Question about Spinmaster Air Hogs RC Reflex Micro Helicopter
How do i fly my spin master air hog rc helicopter all it does is go in circles
  • Anonymous Mar 18, 2014
    won't fly, keeps going back to the ground
    Problem Solver:
  • 7 Answers
If its a Reflex twin rotor Heli use the trim wheel on top to counteract the spin and at least stabilize the craft at hover. Then use the right/left froward backward fans to control flight, (right joystick on the controller). These fans are not very powerful so don't expect alot from them other than turning the craft right left and reverse. Seems there is too much down draft from the rotors to effectively move the Heli forward. Not a real good design. The Sharpshooter is easier to fly but uses the batteries in the controller as a charger so they don't last real long.
Posted on Feb 15, 2010
  • LuiTutin Mar 10, 2010
    Don't know if you ever solved this issue but if the problem is still there and you feel adventerous you can try to fix it.If the top rotor and shaft came loose, (either it pulls out or if you turn the upper rotor and it does not engage and turn the lower one at the same rate) I used an exacto knife to cut along the seam of mine,(you have to be careful especially in the tail section as the antenna wire runs along its length). You will have to caerfully bend up the directional fans to remove each side of the body once separated. Use a small jewelers screwdriver to open the motor housing - there is a screw on the vertical rotor housing section right behind the circut board that you will have to get to by going in on an angle - being careful not to lose the small washer on the shaft above the lower gear. Remove the upper rotor and shaft and the gear and washer. Clean all with rubbing alcohol. Now here is the hard part - place the gear back into the lower half of the motor housing, insert the upper rotor shaft into the gear until it bottoms out and mark the shaft at the top of the gear, (a dab of liquid white-out used for typing errors works well becuse it dries fast). Once dry remove the shaft and pull the gear off of it. Measure from the bottom of the shaft to the white mark and write it down - you can use a piece of paper as a guide by lining up one edge with the bottom of the shaft and placing a mark at the spot of the white out if using a ruler is too difficult to read. clean any grease off of the shaft and inside of the gear. Since the shaft is carbon fiber and the gear is polyethylene plastic not many glues work well. I used "J-B weld" a two part epoxy that is tough as nails and holds up well. place a mark on the paper guide approximately 1/64th of an inch above the original mark. This is how far you will have to place the gear from the end of the shaft, (this allows for less friction and keeps the lower gear from rubbing on the bottom of the gearbox...VERY IMPORTANT!!! insert the upper rotor shaft into the shaft housing in the top part of the gear box and place the small washer on it. Use the paper guide you made and put a small dab of white-out on the shaft using the new mark a your point of reference, (rember it's 1/64" above the original mark). Mix up a tiny amount of JB weld and put a thin coat on the shaft just below the mark. Slide the gear onto the shaft up to the mark and set aside overnight to harden. Next day reassemble the gearbox, (if you placed the gear too high up on the shaft the two halves of the gear box will not come together. DO NOT force it. use a file to take alittle off of the end of the shaft until the gearbox seats together tightly and reinstall assembly into the heli. I would tape the two halves together with scotch tape until you know you got it right. Try the heli using the trim wheel to stop rotation. If better but still not right check the flex on the rotor blades as it seems if used alot they get soft and flex too much which makes it hard to adjust. If they do flex alot try coating each with a THIN layer of JB weld to stiffen them up. This is a very delicate procedure as if you put too much on the balance will be shot. Seems like alot of messing around for a $40.00 toy but I enjoyed the challenge and it is rewarding to solve a problem and win.
2 Suggested Answers
  • 4 Answers
SOURCE: how do i fly my spin master air hog rc helicopter
If you trimmed your heli but it still can't work, try using the direction knob to trim it instead. When it goes clockwise push th knob leftwards and hold, and vise versa for anti-clockwise. Or, push and release repeatedly in the direction mentioned till it flies straight. Tested on around 6 air hogs helis and works each time. If you still can't trim you might try it after turning it off or contact the service centre.
Posted on Sep 08, 2010
My 9116 double horse RC helicopter just spins clockwise in circles, on the ground or in the air. I can hover it, but only spinning. What could be wrong?
Air Hogs remote control aircraft are designed to be easy to fly and use, and rarely have flying issues. However, there are the occasional issues that the company can't really predict. Some Air Hogs helicopters, for example, have a hard time flying forward without some assistance. If you're having this problem with your helicopter, this can be annoying, but it is not the end of the world. There is as solution, and it's easier than you might think.For more information:
http://www.playgroundmats.co.uk/ Playground Mats and Playground Flooring Tiles Soft Play Equipment
Jan 10, 2014 | Toys
My green air hog helicopter is spinning on the ground, it won't lift and fly, how do I fix it?
There is a problem on the motor gear, check the underside where you could see a big gear that should spin when you try to lift the helicopter. Check both big gears if they rotate/spins.
Usually the problem is the small gear on the motor shaft that is not aligned to that big gear. Check on it and adjust the small gear of the motor.
Hope that copter flies high.
Thanks for asking FixYa!
Aug 09, 2011 | Air Hogs Havoc Heli Helicopters
I have an air hogs sharpshooter helicopter and it wont stop spinning when i try to fly it and it only gets about a foot off the ground
it could be that you just need to use the adjustment nob it is next to the right joy stick u can turn it to make the heli fly straight. or one of your blades is not working like it should.
Jan 06, 2011 | Master Heaters Air Hogs Sharp Shooter...
My airhogs hawk eye video camera helicopter want fly it just spins in circles
Right here is the support site. http://www.airhogs.com/#/need_help
This is the place to get help for Air Hogs.
They also have a "community" link which may do you some good too.
Dec 29, 2010 | Air Hogs Reflex Micro Helicopter
Feb 05, 2010 | Spinmaster Air Hogs RC Reflex Micro...
Heli spins counter clockwise
See solution 2 for post "How do i fly my spin master air hog rc helicopter?"
Jan 03, 2010 | Spinmaster Air Hogs RC Reflex Micro...
Helicopter keeps spinning in circles and won't lift.
There is a "trim button" on the controller. Ex: if the helicopter is spinning left, press the "R" trim button repeatedly. Takes a little practice to get it down to flying with out hitting anything. Good luck.
May 17, 2009 | Spinmaster Air Hogs RC Reflex Micro...
Wont fly
I have an Air Hogs havoc cyclone stunt plane. I am not sure if your plane has this, but on my plane's remote there left and right steering trim buttons. Play around with these until your plane flies correctly.
Dec 30, 2008 | Air Hogs Glow In Dark Havoc Stinger Rc ...
Rotors spin just a little
make sure that the blades are snapped into place and that everything is charged and then make sure the heli is on because if you crash it, it will automatically turn itself off and then make sure no hair is stuck on the bar that spins thats attached to the blades and then try it again
Dec 26, 2008 | Spinmaster Air Hogs RC Reflex Micro...
Spinmaster Air Hogs RC Reflex Micro Helicopter Logo
914 people viewed this question
Top Spinmaster Toys Experts
ray gallant
Are you a Spinmaster Toy Expert? Answer questions, earn points and help others
