Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Why does my printer notrecognize the ink? - Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
    Scholar:
  • 120 Answers
Follow the mentioned procedure:
1. click start manu
2.open fax and printer
3.double click the effected printer icon
4.there will be show some print order, delet all the print order, then restart your printer.
solution-2
if you use continuous inking system, push out all the ink cartiges from the chamber. then clean the conected area and set the cartige again perfectly.
Posted on Feb 05, 2010
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Tip
How to Fix USB Device Not Recognized Error
One of the most common errors in Windows is the USB Device NotRecognized malfunction. Thankfully, this is not in any way poses athreat to the security of your system though sometimes it may causeyour system to "hang" or experience delays. The USB Device NotRecognized error simply means that your computer cannot distinguish theUSB device that is inserted in one of the USB slots of the computer.
There are different reasons why one's system gets this error. Asidefrom the attached devices at the USB slots, it is also possible thatthere is a malfunction in the host controller hardware. Moreover, thecomputer may not support the USB 2.0 that's why this error pops up atthe screen. There are also some system configurations or hardware thatare experiencing glitches as well.
But you can try different ways to resolve this error so that youwould not have to deal with the pop up message "USB Device NotRecognized".
If there is any connected USB device, gently unplug it from theslot. It might be loose that's why the error appeared. Wait for acouple of seconds before you plug the device again. Make sure that itis secured at the port.
You can also use the Device Manager so your system can scan and lookfor the new hardware. Open the Start menu then choose Run. Typedevmgmt.msc at the box then clicks Enter. Once the Action menuappeared, choose Scan for Hardware Changes. It will allow your systemto look for newly installed devices.
But if these techniques didn't resolve the error, you can tryunplugging the USB device from the port before shutting down thecomputer. Don't open it again immediately and wait for at least twentyminutes or so. However, if you still can't seem to fix the USB DeviceNot Recognized malfunction you may need to update your driver instead.You should know the website of the manufacturer so you will check outthe latest about the driver information. It would just take a couple ofminutes before you can get the updated driver information so you canstop the error from appearing from time to time.
on Jun 30, 2010 | Computers & Internet
Where are the "ink absorbers"?
Ink Absorber Full
This may clear the ink absorber problem. There is ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Aug 19, 2012 | Canon PIXMA MP210 Photo All-In-One Printer
EPSON STYLUS T13 printer's ink pads are at the end of their service life HOW TO RESET FREE
Apr 26, 2011 | Epson Printer
My printer does notrecognize the cartridge
Take the cartridge out and check the connector and clean it, also check the connectors on the printer and clean it. If it doesnt work try restarting or unplugging.
Mar 04, 2011 | Epson CX8300/CX8400/DX8400
Every time I put in the webcam it says webcam notrecognized...what do i do?
Uninstall the web cam driver and install the driver and restart the computer
Feb 02, 2011 | Logitech Webcam
Hi. My printer will not recognize the magenta ink. I tried replacing it with 3 different new ink cartridges, but when I try to make the printer charge the new ink, it does nothing and says I'm out of...
Hi
Some ink printer had ink resetter and just go to ink set up.
If your printer have ink resetter, do it otherwise it will not recognized new ink installed.
If not, some new ink cartridge when the tape is remove, there are cases that the sticky leaf on the ink cartridge, just rinse it with warm water or alcohol to detect the ink cartridge. Turn off your printer and your computer. Then return the ink and open your printer and computer to print again.
Note : Use only ink that is compatible with your printer because it you use other cartridge it will damage the chip set of your printer and it will not recognized any cartridge at all. SO beware.
I hope it helps you.
Jan 12, 2011 | Epson Stylus Photo R1800 InkJet Printer
Red not printing
if replacing M and/or LM cartridges doesn't fix the problem, there is not much you can do. You can try to get the printer serviced, but probably won't find anyone willing to do the job.
LC1000
www.inkbank.com.au
Dec 02, 2010 | HP Photosmart C7280 Printer
Mercury P4VM800M7 Motherboard Problem
vga yi bulamiyorumda yardimci olursaniz sev'n'r'm
Sep 25, 2008 | Mercury P4VM800M7 Motherboard
Ink cartridge problem! The following ink cartridges appear to be missing or damaged.
hi!!!!
try to clean the nozzle of your cartridge with the alcohol
or solvent used cotton
or replace the cartridge
try to email me ronaldsuboc@gmail.com
Sep 18, 2008 | HP Photosmart C7280 Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
73 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
