Question about Frigidaire ATF6000ES Front Load Washer
Error signal appears and wash machine stops
A blanket blew up in my frigidaire wash machine now every time i run it the error signal comes on
  • 129 Answers
Clean out pump and drain hose you have blockage may need to do many times until opened
Posted on Feb 05, 2010
Testimonial: "thanks buddy "
Front loader. Why does it run for about 30 seconds, then stops, beeps, and displays code e64?
Good Morning friend, thank you for your post!
I see that your Frigidaire frontload washer runs for 30 seconds, then stops, and produces an error code "E64". It appears that might be an invalid error code. I would recommend performing a reset on your washer and you can do that by unplugging the power cord for at least ten minutes. If you continue to receive the error code or a new error code please reply back. I would like to assist you further. -Matt
Jun 04, 2015 | Frigidaire Washing Machines
When I press start dryness cicle not working. Appears error
Hey Salvador Juarez, I appreciate your post!
I understand that when you try and press the dryness cycle on your Frigidaire laundry center it provides you an error. I would like to ask you some additional questions in order to best assist you. Does it show you a code or beep? If so, how many times does it beep? I look forward to your response. Thank you. -Matt
Aug 02, 2014 | Frigidaire GLEH1642DS Front Load Stacked...
GLTF2940ES3 - Frigidaire Front load washing machine e59 error code
http://www.ehow.com/info_12127418_frigidaire-gltf2940fs1-not-spin-error-e59.html
May 02, 2014 | Frigidaire GLTF2940ES Front Load Washer
During the wash cycle, an error HE appears, and the wash cycle stops. the clothes are soaked with water
Hi areej, this is AP! Thank you for your post.
I understand you are experiencing an HE indicator during the wash cycle on your Frigidaire front load washer. I would recommend contacting a local technician as this appears to be a problem within the motor speed control board. However, I would recommend a local authorized technician to come out and properly diagnose and repair your front load washer. I hope this information helps.
Mar 05, 2014 | Frigidaire ATF6000ES Front Load Washer
My washing maching is reading E20 and it is not washing. it seems to stop after a few minutes of washing and then it will read E20 and just continuosly beep
Hello.
Frigidaire front-loading washing machines have an electronic control panel where the wash cycle and any other wash options are selected, and the wash cycle is initiated and stopped, if necessary. The control panel also has indicator lights that show the washer status and will display an error code if there are issues with the washer. The "E20" error code indicates a possible pump problem.
Blocked Pump
One of the primary reasons why there may be an "E20" error code on a Frigidaire front-loading washing machine is if there is something blocking the pump. Disconnect the washing machine from the power and release the clips on each side to remove the front access panel. Set a container under the pump drain, which is located on the lower right side of the washing machine. Open the pump drain plug and allow it to drain. Clean out any debris that might be causing the obstruction, then close the drain plug. Close the access panel and restore power to the washer.
Drain Hose
If the drain hose is blocked or crimped, the water may not pump out fast enough, causing the pump error to appear on the display. Straighten out the drain hose in the rear of the washing machine and move it away from the washer if it's trapped between the wall and the washing machine.
Oversudsing
If too much detergent--or the wrong kind of detergent--is used in the washing machine, too many suds may result. This can overwhelm the drain and pump system, resulting in the error. Use only high efficiency (HE) laundry detergent with Frigidaire washing machines and follow specific instructions on the laundry container for the recommended amount of detergent. Run a drain cycle if there are excess suds in the washer to clear out the system.
Pressure Switch or Control Boar
The pressure switch may not be communicating properly with the control board, which can cause the E20 error to occur. The other possibility for the E20 error code is if the control board has failed entirely. Try to reset the washing machine by pressing "Stop/Cancel" and disconnecting the washing machine power cord. Wait 30 seconds, then restore power. Make a new cycle selection and press "Start" to see if the error code returns. If it does, turn off the washing machine and contact Frigidaire for repair.
Thanks.
Nov 08, 2011 | GE Energy Star WCVH6260F Front Load Washer
Kenmore model 119 24622300 Heavy duty 2 speed washing machine....The machine was in mid wash cycle and completely stopped. Although we have emptied the clothes and water out manually (it would not drain),...
the first three is 110 on your model number,not 119.lift the lid up around two inches and close it down,do this a few times,if you don't hear a clicking sound the lid switch is broken,part number 3949238.if that's ok when the washer is in spin does the motor run,if it does you broke the motor coupling,this is located behind the motor,let me know what you find and if you could answer the questions i asked i can help you out better
Oct 08, 2010 | Kenmore Washing Machines
Leaking whashing macine
you probably have a leak high up in the machine. take the top off, wash some blankets and see if you can spot the leak
Oct 16, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire top loading wash machine will not pump water out
if the oump is running check the oump for foreign objects in the pump and a stopped up drain hose if you have washed any blankets or rugs lately
Apr 22, 2008 | Washing Machines
E70 error
May 15, 2009
I had this exact same problem with my Frigidaire washer (E70) as bubbles100. I called an appliance repairman on 5/14/09 and paid him $60 to tell me my hot and cold water hoses were reversed/not properly installed.
This repairman was the cheapest priced $60 and he would work till he found the problem. I had one appliance repair company wanting to charge me $90 for 30 min and another wanting to charge $120 for 30 min. Hopefully this information can help save the next person some money by trying this first.
Feb 16, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
74 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
