Dell Tech Support replaced my laptop hard drive and left me the old hard drive that is functional, but has alot of vibration. How do I replace the new laptop hard drive data with the old laptop hard drive data?
  • 10 more comments
  • glbrown_scv Feb 05, 2010
    It is a SATA drive and I am able to connect to it.
    But can I completely replace the new laptop hard drive apps/files/etc. with the old laptop hard drive apps/files/etc?
    I have Norton Ghost. What should I do? I am new to Norton Ghost.
    So I cannot replace new hard drive os and programs with the old hard drive os and programs?
    old drive was working ok.
    os, programs, everything was working okay - just noisy.
  • 617 Answers
If you mean with the os sys and programs, can use norton ghost to create an image of old drive then put on new drive
Posted on Feb 05, 2010
  • 1 more comment
  • tim mcgrath Feb 05, 2010
    coping the files over is one thing, but for programs to run they need to be installed not just a copy, most programs wont work if trying to copy over if wasnt installed
    ok good, first thing is your old drive was working ok but drive itself was problem, meaning the operating sys and programs working fine? if was ok what i would do is created a boot disk for ghost, take an image of new drive, then install old drive take image of, then re-install new drive boot with disk put old image on new drive, when you make image do drive image not partition image, when making it will tell you how many discs will require to make image
    not by coping files over
  • Computers & ... Master
  • 5,339 Answers
First what type of hard drive do you have? IDE or SATA (IDE has a very wide data ribbon, SATA a much thinner one when you look at the back of the drive). You need to get either an external 2.5" drive enclosure or a USB/IDE/SATA bare drive connector. For the external enclosure, you need to get the right one for your drive. The data output can be either USB or eSATA, if your laptop has that port and you have a SATA drive). The USB/IDE/SATA connectors can be either bus powered or self-powered. The bus powered ones do not have enough power for some drives. With either of these, the drive must be connected carefully and with the correct orientation of the power and data connectors.
Connect the drive or install it into the enclosure. (For this, open the case, slide the drive part way in and connect the cables, push the drive the rest of the way in. Screw the drive into the frame if this is a needed step. I have seen any tool-less enclosures but read the instructions.) Power on the device and plug it into the appropriate connection on your computer. The device should be found by your computer and the drivers should load.
Assuming your computer sees the drive (if it doesn't one of the cables is probably not seated properly or not correctly oriented to the device), then you can just copy the files to the new drive. Setting up your e-mail may take a bit longer, you may need to import your profile in addition to copying it to the new drive into a folder in the same location.
I hope this helps.
(If you do not feel comfortable doing this yourself, there are many data recover companies as well as computer repair shops that will install your drive into the enclosure you buy.)
  • Cindy Wells Feb 05, 2010
    I see that I misunderstood. I thought you just wanted the data. You can run a program like Norton Ghost. This creates an image of the entire contents of the drive. Then restore the image to the new disk.
    Alternatively, get one of the drive cloning programs (several partition management software programs, such as Paragon Partition Manager, have the feature built in). Set it to clone the old drive to the new one. This will maintain every partition including a recovery partition if your computer came with that.
    I hope this helps.
    (cloning keeps the registry information. Copying the data and installing the software fresh could improve your computer's behavior since Windows systems do get registry issues over time. It does take a bit longer.)
Hi , went to bed at night laptop was fine. When I woke up and tried to open, The dell load screen appear and 1sec later it goes to the black screen with a white underscore blinking top left corner. Windows...
The hard drive may be going bad. Try booting into Safe Mode to see if it boots into Windows. Then I highly recommend backing up all documents onto a flash drive or portable hard drive.
Mar 22, 2015 | Dell Inspiron Computers & Internet
My laptop makes a weird noise evry 5 minutes
The only moving parts are the hard drive and the dvd drive when a disc is inserted. If the noise only occurs when using the dvd drive, then thats where the noise is coming from and probably means that the drive is past its best and may need replacing. It could be the dvd drive thats causing the blue screen also, if windows detects an error with the drive.
Make sure that the Pc is not running too hot as this can also cause problems with hardware function and bsod issues.
Mar 27, 2012 | Dell Computers & Internet
I have a problem with my dell studio laptop stating like smart hard disk failure in statrup and asks to hit F1 to continue..please give a solution for this problem...
Normally the SMART error occurs when the hard drive has gone bad.. What you do is.. Try running the dell diagnostics by turning on the computer holding the FN key.. It will run some tests... If it provides any error code then the Hard drive has gone bad you need to replace it.. Call up the Dell or a local tech and replace the hard drive
Oct 06, 2010 | Dell Studio 15 Laptop
Dell Inspiron 1501 wont power on (no power-on light), nor gives any indication of starting power-on. Power adapter blinks when connected to laptop, but stops blinking and stays lit when removed from...
This seems like there is a device causing this problem. Disconnect the battery, hard drive, optical drive, hinge cover, keyboard, palm rest.disconnect the above devices one after the other and check the functionality each time. You can find a service manual at www.support.dell.com from the left click on manual, when opted choose your model and follow the service manual. This should help you. All the best.
May 29, 2010 | Dell Inspiron 1501 Notebook
My dell inspiron 1720 keeps rebooting. Pressed
Yes. You'll need to replace the hard drive with that error code.
No matter you can't use that computer without replacing the hard drive.
If you have a warranty for the computer contact tech support for your dell, give them the error code you have
and they will immediately replace your hard drive.
Re seating the hard drive won't fix it.
Hope this helps!
Feb 21, 2010 | Dell Inspiron 1501 Notebook
I have no problems..need larger hard drive for Dell Inspiron B130. Have only 15gb left. Is this a diffucult task? hump
Surprisingly the task of replacing the hard drive is fairly easy, as soon as you have purchased a replacement drive (make sure it's a IDE 2.5ins drive)
Just click on the link that i have provided bellow for instructions on how to remove the hard drive from the laptop and replace it >>>>
http://www.mrdimpy.co.uk/Dell%20Inspiron%201300%20Service%20Manual/hdd.htm
Regards.
Jan 06, 2010 | Dell Inspiron B130 Notebook
I have an error code 0146 on my dell laptop that isn't a year old. it should still be under warranty. Should I try and restore the whole system or don't even bother and contact dell and let them fix it?
A 0146 error code is a write error on the hard drive. Normally, this is cause for a hard drive replacement. 800-624-9896 call Dell Tech and get it replaced.
Dec 06, 2009 | Dell Inspiron 6400 Notebook
My dell 610 laptop has started running slow
if you are experiencing these and unsure on what to do, better take your laptop a laptop tech, if you feel that you needed a hard drive change, then take it to a tech, have them replace your old hard drive
Nov 26, 2009 | Dell Latitude D600 Notebook
Upgrade-replace Dell inspiron 6400 laptop's hard drive ???
I'm sorry to say there is no Easy way to do this with a Laptop without re-loading everything from scratch. As far as using the old drive as an external, you will have to order an enclosure for it. Tigerdirect.com is one source so is Ebay.
Mar 21, 2009 | Dell Inspiron 6400 Notebook
Hard drive problem
where did it exactly stop? what screen did you last see?
You may go here to get a walkthrough on how to reinstall windows
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&docid=58E26A65A4388E4FE040AE0AB7E107E3&l=en&s=dhs
Mar 01, 2009 | Dell Inspiron 1525 Laptop Jet Black
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
