Question about Maytag PAV2300 Top Load Washer
Tub won't spin the water out. and how do you take off the knob that has wash rinse spin
  • 129 Answers
Pully bearing kit under neath may need to replace . center comes out unclip knob
Posted on Feb 05, 2010
I have a top load washer model LSR 8433 KQ0 the machine will not spin but agitates, rinses, drains fine but when it clicks to the spin cycle it just pumps out any water and does not spin. Would this b
Either the belt broke or the hood switch is not working. Sometimes it could be the contacts in the main control knob but if everything else is working correctly, then check the belt, and the hood switch first.
Jan 11, 2015 | Washing Machines
Hi my washing machine works perfectly fine but the water don't pump out srew out bottom filter is clean and I clean it on a regular basis. Defy 1300 laundromaid. Thanks please help
You probably have a rock or some object stuck in the pump blades. Take out the pump and turn the blades get out the obstruction
Nov 26, 2014 | Washing Machines
Timer is broken. I want to bypass and manually do a load of laundry I have the tub full it is agitating. How do I get it to rinse and spin?
just turn the knob to rinse and then turn the knob to spin if that will help just try it first then tell me
Jan 27, 2013 | Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
Maytag Neptune front loader won't rinse/spin
you have something clogging your pump
remove the back panel
clamp the tub to pump hose or deal with all the water when you remove the pump - three bolts
open the pump - three screws
remove the object blocking the impeller
check tub to pump hose and pump to drain hose thoroughly
reassemble
be careful of the machine opening once you remove the rear panel it is razor sharp !
Oct 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Rinse cycle is not starting after wash cycle. I have to manually turn the knob and it won't start until just before the spin cycle.
inlet valves working correctly are you getting hot and cold water entering the tub ?start the machine and switch from hot to cold and make suire there is both temps available there is a thermister on some washers that read the temp of water cold is required for most machines to rinse ..the therms are mostly located on the inlet water valve inside the machine.
Aug 10, 2009 | Washing Machines
Won,t drain on rinse cycle
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
Maytag A482 top load washer
The timer is faulty and needs replaced.
NOTE:
There is a possibility that only the timer "motor" is bad. This motor can be replaced. Listen at the timer knob. If the motor is running you can generally hear it this way.
Because of the age of this machine it is best to replace the timer
Jan 09, 2008 | Washing Machines
Maytag PAV2300 Top Load Washer Logo
97 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
