Question about HP Photosmart C6180 All-In-One InkJet Printer
Error Message: 0xc18a101
I have a Photosmart All in One C6180 printer,scanner, fax. I get the following message: - 0xc18a101 - have tried re-calibrating as suggested by one of your colleagues, I've put new HP cartridges in, but still get the message.
Hope someone can help, PLEASE.
  • 181 Answers
The Ox error you are describing is an issue being seen in quite a few hp printers. The only known fix is to try is while the printer is turned on unplug from power source. Unplug the power cord from the back of the unit as well and hold the power button down for 5 seconds to drain any remaining power the printer may be hanging on to. Wait another 30 seconds and plug the cord into the unit first and then directly into the wall - not a surge protector or power strip.
After you have plugged it back in if the error message comes back up then it is a fatal error within the printer. Call hp and see if they have any upgrade units available - usually refurbished but they come with a 1 yr warranty and are significantly cheaper than buying a new unit from the store. They will also take your unit and pay to have it returned to go to an environmental recycling facility.
Posted on Feb 28, 2008
Hello, I have an HP Photosmart C6180 All-in-One Printer, Fax, Scanner and Copier. It seems that as soon as I turn it on a message comes up: "Fax Failure" Unable to Send or Receive Faxes" This message has...
try ti perform steps as ---->Disconnect the power cable from the back of the printer and then press the power on button for 3- seconds and then at the same time connect the power cable at the back of the printer and then try to turn on the printer and then try to make copy from the printer
Aug 19, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP photosmart c6180 all in one printer error message of 0xc19a0035, ink system has failed. unable to copy, receive faxes, or print. what can i do to fix it?
The "Ink System Failure" error is caused by air in the ink fed tubes. We have a step by step guide to perform a ink purge on the printer posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ Following this procedure should get your printer back running in about 10 minutes.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Aug 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
Unable to scan, copy or fax message on HP C6180
Please follow the steps and then let me know the results:Click Here
May 23, 2010 | HP Photosmart C6180 All-In-One InkJet...
Photosmart 8180 has error message Oxc18a0101
try to follow this instructions to fix the error: Hit * and # at the same time on your printer, then enter code: 123 press right arrow, then go to system configuration and press ok 3x. unplug power from printer and wait 2 minutes, plug the printer again and then it will all be back to normal. hope this helps. Good Day!
Jul 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink System Failure
below is to document that i want you to follow exactly inorder to resolve your issue..
CLICK HERE ==>> DOCUMENT
Please let me know the result after following the document.
thank you so much.
adonscott
Aug 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
Error HP Photosmart 3310. No strart print, no scanning...
I have a Photosmart C6180 all in one and get an error message 0xc18a0101 Ink System has failed. Unable to copy, receive faxes or print. Refer to printer documentation. Error: 0xc18a101.
I put new cartridges in and tried to recalibrate as mentioned by someone on the board. Can anyone help, please?
Nov 16, 2007 | HP Photosmart 3310 Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
301 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
