep 25, 2012 | NetGear WGR614 Wireless Router
Need to know how to forward ports
This WEB site will help ypu to setup port forwarding for your model router.
Port Forwarding Guide by Make and modelhttp://portforward.com/
Mar 16, 2012 | NetGear WGR614 Wireless Router
I want to hook up my ps3 using my 595u sierra wireless air card how do i do it?
You'll have to set up "Port Forwarding" on your router.
Click here to see a picture of which ports to setup under "Port Forwarding" for your router and the PS3.
Here are the settings that you should use when you setup your PS3 with a static IP:
IP Address: 192.168.1.200 (Same as the one you used for Port Forwarding)
Subnet Mask: 255.255.255.0
Default router: 192.168.1.1
Primary DNS: 192.168.1.1
Secendary DNS: 192.168.1.1
Jan 13, 2010 | NetGear WGR614 Wireless Router
Trying to open ports
You will need to setup Ports 5631 and 5632 to forward to the IP of the computer with PC anywhere installed on it. You need to go into the Virtual Server section to setup the port forwarding.
Apr 22, 2009 | Computers & Internet
Help :S
the ip address is to log into your router setup page..
open a new internet explorer page and type, http://192.168.0.1 and then hit enter, it will prompt for a user name and password, if not try clearing your browser catche memory and the try..
Aug 14, 2008 | NetGear DG834G 802.11G Wireless ADSL...
Nat ports
Go to the port range forwarding page on your router's setup.
It will ask you for the specific port. (88,3074) Enter them in in their own seperate sections. Then select either UDP of TCP for each. Then save the settings and you should be good to go.
Apr 06, 2008 | NetGear WGR614 Router
NetGear WGR826V Router (wgr826vna) Logo
1,517 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
