Question about Centon Electronics 1GBMP3-001 MP3 Player
I have a centon 2GB Digital MP3 player. I plugged
I have a centon 2GB Digital MP3 player. I plugged the player into my computer usb port and thought that I was downloading music to it. However when complete the download (which didn't happen) I turned on the player and received a message "File System Error". I cannot load any music on it or get it to do anything. Any help would be greatly appreciated. Thanks
    President:
  • 949 Answers
Remove the battery, then put it back in, restart windows and plug it in,
make sure windows see the devise.
If you removed it while it was still loading, you could have locked the devise
from working, and you will have to send it to the MFG to get it fixed.
Go to there website and see how you have to send it back.
http://www.centon.com/support/warranty/return-procedure
Posted on Feb 05, 2010
Testimonial: "Thanks!!!! It that worked."
My centon mp3 player not detected by computers
Reboot your computer. Or, insert in another USB port.
Feb 23, 2011 | Centon Electronics 1GBMP3-001 MP3 Player
Mac book and a centon mp3 player
Presuming you're running OS X and not booting into MS Windows, you shouldn't need any drivers at all. I see the same logo, etc. on my centon's display when I plug it into my Mac (via a hub), so that's a good sign.
If the centon doesn't show up on your Mac's desktop, does it show up in Disk Utility? If it does, and it's grayed out, try selecting it and mounting it. If it doesn't show up in Disk Utility, does it show up when you open System Profiler and click on 'USB' in the left-hand column?
If it doesn't show up at all, try plugging it in with the battery installed.
Jul 11, 2010 | Centon Electronics 1GBMP3-001 MP3 Player
When i turn on my centon mp3 player, the screen comes on and says "mp3player" but then doesn't do anything. the screen just stays like that and none of the buttons will do anything either.
I had the same problem--It turned out to be corrupt data on the USB drive.
Remove the battery.
Make sure the "HOLD" button is "OFF" and insert the drive in your computer's USB port.
Find the USB drive in your "My Computer" menu and right click on it, then click "Format." (Note: Some computers to not supply power to certain USB ports. If you do not see the USB drive, try another port. If you can't find it using any port, put the battery back in and try again.)
Quick-format the USB device as at FAT, FAT16, or FAT32.
To prevent drive/data corruption, ALWAYS click on "Safely remove hardware" in your computer's taskbar and "eject" your USB device before removing it from the USB port.
You should have all menus and functionality restored, it worked for me.
Mar 09, 2010 | Centon Electronics 1GBMP3-001 MP3 Player
Centon Craze MP3 8GB: How does it charge or do I need to replace the battery and if so how.
MP3 players rechargeable battery is charged by connecting it to the computer's USB port or by a USB adapter charger.
Jan 01, 2010 | Centon Electronics 001 MP3 Player
No instruction on how to upload or use the unit, can the battery be recharged?
There is a user guide for the Centon MoVex MP3 Player here (the manufacturer's support web site) . . .
http://www.centon.com/doc/guides/eng/movexguide.pdf
Since all Centon's MP3 players seem to be alike with the only difference in storage capacity, this manual may serve you . . . it did for me with my 2GB player (whatever make it is.)
As for charging the batteries, if yours is like mine, then the MP3 player uses AAA size batteries, so you won't have any internal battery to charge.
Hope this info helps.
jc
Oct 20, 2009 | Centon Electronics 1GBMP3-001 MP3 Player
When i connect my sansa clip 2gb it will not charge. it say connected and then goes off. I thought it was charging but when i checked it the battery had died what do you suggest i do to get it working...
Check for the following:
USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure the computer isn’t entering hibernate or sleep mode while the device is connected.  The computer must be on in order to charge your player.
USB Port 2.0
Make sure the player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged.  It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater
Jan 23, 2009 | SanDisk Sansa e250 MP3 Player
Centon digital mp3 player problem
I don't know if this will work for you but make sure that the hold button on the side of the mp3 player is not "on" - you have to slide it off.
Dec 10, 2008 | Centon Electronics 001 MP3 Player
Open Questions:
Centon Electronics 1GBMP3-001 MP3 Player Logo
380 people viewed this question
Top Centon Electronics Audio Players & Recorders Experts
Computer Repairing
Computer Repairing
Elise Lacoursiere
Elise Lacoursiere
Vernon Taylor
Are you a Centon Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
