Question about Sewing Machines
After winding the bobbin I went to tighten the stop clutch knob but it no longer does anything for the hand wheel clutch.
  • za_lou Feb 05, 2010
    No solution was given, just another website to search. There was a very similar question posted when I first found FixYa with a reply of "Thanks - it worked!" I would like to know what worked!
  • 2,335 Answers
What is the make and model of your sewing machine, so that we may provide more accurate advice for your particular unit?
Posted on Feb 05, 2010
My sewing machine stops after about 10 revolutions, the motor is till running but the needle does not move. any suggestions please ?
1. Loosen the screw on the front of the hand wheel, almost completely.
2. Now, tighten the hand wheel control knob. The needle should be able to move now.
3. Tighten the screw. Your hand wheel control knob should be able to be loosened for bobbin winding and tightened for sewing.
Just for information purposes: The hand wheel control knob is usually the small round knob on the front of the hand wheel and is also very shiny.
Oct 02, 2016 | Sewing Machines
The Balance Wheel and the Clutch Release knob will not tighten together again after filling a bobbin. How do I fix this?
THERE IS A SMALL SCREW AT THE MIDDLE KNOB ON THE HAND WHEEL THAT YOU NEED TO LOOSEN. AFTER THAT TIGHTEN THE HAND WHEEL KNOB JUST AS YOU WOULD WHEN YOU ARE GOING TO SEW. NOW, TIGHTEN THE SMALL SCREW. YOUR MACHINE SHOULD BE OK FOR SEWING AND YOUR BOBBIN WINDING.
Jan 07, 2015 | Brother Sewing Machines
I have a Janome 7933. The hand wheel turns but the needles don't. Looked in the manual but nothing about changing a belt or anything pertaining to this problem. How can I fix it?
Is the hand wheel properly engaged ? A hand wheel often is used when you wind bobbin. When you wind a bobbin, you want to disengage the clutch to prevent the needle going up/down.
On a lot of machines, either the entire hand wheel will pull out, or a smaller middle dial will pull out. You pull it out to wind the bobbin, push it back in to reengage the clutch so the needle goes up/down again.
So giving it a good push IN might solve this.
Oct 27, 2014 | Sewing Machines
Singer 362 bobbin
It appears from the manual (see pages 9-10, which are on 11-12 of the pdf version) that it is necessary to disengage the hand wheel (loosen the center knob) with the bobbin winding lever all the way to the left, before putting the bobbin on the winder spindle. Put the bobbin on the spindle, then set the winding lever to the right position to engage the spindle drive. Do not tighten the hand wheel knob until after the bobbin is wound and the lever is moved back the left to permit bobbin removal.
If you are following these directions exactly, or you can't get the hand wheel knob loose, you have a mechanical problem to solve. You may need a stronger hand to loosen the knob, or something in the bobbin winder is bent, out of adjustment, or jammed with foreign material. If you are mechanically inclined, you may want to remove the top cover of the machine for inspection.
Dec 02, 2013 | Sewing Machines
Needle does not move when I try to sew.
On these old singers, there is a locking washer that controls the tighten and release mechanism. If it is not in the proper place your efforts to tighten and loosen to engage the sewing functions do nothing.
Aug 11, 2012 | Sewing Machines
Kenmore sewing machine Model 1602: I was filling a bobbin and when I went back to sewing - the needle won't go up and down. Motor runs when I press on the footpad. It is as if the clutch is stuck as well...
Sound like you need to take it out of bobbin winder mode. Suggest looking for a way to engage the clutch. Turn the center knob on hand wheel and or move the bobbin winding post back to postion.
The center hand wheel should move about 1/3 turn towards you to look it back into place.
Feb 09, 2011 | Kenmore 15516 Mechanical Sewing Machine
Needle not going up and down but power getting to the machine
Check your manual for the bobbin winding steps for your particular model.
On some machines there is a knob in the center of the hand wheel that is loosened for bobbin winding - this also disengages the movement of the needle. Tighten for sewing.
There may be an additional step, such as moving the bobbin winding pin to the right or the bobbin winding wheel to the left.
Apr 06, 2010 | Bernina Sewing Machines
Clutch Release Problem
You will need to remove the clutch release knob and the 3 eared positioner (the clutch) under that knob. Reposition the clutch on the shaft, put the knob back on and see if you can put the screw back in the hole. If it hits something, remove the knob, remove the clutch and turn it 180 degrees. This will reposition the ears. Put the clutch back on the shaft, put the knob back on the shaft and screw the screw into the hole. Test to be sure the knob releases the hand wheel to wind the bobbin.Be sure the thread is under the thread guide when you wind the bobbin and that there is a slight tension on it.
sewman7
Jan 16, 2009 | Brother Sewing Machines
Winding the bobbin?
Most of the entry level machines will have either a clutch knob or an automatic release when the bobbin winder mechanizm is engaged (put a bobbin on and more the unit to you right). If it does not disengage the clutch automaticly then either loosen the clutch wheel by turing or pulling. Sometines you have to grab the whole clutch wheel to disenage the mechanism to free wheel while winding the bobbin. Now press you foot control to wind the bobbin.
SewTech
Apr 21, 2008 | Janome Mini Compact
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
