Question about Lenovo Thinkpad T60 Notebook
Lenovo laptop not all keys work
Not sure of model no.........i have to hold down the function Fn key to get all my keys to work, if i dont i get numbers instead.
  • neetu_e Mar 10, 2009
    i get the numbers insted of keys
    the keys which are working with fn key
  • Anonymous Apr 01, 2014
    Hello, disable touch pad from function key not working. When you go into the options of the touch pad control panel and turn it off from there, it is off. Buttons "FN" and "F6" work. I Installing drivers. What can I do? Work with windows 7.
  • 77 Answers
Take off NumLock
Posted on Feb 20, 2008
The letter s and D on my laptop act as a volume control function. How do I fix this problem?
Most laptops use a key combination for these kinds of tasks. Things like volume, wifi access, or screen brightness can be modified usually by holding a function key. This key is usually marked with "Fn" and you hold it down while pressing on of the F keys at the top of the keyboard (F1, F2, etc til F12.) to perform the task. Now, some computers have a "function lock" ability. Which basically means you do not have to hold that Fn key to do tasks. Could be that has been enabled. If you provide the laptop make and model we can look into it. =)
Mar 08, 2015 | Lenovo IdeaPad Z585 15.6" LED Notebook -...
Function keys
If holding down Fn and the desired function key does not do what you are expecting then you likely need to re-install the Energy Management Software, you can download it from http://support.lenovo.com/en_GB/downloads/default.page?
Mar 22, 2013 | Lenovo G580 Laptop Computer - 268938U -...
Jumbled keyboard numbers
Are you typing on your laptop and notice the text has become illegible? What should be letters, have become numbers or symbols. This odd behavior can probably be explained be peering a little closer at your keyboard. Those little numbers on the keys. These numbers and symbols normally become active when you hold down the function key, usually labeled as the "FN" key. The "FN" key is similar to the Shift key, activating a second function assigned to a key. It can become active seemingly on it's own because a key is locked in the on position.
Before performing numerous key combinations, try the simple thing of lightly tapping the "FN" or "Num Lock" 5 to 6 times. There may be a small particle of something logged under the key that you can loosen, move, or crush down. Do not bang the keys, just press normally. Next focus on the "Numlock" key which usually located with the "Print Screen" and "Pause" key on the top right of your keyboard. Press the "Numlock" key, then press a scrambled key to see if it's normal. Older model laptops may require you hold down at the same time, the "Ctrl-Shift-Numlock" keys. Newer models may require holding down the "Shift" key and pressing the "Numlock" key. Turn off the Function key with the following combinations. Hold down the "FN" key and hit the "Numlock", Hold down the "FN" key and hit the "Scroll" key and Hold down at the same time "Fn+F12+Num Lock"
Feb 08, 2013 | Lenovo Computers & Internet
Keyboard numbers are jumbled
(Fn) key function
Fn or Function key is used for your F1 up to F12 keys. Ex. Fn+F5 is to turn on the wireless capability. Fn key is like a shortcut for the functionality of the machine. You can also adjust brightness by pressing Fn+Up or Down arrow and for the Volume Fn+Left and Right arrow.
Apr 29, 2011 | Lenovo IdeaPad Z360 Notebook
How to adjust the screen brightness form dark to bright
ok bottom left hand side of keyboard there is a key with fn on it hold this down along with other blue keys that have like little suns on them this is your brightness keys
Sep 06, 2009 | IBM Lenovo ThinkPad X40 2371 Notebook
Cat sat on laptop changed screen brightness. its to dark how do i brighten monitor
There is a master function key that you hold down while tapping another function located on the keyboard. This all depends on the model of laptop. Next time try to giva a little more info like make and model, which is located on the bottom. The function key or Fn key is usually located on the keyboard near the Alt and Control key lower left. while holding this key down, you tap the corresponding brightness key on the number of the keyboard, some times the brightness is on the 4 arrows on the right side of the keyboard...sometimes they are the numbers 6 or 7 look for what appears to be a symbol that looks like the sun or a light. Hold down Fn and tap the key that brightens the display.
Sep 05, 2009 | Computers & Internet
How do i auto switchoff my lenovo y410 laptop
I'm not sure if your referring to sleep mode or not but I hope this helps There are several specialty key functions on the Lenovo Y410...here is a list....good Luck....please rate me ...The Fang
The following describes the features of each function key.
Fn + Esc: Turn on/off the integrated camera.
Fn + F1: Put your computer in sleep mode.
Fn + F2: Turn off the LCD screen (any subsequent operation will turn the LCD screen back on).
Fn + F3: Shift to other connected display devices.
Fn + F4: Switch between wide screen and normal mode.
Fn + F5: Enable/disable the built-in wireless networking feature.
Fn + F6: Enable/disable the bluetooth features.
Fn + F8: Enable/disable the touch pad.
Fn + F9: Enable/pause Media Player playback.
Fn + F10: Stop Media Player playback.
Fn + F11: Skip to the previous track.
Fn + F12: Skip to the next track.
Fn + Insert/NmLk: Enable/disable the Numeric keypad.
Fn + Delete/ScrLk: Enable/disable Scroll Lock.
Fn + Pause/Break: Pause to view the system information during start-up.
Fn + up/down arrow key: Increase/decrease display brightness.
Fn + right/left arrow key: Increase/decrease computer volume.
Feb 19, 2009 | Lenovo 3000 Y410 Notebook
How do I use NumLoc on lenovo t-60? No keys for it?
If you hold down the Fn (function key) and hit one of the NumLock keys, this will type those NumLock characters usually printed in blue on the keytop). Also this is different on virtually every laptop, but one key should say NumLock or have a picture of a lock on it in blue. This is the NumLock and it is toggled by holding the Fn key and that key.
Jan 29, 2009 | Lenovo Thinkpad T60 Notebook
Function keys
Hi you need to hold down the function key (FN) and press the number lock key (num lk). hope this helps
Jan 14, 2008 | Gateway MX6453 Notebook
Lenovo Thinkpad T60 Notebook Logo
410 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
